Technical: System Noise
Posted 25 November 2008 - 02:36 PM
Whether or not you can hear it, and whether or not you like it, there will be some noise in your system.
There is a bit of discussion in the SQ forums at the moment about what is system noise, and how should it be measured or tested.
I'd like to present my thoughts on the source of system noise; how to identify it, and how to test it.
System noise is that feint "shhhh" sound that you can hear in the background while music is playing, and sometimes when there's no music.
System noise is not recorded as part of the music, it is generated in the playback system, and is presented to you along with the music.
What causes system noise? Almost every part of your system.
Active components such as power supplies, amplifiers, oscillators, processors, DACs.. Any 'active' component in the system will contribute to the level of noise in your system.
The history of "removing" system noise from car audio started many years ago, with some people going to great lengths to make the noise in their system inaudible.
In modern Car Audio products, most are fitted with a 'noise gate' which is like a switch - when the level of the sound on the CD drops below a certain threshold, the gate closes; stopping any sound from getting out of your CD player.
The most common form of noise gate in car audio is called "Zero Bit Mute" and is a hardware function of the DAC circuit. It tells the output stage "There is no audio data output". The Zero Bit Mute signal is fed from the DAC to the output section, to some switching circuit, and effectively shorts-circuits the outputs, preventing any signal from getting to the amplifier.
This Zero Bit Mute behaviour results in most, if not all, system noise being prevented from reaching the speakers. Good so far, except in the case of a recent discussion which resulted in the outcome of some tests being highly skewed by the use of the wrong test track to determine system noise.
There are two test tracks on the Sheffield Lab "My Disc/A2TB Test Disc" (also known as Autosound 2000 CD103) which can be used for measuring System Noise.
Track number 41 on "My Disc" is a Zero Bit track - it is designed to activate the Zero Bit Mute circuit in the CD Player (or DAC), and should result in no 'audible' sound being output from the system. There are many test discs which have a Zero Bit track, and this is the common method across the entire industry for determining system noise. The liner notes for track 41 state " This track can be used for evaluating the noise floor of components or a system".
Track number 42 on the same disc is a "High Bit" track. The High Bit track, because its sample values are not all zero, will open the mute gate and allow us to hear the 'true' system noise, although it will introduce a small amount of noise itself. This means that track 42, although theoretically silent, actually will cause a small amount of noise in a high resolution system which may otherwise have none. This really exposes the internals of the CD player to scrutiny for which it was not designed, and any noise source - as described above - will be bared for all to see (or hear, actually)! The liner notes for track 42 say this track is "Useful only with the proper test equipment".
What follows is a technical explanation of the differences between the two tracks.
What is the difference between track 41 and 42?
Music on a CD is recorded in LPCM format, with 2 channel 16bit resolution and 44.1kHz sample rate.
LPCM is a 2's complement signed integer format, which means if the first bit (MSB) is a 0, then the sample value is positive. It the MSB is a 1, then the sample is a negative number. We know audio signals consist of positive and negative values, to represent compression and rarefaction of air pressure - sound.
0000 0000 0000 0000 (16 bits all '0') represents digtial 0. The Zero Bit track consists of the entire track, with every sample value set to this 0 value (0000 hex)
0111 1111 1111 1111 is maximum output value, the leading zero tells the DAC that this is a positive number. (7FFF hex)
1000000000000000 is minumum output, the 1 at the beginning is for negative number, and 2's complement means we invert all the other bits, then add 1 to get the sample magnitude. (-8000 hex)
the High Bit track (track 42) contains alternating samples at 1111 1111 1111 1111 (FFFF hex) and 0000 0000 0000 0000 (0000 hex). This corresponds to sample values of -1 and 0. The amplitude step from 0 to -1 is very small (0.03dB), and the sample rate makes the audio frequency 22.05kHz. In this case there should still be no audio; just a very small (-96dB) signal which is well below a normal reproduced output range. And yet, not zero.
http://www.aes.org
TEAM Floor-Pods
Posted 25 November 2008 - 02:56 PM
I'm not trying to wind you up, i'm interested in this as well as I'm fairly sure my system has noise using that track.
cheers!
Quote
Posted 25 November 2008 - 03:04 PM
1. turn down the amp gains
2. modify the components and/or design of your amps, source(Cd Player), processor (if any), etc. to reduce their inherent noise.
http://www.aes.org
TEAM Floor-Pods
Posted 25 November 2008 - 05:03 PM
Posted 25 November 2008 - 05:37 PM
Luke
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
Posted 25 November 2008 - 08:18 PM
Expert class may be using track 42 for the next season - depending on the outcome of current discussions.
Edit -
After looking over the scoring of some 'other' SQ formats, noise is measured using the equivalent of track 41 and 42.
Edited by Pulse-R, 25 November 2008 - 08:22 PM.
http://www.aes.org
TEAM Floor-Pods
#7
Posted 26 November 2008 - 04:02 PM
#8
Posted 26 November 2008 - 04:16 PM
http://www.aes.org
TEAM Floor-Pods
#9
Posted 26 November 2008 - 04:31 PM
i was asking if a competitor had problems with noise on track 42 there could be a work around where they could set their amps to 0 gain and set levels via headunit or processor instead.
#10
Posted 26 November 2008 - 07:59 PM
jas thats how i get around noise on my disc - by turning my gains down
#11
Posted 27 November 2008 - 11:58 AM
If the noise source is the player, then turning the gains up in that source will have the same issue - just need a quieter source, or mod the one you have.
there is actually another way to eliminate noise from a 'non-zero' track, to use a digital noise gate which is set to ignore low-bit noise. you lose a little in dynamic range ( 1 dB or so) but then there's no noise again, same as a zero bit.
this won't work so well if the noise is entering after the noise gate, such as amp noise, or alternator whine.
guess we'll see soon enough.
http://www.aes.org
TEAM Floor-Pods
#12
Posted 27 November 2008 - 12:35 PM
but if as you say the source has a high noise floor then lowering the amps to 0 gain will have to help.
#13
Posted 28 April 2009 - 04:14 AM
MEASQ co-founder
#14
Posted 28 April 2009 - 06:18 PM
As it turns out, a Zero-bit track is used for noise testing in MEASQ in all classes for 2009.
http://www.aes.org
TEAM Floor-Pods
#15
Posted 26 May 2009 - 10:47 PM
