help with idamax
6 replies to this topic
#1 N15TURBO
  • 1,099 posts
Posted 11 February 2008 - 09:49 PM
so i have now got an idmax10d4v3 in my hands
i need some advice of what size enclosure i should use,
i like R/B, Hip/Hop, and a little hard house
but mostly r/b
so yea have i chosen the right sub,
i have a pulsar n15 hatch if that helps and it will be running of a clarion dpx1000.2 bridged so 1000@4ohm
also running focal 3ways semi active.....the huge amount of vibration is from the door not the speaker right, also i have no idea what xover settinigs i need
Daily driver
Nissan Pulsar N15
Eclipse//Polk audio//Audio development//Audio system Mosconi
Weekend Track/show car
Nissan Pulsar N15
Pioneer P99
Audio System Mosconi 300.2 + 200.2 + 100.4 (active
Audio Development MM 1/4/6
Audio Development Vipera 12 x2
Dynamatt//Stinger//Rockford
SR20DET//GT2860RS(12psi)//Big frontmount n custom pipes//LSD gearbox//3" exhaust//Z32 4Pots//Enkie RPF01 17x7+35//Tein SS coilovers//Greddy E01+Nistune//480CC injectors//Pit Road M Carbon bonnet + Topstage front lip//AND ALOT MORE
#2 Matt VIP
    Got loud yet?.....nope...
  • 4,090 posts
  • State:ACT
Posted 11 February 2008 - 11:21 PM
what the hell is going on with my hotlinking skills today dammit!
this data sheet (which should have come with the sub) gives you the box sizes & specs for your sub
with that much power you should have no worries getting the thing moving.
So, how competent a box builder are you?
a) "Miss Hoover I nailed my hand to my sub box" - build yourself a sealed box
b) "Miss Hoover I nailed Ralph's hand to his sub box" - build yourself a ported box
also pay attention to the quote at the bottom of the data sheet. it says "choose response "a"
as for the vibration, how well is the midbass attached to the door?
have you used sound deadening on the door? If not, consult the tutorials and the beginner section too :)
hope that helps
Edited by VIP318, 12 February 2008 - 09:11 AM.
Quote
The only excuse for passive crossovers is their low cost. Their behavior changes with the signal level dependent dynamics of the drivers. They block the power amplifier from taking maximum control over the voice coil motion. They are a waste of time, if accuracy of reproduction is the goal.
my vibe tastes like hedgehog slice
#3 N15TURBO
  • 1,099 posts
Posted 11 February 2008 - 11:55 PM
mid bass is 18mm mdf spacer straight to the steel...and i thought it was that but wanted re assurance.....
as for the data sheet that aint my sub....mine is id max not idq that look like
small box .6
normal .9
but i want tight n fast n low bass....what size will acheieve this
Daily driver
Nissan Pulsar N15
Nissan Pulsar N15
Pioneer P99
#4 mooingchicken
    mr moo
  • 1,039 posts
Posted 12 February 2008 - 07:32 AM
Quote
bit late now if you dont like it....
Quote
deaden your doors
/////ALPINE . Audiosystem . Morel . Digital Design . OPTIMA . Stinger . Dynamat
Previous VL Install - Current Lexus IS300 Install
#5 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 12 February 2008 - 08:39 AM
my bad.
from the same tech pages at the ID site anyway.
give this a try
as I pointed out, build yourself a sealed box. I dont think you'll miss the extra output from a ported box with that amount of power on tap. also, couldnt find specs of your amp either.
sorry :)
Edited by VIP318, 12 February 2008 - 09:10 AM.
Quote
#6 Louie
    3kW Power House
  • 5,849 posts
Posted 12 February 2008 - 08:49 AM
The dpx1000.2 you have is actually 1000rms@2ohms from looking on the net. Which is actually lucky for you, seeing how you chose the Dual 4ohm version of the IDmax, not the Dual2ohm which would be needed to achieve the power at 4ohms. Whether you realised this or it was just lucky, but your first post it indicates you didn't realise it, perhaps you did?
'06 Subaru Impreza
Source: Alpine CDA-9855R
Speakers: Dynaudio 242GT
Sub: Treo SSi-10.44
Amplification: Alpine PDX 4.150/1.1000
Trusted Buyers/Sellers: Pulse-R, Pyroay, Riley, jamer, brown202, Roo, dasherhalo, ch0c0, philz, vs380kw, Pacman, hardyards, spiderman, SPLcamry, shaky, GTI-18T, Ash W126
#7 s4turn
  • 361 posts
  • State:Other
Posted 28 February 2008 - 08:50 PM
small box .6
normal .9
I have an idmax10 d4...
mines running in a sealed box .9 cu ft
sounds great, very loud, and very nice sounding sub.
I had mine running off 500-600 w rms, sounded nice
then got a new amp, now running at 1200-1400 w rms, and its amazing, it really comes to life :)
Boston ---> Alpine ---> Scan-Speak
