Alpine's Ai-net Output voltage???
7 replies to this topic
#1 infiltrator
  • 393 posts
Posted 08 January 2004 - 12:58 AM
G'day all... i have been wondering for a while now about Ai-net's output voltage...
i have a alpine h/u (model No escapes me atm) with a 3 sets of 4 volt preouts and Ai-net.
i also have a PXA-H600 processor running off Ai-net..
even tho the pxa is running nicely i want to know should i feed it an rca input if the Ai-net voltage is lower???
thanks for your help..
marty
#2 Cyberpunky
    3kW Power House
  • 3,321 posts
Posted 08 January 2004 - 07:35 AM
If you use digital input then you will get 4 V out. You need to use RCA or dig with any Ai-net processor (I think) and so will get 4V with either. If you used just Ai-net, if thats possible, then you should get 4 V too.
Anyway its been a while since I worked at an Alpine d4ealer but give one a call or Alpine direct to be sure, unless others know ?
#3 JohnA
  • 1,401 posts
Posted 08 January 2004 - 07:42 AM
The ainet cable is simply a way for the HU to talk to the processor, the processor then gives you 4V via the RCA outputs to the amplifiers
#4 infiltrator
  • 393 posts
Posted 08 January 2004 - 06:53 PM
corect me if i am wrong but using the ai net system the head unit becomes a digital decoder and the processor becomes the pre amp???
#5 JohnA
  • 1,401 posts
Posted 08 January 2004 - 11:06 PM
that is correct, the HU will only act as a cd transpot unit and all the DAC's and preamp function will be from the processor
#6 Macca
    1500 - 3000w RMS
  • 1,806 posts
Posted 13 January 2004 - 01:35 PM
Well i asked this same question in my therd in there forum. As i dont have an Alpine HU im using RCA inputs. As far as i know the PXA does diplay a warning icon when the input signal clips. But i would like to know what type of digital interface it uses. Its own codec or some sort or just your basic 1's and 0's on a CD
BRYDEN
The world needs to be EVOlutionised.
#7 Mr_Bob
    3kW Power House
  • 8,745 posts
Posted 13 January 2004 - 02:37 PM
Quote
the RCA output from your HU is analogue, therefore it has already been through a DAC.
the PXA may convert back to digital, then back to analogue again, but it would hardly be worthwhile, as if "colouration" from the first DAC would still be present, and it would only make matters worse.
using the DAC in the PXA would only be useful if you had a digital link between the HU and the PXA, bypassing your HU's internal DAC. (it will send only 1's and 0's to the PXA)
<p style="text-align: center"><strong><span style="font-family: Tahoma"><span style='font-size: 10px;'><span style="color: red">RE XXX Splits - AXTU600C<br />12&quot; RE XXX - USAmps AX2000</span></span></span></strong></p><br />  <p style="text-align: center"><em><strong><span style="font-family: Tahoma"><span style='font-size: 10px;'>2004 CAASQ National Champion (Amateur Street class)</span></span></strong></em></p><br /><p style="text-align: center"><em><strong><span style="font-family: Tahoma"><span style='font-size: 10px;'>2005 CAASQ National Runner up (Pro Street class)</span></span></strong></em></p>
#8 Macca
    1500 - 3000w RMS
  • 1,806 posts
Posted 13 January 2004 - 07:35 PM
True Mr bob it wouldnt be worth wile, i was hoping that a high end deck with digital out would work OK thru the PXA.
BRYDEN
