Xenon X600.1 Xe.Load Trick
16 replies to this topic
#1 Iceman_jkh
    Group: sex
  • 899 posts
Posted 05 May 2005 - 07:02 PM
Hi guys,
I have a Xenon X600.1 (some knew that already) (600W into 1-4Ohm).
I am looking at getting an IDMAX 12" to run off it.
I wanted to know if anyone has experience or knowledge about doing Xe.Load tricks, to make the amp think its running @ 4Ohm load.. but actually use a 2Ohm load.
I believe the amp determines the load @ bootup.. then delivers the required current (for 600W output) after it knows what load is present. Is it possible to trick/rewire the amp to always sense a 4ohm load... but actually give it 2 Ohms. Therefore increasing power output... yes other things will go down/get worse i know.
I know higher current is higher stress for electrical and amp.... but I'm interested.
Thanks,
Jason
Car: Holden VY Berlina
Progress: 90% Complete
Source: Fully Active Core2Duo CarPC (90%)
DAC: E-MU 1820M [24Bit, 120dB SNR, 120dB Dynamic Range]
Amps: JL Audio 450/4 + JL Audio 1000/1
Tweeter: ScanSpeak D2904/600000
Midrange: Hertz Mille 165MLK
Sub: Peerless XLS 350500
Doors: Dynamat Extreme - 4Kg/door & Absorb Pads
Battery: 750CCA Orbital Deep Cycle
Wiring: Modified Stinger "Hyper" Interconnects + Stinger 0AWG 'Platinum' Power Kit
