2X 12W6v2 or single 13W7?????
14 replies to this topic
#1 Interceptor
    1500 - 3000w RMS
  • 2,094 posts
  • State:Other
Posted 27 October 2003 - 08:35 PM
What’d be better for SQL purposes?
1X JL Audio 13W7D1.5 driven by a JL 1000/1
or
2X JL Audio 12W6v2D4 driven by a pair of JL 500/1
both will be in a ported box matching the JL recommended volume.
and at a guess, what kinda SPL could I expect from either setup in a XF sedan?
#2 adrianf
  • 397 posts
Posted 27 October 2003 - 08:44 PM
couldn't you could use the 1000/1 for either setups? it would be cheaper.
#3 Interceptor
    1500 - 3000w RMS
  • 2,094 posts
  • State:Other
Posted 27 October 2003 - 09:14 PM
no, the 12W6v2's are dual 4 ohm, and with 2 of them i'd have to run them at 1 ohm or 4 ohm, and the 1000/1 isnt 1 ohm stable, and i want to tun the amp(s) at as low an impedance as possible to screw every lil bit of power out of them
#4 adrianf
  • 397 posts
Posted 27 October 2003 - 09:36 PM
but they are regulated.
i know there is a difference with those amps running in 2 and 4 ohms. but not much
but yes 2x500/1 will have a bit more totaly power in either 2 or 4.
higher impedance higher dampning factor
from what i have read. a 13W7 should have a slight lead in sq and spl. but you really need more than 1000rms for it to really pull away.
i had a quick look at sounddomain forums. if you haven't already, do a search on w6 vs w7 and you'll get quite a few posts of interest.
good luck.
#5 Winno
    Eccentric but effective
  • 1,756 posts
Posted 03 November 2003 - 08:41 PM
Go the two 12W6 subs for the amp set up you have in mind definitely.
We stock and get to play with daily, the subs you are asking about and so I speak from experience here.
#6 Interceptor
    1500 - 3000w RMS
  • 2,094 posts
  • State:Other
Posted 03 November 2003 - 10:57 PM
just as a variation, would it change much if i put the 13W7 in a ported box, and the 12W6v2's in a sealed box (i'm limited with space, and a sealed box for 2X12W6v2's is nearly the same size as a ported box for a 13W7)
#7 Maz
    3kW Power House
  • 3,998 posts
Posted 05 November 2003 - 02:45 AM
I'd get a 13w7 with the 1000wrms monoblock.
That system will be very very good.
#8 ultim8DTM5
    1500 - 3000w RMS
  • 2,294 posts
Posted 04 November 2003 - 03:03 PM
Is budget an issue?
Why not compromise and get two 12W7s?
#9 Interceptor
    1500 - 3000w RMS
  • 2,094 posts
  • State:Other
Posted 04 November 2003 - 09:53 PM
1X13W7 ported: 67.3L ($1998)
2X13W7 sealed: 106.2L ($3996)
2X12W7 sealed: 77.88L ($3396)
2X12W7 ported: 99.12L ($3396)
2X12W6v2 sealed: 70.8L ($1996)
2X12W6v2 ported: 85L ($1996)
2X13W6v2 sealed: 92L ($?)
2X13W6v2 ported: 106.2L ($?)
now, if I use a box with any more than 90L I’m gonna have a serious lack of space in my boot (don’t ask why) so I’m limited to the selection above (using JL’s recommended specs) my initial thoughts were for a pair of 12W6’s or a single 13W7 just to give me that little more room as well as being in the same kinda budget
At the moment a pair of 12W7’s looks the best option, but if budget is a concern, a pair of W6’s or a single 13W7 might be the go.
[ November 04, 2003, 20:00: Message edited by: Interceptor ]
#10 DG Phil
    Hoogste Hond
  • 11,943 posts
Posted 05 November 2003 - 01:13 AM
The W7 is superior in terms of SQ.
A pair of W6s would probably be louder on a meter but who cares, you won't win any SPL comps in an XF!
A pair of $1000 subs will sound like a $1000 sub, only louder. A $2000 sub will always sound like a $2000 sub.
Have a look around at some other high end woofers, I personally think the W7 is a tad expensive for what it is, even with it's flashy looks.
#11 Interceptor
    1500 - 3000w RMS
  • 2,094 posts
  • State:Other
Posted 05 November 2003 - 08:11 AM
i know i'm not gonna be seriously competitive in SPL comps, but i wouldnt mind being in the mid-high 140's, besides, who says you cant hit high numbers in a big car????? and before you ask, no, i'm not gonna go for DD subs.... i'm very impressed with JL gear in general
#12 Damo95
    Team Tennent
  • 7,178 posts
  • Interests:Car audio & Architecture
Posted 05 November 2003 - 03:53 PM
I am in the same situation as you interceptor.
i was tossing up between the 2x12W6v2 or the single 13W7.. i was gonna run them off a PPI PC21400 (1x1400wrms @4ohm) and im going to choose the W7..
I have been told to go DD as well, but i didnt want to 'blend' in with the majority and i have always had a soft spot for the JL's, used them in the past..
to be honest, i would go the W7's..
they are better than the W6v2 in build quality, etc.. as well as handling more power.. Not to mention the smaller boxes..
Go the W7..
#13 Rattlehead
  • 1,451 posts
Posted 05 November 2003 - 08:57 PM
DAMO!!!!!!!!!!!!!
No more considering - go buy the W7!!
If I had $$$ I'd get the W7 - such a nice woofer.
#14 Winno
  • 1,756 posts
Posted 05 November 2003 - 09:00 PM
I agree that the W7 is the better quality of the two but what about cone area?
Two 12W6's would be better in this regard and you can use a sealed box and get the SQ side of things right as well (although, if you follow JL's box specs to the letter, their ported boxes do sound very good)
#15 Damo95
    Team Tennent
  • 7,178 posts
Posted 06 November 2003 - 03:52 PM
Quote
Originally posted by Rattlehead:
DAMO!!!!!!!!!!!!!
Rattle..
i WAS considering, and now im gonna get the W7.. the L7's and the ZR600 are coming out end of year..
Winno..
i believe that a better single sub would be better than 2 of the lower model.. ok, twice the cone area, but also half the power to each sub..
by using the single W7 you can use a single box and still have boot space and lots of power, where the twin would need twice the enclosure volume.. i can go on but i wont..
we'll see how i go with my W7 next year..
mind you, i'll have 1400wrms goin to it..
