Tutorial - How to make a LED Switch
16 replies to this topic
#1 peaandham
    I'm John Wayne Pilgrims.
  • 4,077 posts
Posted 19 November 2008 - 09:17 PM
Disregard the method i used was probally unsafe with cutting the plugs and what not.
Edited by peaandham, 07 August 2010 - 04:38 PM.
1st Place in SA's first SQ Comp, Intermediate Class.
1st Place in SA's First 2011 Comp, Intermediate Class
Sales Assistant for Solver/Wattyl Paints and Granosite Texture Coatings.
Inquires Welcome.
#2 TheyDontWantMusic
    1500 - 3000w RMS
  • 2,075 posts
Posted 20 November 2008 - 06:21 AM
this post is near useless without at least a drawing of what you're talking about.
I'm not even sure what you've typed makes sense, and if it does, its pretty much impossible to follow anyway.
oh, and if you're switching an LED, you're going to need a resistor in there... somewhere...
Edited by TheyDontWantMusic, 20 November 2008 - 06:23 AM.
#3 sean
    MetalManiac
  • 2,510 posts
  • Interests:Electronics, Audio, Metalwork
Posted 20 November 2008 - 12:36 PM
I would update to rewrite some of what has been written using the correct terminology :) Also I would solder and heatshrink my wire junctions rather than use those crimp on plastic joiners. The LEDs that he's using (or neons) already have the resistor built into the unit. Best way to find out which polarity the bare wires of the neons go to is to open up the lighter casing (if applicable) and see which terminal they end up at - positive is the fused terminal.
Black Alfa Romeo 164 Q: Denon DCT-Z1, Zapco 1000.1,
Sinfoni 90.2 (2x), Sinfoni 45.2x, Scanspeak AirCirc tweeters,
Focal Be 3W2 Midrange, Focal Be 6W2 Midbass,(2x) PHD AF10W subwoofers
______________________________________Trusted members:_________________________________
___muzzy66, zion187reigneth, Darkness_GR, TRD1JeeZy, 1point21gigawatts, DrBoom, NowHearThis,___
___Chemhaz, Charger, broadz, ~thematt~, keepitreal07, philz, Pulse-R, blanketman, TEGBOY, Damo95,___
_____Pacman, FaBzZz72, devolutionary , The Toad, shaky, MattVIP, Blackfox, Brycestro, KARAFLA_____
__268669, GTi-FTW, fury, Stone, stupidfingers, Tiger, brown202, burgsy, brady123, Morpho, Mr. Drifter____
#4 TheyDontWantMusic
    1500 - 3000w RMS
  • 2,075 posts
Posted 20 November 2008 - 04:44 PM
seeing as neons and leds are completely different things, I think the title should be corrected.
#5 peaandham
  • 4,077 posts
Posted 20 November 2008 - 10:39 PM
Tried to clear thing up with a diagram ! See above
Inquires Welcome.
#6 {Chips}
    Needs moar loud!
  • 4,585 posts
Posted 20 November 2008 - 10:45 PM
It is also probably a smart idea to hook things like neons and stuff up using a relay. other wise people might go crazy with them, hook to many up, and start popping fuses.
Car: '00 Subaru Forester
HU: Alpine CDA-9811
Front Stage: JBL C608GTi MkII
Front Stage Amp: 2x JBL P180.2
Sub Amp: 2x JBL BPx 2200.1
Sub: 2x Treo Engineering SSX 12.22
Powered by Odyssey Batteries
147.8 dB
Cide, on 12 February 2010 - 03:37 PM, said:
OMG :shok: i didn't even notice the adams apple the first time...
#7 TheyDontWantMusic
    1500 - 3000w RMS
  • 2,075 posts
Posted 21 November 2008 - 04:25 AM
you're not meant to connect ground to the fuse.
#8 kingswoodproaudio
  • 41 posts
Posted 21 November 2008 - 01:58 PM
NO ur wrong, the light bars are designed to run fron a cigarette lighter, the plug on the end does not have resistors in them, and its not hard to follow, simple cut the plug off and wire into some 12v power source in your car, simple, i mean if u can install a stereo speaker then u can do this as its the same level of work
Edited by kingswoodproaudio, 21 November 2008 - 02:00 PM.
76' HX Kingswood
(Old Gear Now dunno models)
Clarion Head Unit MP3 4xRCA $400ish in 05
Clarion Front Splits $350ish in 05
Pioneer 6" TS-A1681S rears
1x or 2x ???? 15" or 12" SUB (306c's donated 2 lancer)
Clarion 4 way 400w amp for speakers
Avalanche 800w 4ohm at 2ohm for subs
01' CE2 Lancer 4 GLXi
Kenwood MP5110U
RF Power T162S's front
RF Power T162S's rear
4x Pioneer TS-W306C 12"
RF Punch P1000-1bd 1200wrms mono
RF Power T600-4 Speaker Amp 120wrms x4
#9 Neon
  • 455 posts
Posted 21 November 2008 - 03:52 PM
actually some neon/LED's do have resistors in the cigarette lighter plug. so it would be best to check first before you go chopping off the plug
Alpine\\\Jaycar\\\Soundstream\\\Digital Designs
Old car
Camry
Current car
XT Forester
#10 TheyDontWantMusic
    1500 - 3000w RMS
  • 2,075 posts
Posted 21 November 2008 - 05:49 PM
some neons have the powersupply for them in the cigarette lighter plug, so if you cut that off, they don't work :P
also, the title doesn't say "led strips designed for car use"
it says LED's
#11 icacha
    Resident wanna be comedian AKA George
  • 5,362 posts
Posted 21 November 2008 - 06:55 PM
after skipping through i have one question, does anyone know why this thread has so many people arguing over bloody lights and how to wire them up?
i didn't think it was that hard to connect lights to a switch, you can bypass all the BS and connect the ground of the lights to your door switch and the power to constant via a fuse and the lights will turn on when the door is open and off when you close the door.
argue over that simple solution to a switch that you don't need to have :rofl:
Q: How do you know if you're too drunk to drive? A: You swerve to miss a tree then realise it's the air freshener hanging from the rear view mirror.
Albert Einstein: (you think he was thinking about the I.C.E. industry when he said the following?)
-We can't solve problems by using the same kind of thinking we used when we created them.
-Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe.
-Insanity: doing the same thing over and over again and expecting different results.
#12 FL0SSIN
  • 472 posts
Posted 21 November 2008 - 08:43 PM
cos its awesome to have led's and neon's going when your driving, aspecially at night cos everything reflects off the glass on the inside and ya cant see crap!
team no audio in the car cos im a sh*t bloke
#13 Braiden Michetti
    0 - 25w RMS
  • 14 posts
  • Interests:Cars | Audio / Lighting | Guitar | Games | Women
Posted 09 February 2009 - 05:49 PM
Neons / LED strips draw SFA anyway. 1 milliamp or something. I think you would struggle to do fuses. Even so, if you did pop a fuse, then you'd know it were time for a relay (assuming all other relevant troubleshooting had been done prior).
94 Falcon GLi Classic
All electronics, audio, and visual by bmICE
#14 MrMally
  • 576 posts
Posted 10 February 2009 - 01:17 PM
just put it into your interior light circut.
splice into a intereo light switch wire, and use that as an earth.
RIGHT HAND OF "TEAM OF ONE"
#15 phunkdust
  • 128 posts
Posted 17 April 2009 - 12:53 PM
I got two lengths of self-adhesive SMD led strips and put them in the footwells, wired up to the internal lighting circuit. They'll dim nicely with the rheostat so for late night highway or country driving I can dim the whole lot right down for better visibility. They're red to match my dash and don't really affect my night vision anyway. They're designed to run from 12V and they're a neat little alternative to neons or LED tubes, just cut to length, peel and stick anywhere.
...car Mazda Astina "The Shopping Trolley"
...sound by Alpine, Digital Designs, Audiocontrol, Dynamic Control
...wishlist Boston Acoustics Pro60SE, Digital Designs DD1515
...installation by Stylyn
