Are all 3 ways better than 2 way?
Posted 27 June 2004 - 10:59 PM
Posted 27 June 2004 - 11:02 PM
To install the 3ways will cost heaps more, to pay someone to install. The 2ways can fit in the factory spots.
If your installing everything yourelf then the 3ways will definitley be better. However if you have to pay someone $300 to make custom kicks or pods then The 2ways will be heaps cheap, so u could spend more money on the 2ways which will kick bum.
Posted 28 June 2004 - 03:16 AM
Posted 28 June 2004 - 08:19 AM
MEA National Sound Quality Champion - Amateur Show 2004
MEA National Sound Quality Champion - Pro Show 2006
Qualified Sound Engineer
Posted 28 June 2004 - 08:33 AM
Posted 28 June 2004 - 11:39 AM
I still prefer a nice set of 2 ways but with the 3 ways, depending on that car and install, it might actually be easier to get a good image with them.
Its a lot easier to install a tweet and a 3" or 4" mid range and image them that to install and image a 6.5" and a tweet - like in my car, I had the tweet and 4" in the kicks. 6.5" won't fit in the kicks and give me enough pedal room.
Bye.
Mo
#7
Posted 28 June 2004 - 12:03 PM
the 3 ways (if installed optimally) should image better, and because they aren't required to play a large range of frequencies, it's easier to make them sound good.
however, installation will play the biggest part.
if the 3 ways are installed poorly, then the 2 ways will be considerabyl better.
installing 2 ways isn't much of an issue for anyone, an angled spacer/pod and a location for a tweeter.
installign 3 ways involves lots of custom work, and organising your doors/kickpanels/dash to suit the drivers.
don't think "i can fit the 4 inch speaker here" cause chances are it wont sound good there.
generally they work best in kick panels, if you can fit the tweeter and midrange in there, then it might be worthwhile going for 3 ways. i tried mounting mine in my doors, and it didn't sound anywhere near as good.
#8
Posted 28 June 2004 - 08:31 PM
Thanks for your replies..
The polyglass 156V3E comes with the slim 100V 4" so it should be suitable for kickpanel.... BUT.. how do you all find space in there? I don't mind putting there...but looks like I don't have enough depth to clear away from my accelerator.
Anyone with pics of their kickpanel (driver side please)....???
#9
Posted 29 June 2004 - 12:45 AM
My VN can fit 4inch mids in the kick panels no problem, and thats with them angled quite a bit. No pics though as im now running horns.
#10
Posted 29 June 2004 - 03:26 AM
#11
Posted 29 June 2004 - 04:20 PM
all in the doors too... 6" in factory location, 4" just above that, tweeter also just above that. Initial testing of the sound is fairly good (the sound stage). however it was tested using some speaker level outputs on a deck, they'll be amped and the doors will be deadened.
some "so far" pics are here:
http://www.micra.hl.com.au/messages.asp?me...messageID=10325
I'll see how it sounds when it's deadenned and amp'd before I look at possibly enclosing the 4" off from the rest of the door. It might be okay.
They arent angled in any way, I've played with these speakers heaps, including in another car, and I've found they've always sounded better off axis, especially the tweeters....
#12
Posted 29 June 2004 - 05:08 PM
i didnt even know what a micra was until this post
wow its a really small car, might even be smaller than my mothers echo
its amazing how much can fit in a small door when you want to make it fit :-)
is there any room in the kicks for a 4inch mid and a tweeter????
great effort and keep up the good work :-)
#13
Posted 29 June 2004 - 05:37 PM
thanx, yeh I've only had the car for 1 week ! hahahaha. I bought a micra because it's the only other small car that I liked that would fit in my garage with my other cars. (had to be less than 3900mm long!) sounds silly but yeh no crap. It's my daily driver, so will cop the tunes.
the doors are large, as most 2-door cars have large doors. the car is very spacey inside! nice 1.3ltr twin cam motor, kinda like an sr20, only smaller.
yes you could easily put mids and tweets in the kicks. I already made fiberglass ones for my pulsar. I cant be arsed doing it in the micra. There's a small amount of wiring behind the passenger side kick too which i couldnt be bothered re-routing. When i discovered that it wouldnt be too hard to fit all the speakers in the doors, I went for it.
I'll be updating that link as I go along
I wanted to keep this car real lightweight so i dont loose performance, but it's not easy as everyone knows when your doing an install. I probably wont fit the JL12W6, I'll prolly go a tenner or something. fiberglass tyrewell install possibly, etc.
James
#14
Posted 29 June 2004 - 10:23 PM
Is it really easy to put the mid and tweeter at the kickpanel? My accelerator and the plastic piece is only like an inch away...
#15
Posted 30 June 2004 - 12:07 AM
remove the kickpanels and see for yourself!
James
