ground loop/engine noise???
8 replies to this topic
#1 daniel price
  • 351 posts
Posted 15 July 2003 - 10:39 PM
hi all, my prob is that since installing the basics of my SQ setup, i have noticed a whining sound that changes pitch as the engine's revs change.
i have a feeling that this is the result of a ground loop, but have no idea how to pinpoint or fix the problem.
it is a large setup and currently running off an NRMA 560CCA standard battery. 2GA power and twin 2GA grounds (one on the engine in the stock position and one on the chassi).
any advice for fixing the prob is greatly appreciated.
thanks, Dan.
#2 craigt
  • 255 posts
Posted 16 July 2003 - 01:20 AM
make sure all rca's are on oposite side to power cables
ground all amps to the same spot using a nice big bolt
what deck are u running(sum times can be the cause)
shift ground point if not happy with location
check out www.autosound2000.com (they have done it all before)richard and david are the guru's.
hope this helps
#3 Subatomic
  • 960 posts
Posted 16 July 2003 - 01:27 AM
i recall that having 2 grounds is a bad thing, so this might be causing it.
i'd try just the 1 ground and see how it sounds
#4 craigt
  • 255 posts
Posted 16 July 2003 - 01:34 AM
dont take the engine one off your car need this to start. take it off and it(ur starter) will look for another path to earth usualy through the main wiring harness(could get messy)consult an auto elec before you go any futher
#5 Subatomic
  • 960 posts
Posted 16 July 2003 - 01:41 AM
ohh i thought u meant that u kept ur origional grounding point and just added another.. sorry!
#6 Konrad
  • 293 posts
Posted 16 July 2003 - 02:45 AM
Has nothing to do with RCA and power cables running close to each other.
Ground loops can allow noise into your system. They are caused when your deck and your amplifier have different ground references relative to each other. Jaycar sell an RCA isolation transformer, which will effectivly eliminate the DC component (ie shift in ground reference) from your RCAs and remove the whine.
#7 RTTZ
  • 623 posts
Posted 16 July 2003 - 03:31 AM
Try a different ground point for your amps - a good solid point - that might just solve you noise prob.
Da'flea.
#8 RTTZ
  • 623 posts
Posted 16 July 2003 - 03:37 AM
Quote
Actually, some cars will benefit(in terms of performance and electrical flow) from a few more ground points from the battery to the car.
Da'flea.
#9 mazzoi
  • 50 posts
Posted 17 July 2003 - 10:25 AM
hmmm i was having the same problem, running sub and splits off the one amp, i thoguht it was the RCA for the splits.. it turned out that when i d/c the RCA for the sub the whining/buzzing noise went away, so i got one of those ground loop isolator things, and it all went away...
that was until i unscrewed one of the speakers and put it back in , i'd unscrew it slightly and the noise would go away?? oh well
