right way to go about testing
4 replies to this topic
#1 Shieldsy
    Heaps G
  • 3,564 posts
  • State:ACT
Posted 31 October 2003 - 05:34 PM
ok many maany people are saying you have to be carefull of this and that variable and this can blur that and so on and so on... now wat i am sugesting is that we list all the main variables and ways to combat them... obviously you need some constants like your speakers head unit and xover settings.. so i would say use an seperate xover unit and set the amps to full range with no added features on... one problem i see is setting the gains... how would you overcome this? would playing a tone thru the fronts and setting your volume on the head unit as a constant and adjusting the gains so each amp was hitting the same number (you would use amps with the same power output to deal with problems like head room and the sort) so you would allso need a very accurate meter.
would this work or am i just losing my mind? wat other variables are there that could hinder a test on amps and how could you combat these problems that the variable creates
#2 STIK79
    3kW Power House
  • 4,342 posts
Posted 31 October 2003 - 06:22 PM
You can accurately set gains using an oscilliscope
Other variables are power supply - need a power supply that doesn't drop voltage over time - ie a 240V->13.8 power supply
otherwise yeah - external crossover used (or even better run full range...)
#3 STIK79
    3kW Power House
  • 4,342 posts
Posted 31 October 2003 - 06:24 PM
Quote
and bypass all filtering onboard the amp - ie LPF/HPF bass boost yada etc...
[edit]oops pressed quote button [/edit]
[ October 31, 2003, 16:25: Message edited by: STIK79 ]
#4 mick007
  • 453 posts
Posted 07 November 2003 - 03:06 PM
If you took eveything away from an amp, eg x-overs in particular arn't you putting that amp a a disadvantage to others that don't have x-overs as good?
Or maybe the test should read amplifier shootout INCLUDING x-overs, bass boost etc, etc. That way you are testing the amp as it sits, not breaking it down to it's raw components.
Mick
#5 con
  • 46 posts
Posted 09 November 2003 - 03:35 PM
this site lists the variables
http://sound.westhost.com/amp-sound.htm
