Should a 10"sub be used with an 18" sub setup?
Posted 21 February 2005 - 06:42 PM
I installed a set of blauhpunkt 3ways with an 8" woofer in my gfs car and she has a 12" sub and it sounds kinda crappy.
but would it be a good idea?
Peace
Matt.
Posted 21 February 2005 - 08:07 PM
Posted 21 February 2005 - 08:10 PM
my rule of thumb is that the diameter of the midwoofer should be more than 1/2 the diameter of you subwoofer.
Posted 22 February 2005 - 11:14 AM
Posted 22 February 2005 - 11:41 AM
Posted 22 February 2005 - 01:28 PM
The "rules of thumb" that are based on the diameters of the midbass and woofer are not real world at all. Based on cone diameter, an 18" can play well above 500hz+ without problems. The inductance is the dominating factor limiting the high frequency response.
Tutorials & FAQs Subforum
#7
Posted 22 February 2005 - 01:43 PM
what's the point of having large amounts of bass on-tap, wihtouth having enough midbass for it to integrate properly.
sure, an 18" driver isn't supposed to suffer from beaming until 733Hz, by my experiences show me that having 4" drivers with 12" subs, or 5.25" drivers with 15" subs just isn't a good mix when it comes time to tune.
#8
Posted 22 February 2005 - 02:01 PM
I plan on filling my wagon up with six 15inch subs in a few months, so i bought a pair of 10inch freeair subs to mount in each front door to provide the tight bass, these should keep up fairly well i hope.
U'd need custom pods to fit 8's into a 300zx
#9
Posted 22 February 2005 - 03:37 PM
And the sub is an 18" audiobahn which will run off an e-audio 3000D, 2000wRMS @2ohm
and maz yea 8" imo will stick out a bit too far in the doors.
would having the 8"or10"s drivers in the back sound weird? it wont sound like its coming from the rear if its LP will it?
And mr bob i agree, my last install when played loud was either bass or sound from the tweeter. i couldnt hear anythign else.
#10
Posted 23 February 2005 - 04:03 PM
Tuning is easy, you just turn the subwoofer level down.
Nah, I agree that having tons of linear displacement from the subwoofer(s) on tap is kind of pointless for SQ if your front stage can't keep up. (but thats not just about cone area, but xmax and power too...)
Also, its not just the midbass drivers that will struggle to keep up, but the whole front stage. (although with horns and large midbass drivers would have a bit more chance of keeping up)
Quote
It would be pointless having 10" or 8" at the rear because it would sound virtually the same as if the 18" at the rear of the car was covering that same bass range.
If you want to run 8"s or 10"s to cover the midbass then they have to be mounted up front.
#11
Posted 23 February 2005 - 04:09 PM
my inference was that the "upgrade to 8's" would be replacemetns for the midbass drivers upfront. putting them in the boot would be pointless.
#12
Posted 23 February 2005 - 07:53 PM
i spose i will have to trial and error.
thanks for your help
#13
Posted 26 February 2005 - 03:39 PM
Quote
Which is the perfect way to destroy your stero sound stage. Please don't do it.
