2 way vs 3 way splits in competition
Posted 04 November 2003 - 11:20 AM
I haven't been able to yet, and I am starting to think that I may be waisting my time entering sq events when I am against 3 way's.
What is everyones general thoughts???
Posted 04 November 2003 - 11:25 AM
Posted 04 November 2003 - 12:44 PM
speaker positioning, tuning, install quality etc..etc...all add up...
3 way splits are not neccessary to win a comp...you just have to make the best of what you have...
Posted 04 November 2003 - 01:58 PM
However if your system is SQL orientated and the woofers exceed Xmax, or 8inch woofers are usedto keep up with the subs, then a seperate midrange would make a noticable difference.
Having a seperate midrange would also allow you to push the midbass drivers harder.
Posted 05 November 2003 - 02:16 AM
Posted 04 November 2003 - 03:06 PM
Quote
It's not what you have that wins the shows it's how you use it...
#7
Posted 04 November 2003 - 03:11 PM
Quote
#8
Posted 04 November 2003 - 04:03 PM
"Its not the size, its not even how its used, its how often it gets used"
As for three ways - install counts for everything. If you can justify it, and have the expertise to pull it off then go for it!
#9
Posted 04 November 2003 - 04:28 PM
ie. The more pieces you chop the sound up into the harder it is to reassemble those pieces into the original music.
I tend to agree, after all wouldn't the best piece of speaker be a single entity producing the whole audible spectrum?
[edit] bah fuxored the saying up
[ November 04, 2003, 14:50: Message edited by: STIK79 ]
#10
Posted 04 November 2003 - 04:31 PM
#11
Posted 04 November 2003 - 09:47 PM
2 ways are often easier to place and keep the mid and tweeter close together for nice tight imaging. There is also less playing with crossovers settings and level setting. Not to mention often (not always) cheaper, less amplifier power required, more variety to choose from.
I have had both and currently enjoy a set of 3 ways which i find can be pushed louder and provide a more solid punchy midbass up front.
I found when i had 2 ways once you get the volume up a bit (and i have a fair bit of road noise with turbo, exhaust BOV etc...) the midrange cone is moving a good amount of air and some of the midrange frequencys suffered.
#12
Posted 07 November 2003 - 03:42 PM
Dynaudio has a top of range home speaker that is basically as good as they can make and nice houses cost less, and it uses 9 drivers per speaker cabinet to cover 20-20K. The reality is there is no one perfect speaker that can do the 20-20K thing and so we need to use several drivers to cover the bandwidth properly.
Anyway on the 3 way V 2 way front stage issue, even in a worse case secnario, and you lost a few points for lack of midbass relative to a competitor with 3 ways, there are many points left to be gained in imaging and stageing, spectral balance etc and so you may give up 1 or 2 points but if you get the rest right, you should win in other ares, and if the other guy does all that well too, then unfortunatly(for you) that competitor has a better sounding system at the end of day and so should win.
I wouldnt go 2 way or 3 way, just to win, as its really about doing the best you can with what you can afford and choose to use. If you cant fit 3 ways then do the best you can with 2 ways, as at the end of the day its you who listens to what you have most of the time, and so you should have what you like to listen to, and if it happens to be competitive then even better, but you still have to live with the system.
cyberpunky
#13
Posted 07 November 2003 - 04:45 PM
However, I think that if you have a good 3 way speaker (eg Dynaudio System 360) AND it's installed well, then you have the luxuary of angling each speaker (and bascially speaking, each speakers range of reproduction) anyway you want. So basically if you are having problems with midbass, you can alter the placement of the midbass speaker and not change the midrange positioning. Also, a secret to a good 3 way system is the crossover. I have heard 3 ways sound worse when a customer chooses to go full active and tries to tune him/herself. Bascially, how each speaker rolls into each other (both frequency and rate of roll off) can affect how they sound together. So to sum things up (god I'm harking on in this post!!) if you trust your installer, and he/she has the skill to pull it off, then a 3 way can offer more adjustablilty, tuneabilty and ultimately better sound - however if all the factors I've mentioned above aren't close to perfect (which a lot of times they aren't) then a 2 way can out perform the 3 way because there are less variables to stuff up!!
Just my 2.2c worth
[ November 07, 2003, 14:49: Message edited by: SQBOY ]
#14
Posted 07 November 2003 - 05:49 PM
i've heard brilliant 3 ways. i've heard brilliant 2 ways. god i was floored when i heard the Dynaudio evidence masters ($128,000). it all comes down to your application and the way your gear is implemented.
having said that, i'd take some system240esotars over system360s any day....
d
#15
Posted 07 November 2003 - 08:09 PM
Quote
d
