Clarion DXZ-925 other features
27 replies to this topic
#1 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 19 February 2003 - 09:44 PM
Just wanting to know what kind of TA ontrol is on this unit?
[ February 26, 2003, 14:22: Message edited by: Bodyjar ]
#2 T-Bro
  • 1,057 posts
Posted 20 February 2003 - 12:35 PM
hey,
i use this unit so have some experience with it. basically, the TA works by allowing you to adjust the delay by entering the distance in "centremeters" for each speaker in your system, being:
- Front Left
- Front Right
- Rear Left
- Rear Right
- Left Sub
- Right Sub
so in theory, you enter the distance in 'cm' from each speaker to your headrest, and its aligned (though in reality it doesnt work quite that easily). i find that adjusting the delay of each speaker by ear works well using a test disc playing centre stage information only (just get the lady talking to appear in the middle of the dash, and your there).
you can save up to 5, or i think maybe 6, TA presents, so you can make one for you and one for the girlfriend etc as you can TA each speaker individually, it is very flexible - though if you are running an 'active' stage and want to TA the tweet and mid seperately etc, you will have to run one from the front RCA and the other from the rear RCA etc.
any more questions please ask, its a great head unit and sexy as hell
#3 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 21 February 2003 - 09:30 PM
Interesting! So its possible to tune by ear, and not by entering distance. Thats what I wanted to hear! I'm picking it up on Monday
My first move to Clarion, and to the SQ darkside.... hehehehe. Hope it was worth the small amount I paid for it
#4 Bodyjar
    3kW Power House
  • 8,545 posts
Oh and thanks for the info!
I'll be sure to ask more questions once i've installed it...
#5 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 26 February 2003 - 04:25 PM
Installed it Monday, and man is it sweet!!!!
T-Bro, since there are so many features, i'm getting confused! and the manual isnt as helpful as I'd like!
With the EQ, "band" = bandwidth right? what does "Q" mean?
And do you know what kind of frequency curve each EQ mode is set at? Sedan-1, Sedan-2 etc etc? I find Sedan-2 is the best though...
Also, it says whenever I want to save something, hold down the 2 and 3 buttons for 2 or more seconds, is this right? as it doesnt make a beep when I do it?
I basically have a problem of when I wanna change a setting, it turns off or goes back to default and I find myself making things worse!
#6 T-Bro
  • 1,057 posts
Posted 26 February 2003 - 05:10 PM
hey bodyjar
yep, you can adjust TA by ear, get a test CD (or any cd) where you know that someone is talking from the centre of the stage only. then experiment with delaying left, then right etc, until you can shift that voice to the centre of the dash where it belongs.
for the EQ, 'band' means the frequency band you want to adjust (cut or boost) for example midbass at 100hz or treble at 12kHz, and 'Q' means the width of the band that gets adjusted (low Q is wide and affects many frequencies next to the band, high-Q is very narrow and precise and only effects the band your adjusting).
probably best to deactivate the EQ presets like sedan-1, wagon etc, they're for the amateurs you will have better luck tuning the parametric EQ yourself, as it is 1/3 octave and hence able to zoom in on any problem area you might have.
as for saving presets, once you have set it, normally you press the ENT key, or hold down the preset number you want to allocate it to (ie only one number) and it should beep back at you. i cant remember the exact procedures (am at work) but thats basically how it works.
the manual is a bit weird, but after you read it a few times and experiment, you will master it
so what do you think of the sound quality, as compared to your previous unit?
#7 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 26 February 2003 - 05:55 PM
Well I dont have a sub in at the moment, and I havent really used many CD's that I'm super familiar with with the new deck. So can't really say the huge differences, but i have found it to be livlier.
It's definately a cut above the old deck, but I was using a Pioneer 8250, so it wasnt like a MASSIVE jump...
When I save the settings, it definately doesnt beep... so not sure whats going on... I'll sit down and tune it properly tonight, if I have any problems i'll let ya know!
#8 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 27 February 2003 - 08:04 PM
I had another play yesterday and for the life of me, can't get the EQ working properly... for some reason, whenever I change a gain level on a certain frequency, it changes the gain on ALL frequencies?!?! I can't seem to do one by one?
T-Bro help me PLEASE!!!!
#9 T-Bro
  • 1,057 posts
Posted 28 February 2003 - 06:16 PM
bodyjar,
mate, to be honest, i dont use the EQ features of the headunit (they are disabled in PrologicII mode) so i am relating more from what i used to do with my DRX9675z, than the 925.
have another read of the manual, i actually read mine over one whole week, over and over on the train to and from work, before i installed it or used it, to make sure i knew what i was doing
i'll have a play around on the weekend and see what i can find out, in the meantime, readup and experiment i guess
#10 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 28 February 2003 - 07:12 PM
T-bro, mate, I've read it over a thousand times! it says nothing on how to save each frequency in the instructions...
Ripped: Just cuz I have better crossovers
#11 Dr Jones
  • 416 posts
Posted 01 March 2003 - 04:30 PM
I will be happy to have a look at it for you, it all sounds very similar to the DRX9675z. Also with the Q in the EQ the lower the number the sharper the curve is around the selected frequency.
#12 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 01 March 2003 - 04:41 PM
If you're coming out Wednesday man, could you have a fiddle?
#13 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 05 March 2003 - 02:15 AM
T-Bro: Any word on what I should do?
Also, there is a sub controller somewhere isnt there? I swear I saw it once, but can't find it again?
#14 T-Bro
  • 1,057 posts
Posted 04 March 2003 - 06:50 PM
the sub controller is accessed by pressing the AM key (i think AM stands for audio mode in this case) on the far right hand side of the control panel, first press it will come up with SUB and you can go -5 through to +5, keep pressing it to cycle through fader, balance, centre speaker etc (depending on your setup).
as for getting the EQ presets to save, i still dunno, to be honest i havent even touched my system for over a week (partially disassembled). but i swear, once you have set each part of the EQ, you press and hold the ENT key until it beeps back at you...
sorry havent been much help
#15 Bodyjar
    3kW Power House
  • 8,545 posts
Posted 04 March 2003 - 06:56 PM
I'm at uni now, i'll go have a play with it
Thanks for your help anyways!
