Lrx 1.400 & IDMAX - 1ohm or 2ohm
6 replies to this topic
#1 alvins
  • 170 posts
Posted 05 May 2005 - 10:26 AM
Just wanted some advice on how I should run the IDMAX with the 1.400. I haven't purchased the sub yet so I can get a dual 4ohm or dual 2ohm. Thus, running it on the 1.400 - it will either be 1 x 600 RMS at 2ohm, or 1 x 900 RMS at 1ohm.
What would be the better way to run it keeping in mind -
- running in 1.3cu sealed box (recommended by id)
- sq oriented system
Cheers,
Alvin
#2 Stooge007
    2009 - Welcome Wayne Bennett
  • 6,301 posts
Posted 05 May 2005 - 10:31 AM
more power the better.
although cooling fans are a MUST when running the 1.400 @ 1
- Stooge007 out
DISCLAIMER: by reading the above post you have absolved me of any responsibility whatsoever if what I have recommended happens to break any of your stuff, or burns your car to the ground!!!
Please visit the TUTORIALS and FAQs section, or try SEARCHING before posting a new topic
Also check out the Most Popular & Useful Tutorials :)
shiny_car said:
i'm not here to disagree with stooge - his advice is always tops
#3 alvins
  • 170 posts
Posted 05 May 2005 - 02:37 PM
Would there be a reason (besides the amp heating up) to run it at 2ohm? My understanding (limited) was that you lose out in dampening factor when you load the amp up.
#4 nuttered
  • 933 posts
Posted 05 May 2005 - 02:43 PM
hey dude, if you got 900watts on tap, and a hungry IDMAX, do it! Don't worry too much about specs. Quality equipment will always sound good if installed properly
#5 shiny_car
    Posts too much
  • Admin
  • 40,177 posts
Posted 05 May 2005 - 04:05 PM
for SQ purposes with 'normal' listening volumes, 2ohm will be adequate. it does depend on the size of the car, sedan vs hatch, and how loudly your front stage is too. and whether you wish to compete in SPL comps.
i've found IDMAX's aren't very power hungry, but quite efficient. :P
#6 alvins
  • 170 posts
Posted 05 May 2005 - 06:42 PM
Won't be competing in SPL comps.
Car is Lancer coupe 2000.
Frontstage is Dyn 240GTs running off a 2.500.
So gets pretty loud.
What do you think Shiny? So far all have said give it 900Watts.
#7 STIK79
    3kW Power House
  • 4,342 posts
Posted 05 May 2005 - 06:48 PM
I'd say go for 2 ohm too :)
the sheer fact that the 1.400 needs fans all over it to run @ 1ohm means that it's under a fair amount of strain to run at that level!
Then if you find you haven't got enough juice on tap it's a fair amount easier to find a monoblock that's 2ohm stable over 1ohm stable.
VTII Berlina
HU: Alpine CDA-9815
Front Splits: DLS Ultimate Pros 6.5"
Rear Fill: Philips GTM-1750
SUBS: 2 * Alpine 12" DVC type-R
Front Amp: SS TR880/2
Sub Amp: SS TR1600/2
