JL Audio - New amplifiers
17 replies to this topic
#1 Pulse-R
    Digital is only on or off
  • 11,176 posts
Posted 19 January 2009 - 08:18 PM
Well, it's been a while coming, but I finally managed to get my hands on some of JL Audio's latest amplifier offerings.
While not strictly a 'new' product, they are the latest to come to Oz from the design labs
This review of the 4- channel HD600/4 is going to be in two parts
- now, the specs, pics and first impressions.
- next, listening...
Specs (from JL Audio Web Site): http://www.jlaudio.com/
Quote
Description: Class D Four-Channel Full-Range Amplifier
Patented Technology: Single Cycle Control™ (U.S. Patent #6,084,450*)
Differential-Balanced Input Topology: 2 pairs of inputs
On-board Crossover: State-variable, 12 dB/octave Butterworth or 24 dB/octave Linkwitz-Riley, Low-Pass or High-Pass for each pair of channels
Speaker output connections: Accept up to 12 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Rated Power (4 Channel Mode): 150 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (Bridged to 2 Channel): 300 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm per ch.
S/N Ratio: >110 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 6 Hz - 30 kHz (+0, -1dB)
Damping Factor: >300 @ 4 ohm per ch. / 50 Hz : >150 @ 2 ohm per ch. / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 10.74 in. x 8.29 in. x 1.93 in. : 273 mm x 211 mm x 49 mm (Width Measurement Includes Plugs)
unlike some 'other' brand full-range class D amplifiers (which are rated at 1% distortion), these power ratings are at 0.03% distortion
The signal-to noise is 110dB below rated power.. hmmm, we'll hear more about that later..
Price is currently RRP $1,199.
The distributor in Australia is Custom Car Sound and can be purchased through you local car audio specialist (as listed on the Custom Car Sound web site), or JB Hifi.
There are no officially supported online retailers for JL Audio in Australia.
on to the pics...
first look - the packaging
Attached File  DSC02169_2.jpg   64.46K   23 downloads
Box looks nice, inside is what you'd expect (the amp and a book and packaging), plus some extras.
Attached File  DSC02170_2.jpg   68.85K   17 downloads
Here we have (clockwise from top left) the allen key set (3 sizes), The power and speaker terminals, The feet and the feet's attaching screws.
Attached File  DSC02175_2.jpg   56.92K   21 downloads
Allen keys:
The smallest is for the speaker terminals
The middle one is for power wiring and to remove the control panel cover
The large one is for attaching the feet, or stacking kit (up to 3 can be stacked with the optional kits).
Power and speaker terminals:
I was a bit concerned here, JL have opted to use removable plugs for the main wiring points. This is not necessarily a bad thing, but only time will tell if the plugs are reliable.
Convenient - yes indeed; install the amp without risking the wires being bent over, or fraying as you push the strands into the hole.
No more risk of putting the screwdriver across the top of your shiny new amplifier.
Remove the amp without unscrewing (and fraying) all those pesky copper strands. Although why you'd want to remove the amp - who knows, maybe to upgrade later (more on that too).
The only negative here - with the power terminals, the clamp screws are quite large, and the allen key quite small - there is a risk of damaging the terminals or the allen key.
Also, you can't get to the screws while the plug is in the amp - the terminal must be disconnected (pulled out) from the amp to get at the allen key holes (or any 'live' parts for that matter) - Good idea I guess.
Feet and Screws:
The metal (cast aluminium) feet are coated with the same stuff as the heatsinks, and screw in from behind to allow surface mounting or flush mounting of the amplifier.
If you don't want to use the feet, the amp can be screwed directly to a board or bracket, for that 'floating in mid-air', or 'just sitting there' appearance.
On to the looks of the amp.
Attached File  DSC02171_2.jpg   76.98K   17 downloads
These amps are tiny! as you can see, it almost hides completely behind this CD cover.
don't be completely fooled by the size - they still weigh about as much as a house brick.
Solidly built, no loose parts inside, lets look at the connectors:
Attached File  DSC02174_2.jpg   107.49K   12 downloads
Here we have the power socket (left), the RCA inputs and outputs (middle), the remote Level controller (right of centre) and the speaker output sockets (right).
other side - sneaky cover panel.
Attached File  DSC02172_2.jpg   111.37K   14 downloads
On the left is the power/status light, on the right is the allen key screw
panel removed using supplied allen key
Attached File  DSC02176_2.jpg   84.99K   13 downloads
The switches allow all high/low pass filter adjustments, as well as 2- or 4-channel operation.
You can select wether the bass controller operates only the rear, or all 4 channels.. interesting ideas maybe?
The pre-outs (as seen in other pic) can be assigned to front, or summed F+R output.
There is no internal fuse in the JL amplifiers, and for this model, they recommend a fuse rating of 50A prior to the amplifier.
Overall, not a 100% quality build - there was evidence of 'touch-ups' on the mounting holes and feet, like the factory just texta over any bits of missing paint in the crevasses... no big deal, but might be important to some. a light rub with a cloth restored the matte appearance just fine. Also the JL Logo on the front isn't firmly attached - I noticed this one was a bit crooked, and was able to straighten it up with my finger. Maybe a better glue there?
Next... the hookup, and listening... stay tuned.
Edited by Pulse-R, 20 January 2009 - 10:46 PM.
http://www.aes.org
TEAM Floor-Pods
#2 shiny_car
    Posts too much
  • Admin
  • 40,179 posts
Posted 20 January 2009 - 07:02 AM
i love how these are so small. rather cool. :)
are they 'stackable' like the alpine PDX series?
the 'plugs' seem an ok idea - nothing really new there i guess, as some old skool amps used them (eg: soundstream) - and of course, alpine PDX have the same concept. but the advantages are pretty minimal, and the biggest issues are: losing them (and having to replace), and buying secondhand where the unsuspecting buyer doesn't realise they could be missing.
perhaps lack of good thought, is the requirement for 3 different size Allen keys?! have they not heard of KISS! '1 size fits all' would be ideal, 2 is acceptable and common amongst many amps, but 3?! perhaps do as audison do, and supply a funky multi-fit tool with different size endings in the one unit.
but at the end of the day, amps are 'set and forget', so you can look past these things...so long as they perform well!
nice write-up. will you post pics of the 'guts'?
#3 fuddbutter
    Needs to Harden the f*** up!
  • 10,773 posts
Posted 20 January 2009 - 08:59 AM
Quote
noooo!! next is open em up and show us the guts :D
QUOTE (RMA @ Feb 6 2010, 01:22 AM) My only regrets are:
www.fuddbutter.com
#4 Damo95
    Team Tennent
  • 7,178 posts
  • Interests:Car audio & Architecture
Posted 20 January 2009 - 09:24 AM
i would have thought they'd use the largest allen key possible for the power cables, which i assume can accept 4 gauge?
looks nice...
and yes, they are stackable.. but require spacers which are purchased separately?
Power by: Phoenix Gold
#5 jas
    1500 - 3000w RMS
  • 2,606 posts
Posted 20 January 2009 - 09:45 AM
yes the Hd amps are stackable but its an extra kit you have to buy :(
HD Stack Kit #16231
$44.95 RRP USD
From the pictures the HDs have a very similar layout to the 4.150 PDX i use to own.
I love the layout too. RCAs, power and speaker inputs are on one end and the x-overs, gains, other switches are on the opposite end. Very neat very simple and easy to use.
The PDX also is designed to be stacked at no extra cost and more than two can be stack together.
Edited by jas, 20 January 2009 - 12:58 PM.
#6 2LOUD2OLD
    1500 - 3000w RMS
  • 2,648 posts
  • State:ACT
Posted 20 January 2009 - 04:29 PM
hmm nothing to get excited abut thus far i guess we just need to wait for the writeup on the sound.
a bit dodgy that you have to buy seperate hardware to stack them, but oh well, i am sure people will just make their own versions
Alpine 9887 / Alpine PXA-H800 / Alpine RUX-C800 / PPI P900.4 x2 / e-audio 1000D
Scanspeak R2004-602000 / Scanspeak 10F / CSS Trio8 / AE IB15A x2
2009 Intermediate ACT State Champion
2010 Show ACT State Champion
2010 Advanced 1
ACT State Champion
2010 Advanced 1 National Champion
2011 Advanced ACT State Champion
2011 Advanced National Champion (shared)
Trusted Sellers: 37WREFGLi, brown202, niteflyer, fury, DJOLYB, muzzy66, aazn, UnsettledHawk, RHI-SEE, 268669
Trusted Buyers: S3X1T1M3, hecate, Streatz, mmingin, ktime70, Mr_Bob, peaandham, hsvmonarogen3, Cleutin, ryzaa, MR M.R., abuyahoo, V6VITO
#7 Pulse-R
  • 11,176 posts
Posted 20 January 2009 - 08:26 PM
The HD amps are all stackable - the kits can be 2-stack or 3-stack *(3-stack has longer screws, and an extra set of spacers)
as for the terminal screws - ALL the terminals use the same (smallest) 2mm allen key.
The other thing I learned (upon reading the manual last night/this morning) is that the Remote Level Control (not Bass Control) can be paralleled from one knob, to many amplifiers - just using 'telephone' type 6-pin (6P6C) adapters... more and more interesting - no need for that pesky AudioControl MVC unit, or Alpine Processor to do the volume control *big grin*.
I think the two HD600/4 and the (soon to be released) HD1200/1 might end up in the Pulsar one day ;)
http://www.aes.org
TEAM Floor-Pods
#8 Ben
  • 524 posts
  • Interests:Birth control, burning things, squishing bugs
Posted 20 January 2009 - 08:40 PM
Yummy!!! I'm very interested in this amp, and I may be getting one in the next few days (through JB HiFi)...
Let us know how it sounds! I'm hoping it isn't as flat and as lifeless as the pdx amp turned out to be (IMO anyways).
Also, take note and tell us how hot the thing gets when it's being pushed a bit...
If the results are good, I'll grab one of these babies fo sure!!!!!!!!! :rocker:
#9 Pulse-R
  • 11,176 posts
Posted 20 January 2009 - 10:46 PM
first post updated with stacking options, and update on allen key sizes.
http://www.aes.org
TEAM Floor-Pods
#10 jLAUdio
  • 425 posts
Posted 23 January 2009 - 08:06 PM
here is a quick photo of the guts... kinda in a rush to go out for dinner, but i will try open it up more later, unless pulse gets one up (sorry for hi jacking your thread :D)
ive had one of these for about 2 months now, and still havent gotten round to putting it in.
600/4 btw
Head Unit: Alpine IVA-502E
Processor: Alpine PXA-H701
Front Stage: JL Audio ZR650-CSi
Rear Stage: JL Audio ZR650-CSi
Subwoofer: JL Audio 12w3v3
Front Amplifier: JL Audio 600/4 HD 4-Channel Amp (Bi-amped)
Rear Amplifier: JL Audio A4300 4-Channel Amp (Bridged)
Sub Amplifier: JL Audio A1400 Mono-block
Miscellaneous Set-up: Kicker 0 Gauge Kit, Kicker 4 Gauge Kit, Stinger Terminals and Distribution Blocks, Dynamat Extreme
#11 Damo95
    Team Tennent
  • 7,178 posts
Posted 30 January 2009 - 08:31 AM
any updates simon?
heard some pretty distressing news friday night about these... wonder if you've heard anything back?
#12 Crescendo
  • 46 posts
Posted 17 March 2009 - 07:48 PM
No further news guys???
Curious to find out the install/sound on one these amps.
SC.
#13 Crescendo
  • 46 posts
Posted 18 March 2009 - 04:59 PM
Damo95, on Jan 29 2009, 11:31 PM, said:
any updates simon?
No more news on this topic?
Has anyone else got one of these amps hooked up?? - like to find out how good it works.
Also, can someone upload the internal pics...
SC.
#14 Crescendo
  • 46 posts
Posted 24 March 2009 - 10:51 AM
No more news on this thread??
#15 maluko
  • 85 posts
Posted 01 August 2009 - 12:38 AM
Any news/updates on these amps? Am interested in them
