hey guys, just bout to start installin my system. system consists of
Sony XAV- A1 Unit
DD C6.5 Splits (to be ordered) dont know what the power rating for these. anyone?
Soundstream Xstreme XTS 6.5 Coax power handling 150rms
DD 3515 dual 2 ohms
Earthquake D2 - to run sub. modded to .5 ohm stable at roughly 3000rms
Soundstream Van Gogh VGA 500.4 4 x 125 rms
Soundstream Picasso 4.640 4 x 80rms
my first question is what gauge power n cable wires should i use? Is 1 gauge perfect or is 4 gauge adequate. bearin in mind the total power output of my amps, im thinkin the 1 gauge is the way to go. tied in with this question, what fuse rating should i use to protect the power line? where can I purchase a 1 gauge amp wiring kit and how much would i be looking at?
second question is in regards to the DD C6.5 n the amps. in terms of achievin better SQ. is it better for me to wire the DD C6.5 active? or bridge the amp to run 2ch n feed 250rms to each channel? or will this amp be more than enough to run the DD and the XTS (1ch each, hence sell the Picasso).
if I run the DDs active, will the tweeters handle the 160rms? also what frequencies should the tweeters and mids be tuned at?
with running three amps, what things should i be aware of? can i use the same ground point for all three or would i need to find a point for each one?
in regards to the sub on a day to day basis n SQ point of view, would it be ok/blend in well with the speakers if i run the sub at 1ohm? or is it better for SQ to run it at 4ohms?
last question is would i need a cap for this install? by the way this is goin on a jeep grand cherokee.
if there's anything else that I have left out or need to be pointed out to me, pls feel free to let me know. thanx in advance.
Red
need wiring advice
Started by Red23, May 05 2005 03:09 AM
3 replies to this topic
Posted 05 May 2005 - 03:09 AM
Posted 05 May 2005 - 10:13 AM
id uas a single run 1/0guage then split it up into two x 4gauge + one 1/0 gauge
you can find unfused distribution blocks that do this or
i had a stinger expert maxi fuse block that did dual i/p 1/0gauge and 3 4gauge output fused. If you used something like this id run the earthquake out the input so you can use 1/0 to it (so not fused from dist block)...and fuse the other amps with maxi fused 4 gauge.
as far as active vs passive its been discussed here alot. No real answer people are divided, but i can say that you will need professional help if you choose the active route. An rta or something similar will be needed to set the x-over points. Certain tweeters require certain slopes and cut-off points to sound good. A certain tweeter i use in car ONLY sounds good with 12db/oct x-overs for some reason.
i think for now just install it and use the passive x-overs so you get some sound in the car. Later on you can spend the extra time and cash going active front stage. Place the passive x-overs in the rear of the car near the amps so you can easily take them out and go fully active.
good luck
good luck
