angelo kanci said:
Not bad piece. BUT STILL RCA'S NOT BALANCED, LOW OUT PUTS 2 VOLTS. Don't quote input/ output impedances , AREN'T PERFECT Q EQUALISER ETC, ETC, ETC . STILL missing the point in my language.
Audio Control or Orion are just the same. None of them have any line driver capability. If you read careful, they are no more than a Level Matcher.
angelo kancil said:
Are the power supplys isolated I DON'T THINK SO.
Getting into it you start to see the short comings BUT if you like it so be it.
I'm impressed when l see
The PS are most defenietly isolated. Balanced line is really no big deal. If the PS is well isolated, then you don't need a balanced outputs.
Balanced outputs were created in Pro Industry to isolate noise when running several 100 metes of signal wires. Balace line was not created to improve sound quality. As matter a fact, it make the high freq a bit more edgy and raw. Is also another reason why you will virtually will not see any balanced line in Home audio.
angelo kancil said:
HIGH OUTPUTS
BALANCED
FULLY ISOLATED POWER SUPPLIES
HIGH INPUT IMPEADANCE
LOW OUTPUT IMPEDANCE < 4 OHMS
PERFECT Q ( EQUALISER )
PERFECT PHASE ( XOVER )
AD AND DA
see these are the things to consider THESE SPEC ARE MISSING !!!!!!!!!!
That just get you in the ball park. It really does not tell you how it will sound or perform. Specs are really for marketing. Or else, Krell and McIntosh would and should of gone bankrupt a long time ago.
IMO, you can't qualify a product by it's Quantification (Numbers).
I mean, you could have a EQ with best flexibility and with top notch Op-Amp IC that can sound really bad because the company could of cut corners and used 30% tolerance Potentiometer vs. 10%.
As for the Orion DEQ? I'm not 100% sure but I'm betting it's already been re-engineered to make them cheaper. Don't get confused when the original DEQ was designed by Orion Industries in Tempe Arizona. Now, it's made offshore. Did they go offshore to make them better? equal? or to just shave cost and market the snot out of the product?
In my eyes, Orion does not exhist. It just happens now that a company is calling themselves Orion.
Let's think, where does Orion
"Industries" fit into Directed Electronics
"Incorporated"? I sure don't see the Orion building anymore. Just a "Brand" mixed in with others now. Pretty sad actually.
BTW, Potentiometer is the biggest cost factor in any analog processor. Some very popular processor company uses...believe it or not about $0.30 PS.
