Isuzu dmax single cab SQ
24 replies to this topic
#1 037981
  • 71 posts
Posted 05 September 2009 - 09:48 PM
help me build a SQ system
This is what I already have
1 morel 6.5 2w limited edition
2 one jl 13TW5-3 sub
3 eclipse CD5030
CD RECEIVER
What I'm thinking about
1 eclipse mono block XA1200
2 second choice audison lrx 3.1k is it better to run a mono block and a two channel or will this do the trick
3 is it hard to make custom doors to fit morel 6.5 le
And if there is anything else that you think of
#2 037981
  • 71 posts
Posted 06 September 2009 - 10:48 AM
hi is anyone out there what about the vibe BlackBox Bass 1
#3 037981
  • 71 posts
Posted 06 September 2009 - 11:07 AM
#4 037981
  • 71 posts
Posted 06 September 2009 - 11:46 AM
help me please anyone
#5 eclipse_DYN
  • 278 posts
Posted 06 September 2009 - 08:04 PM
The Eclipse CD5030 is a fairly basic head unit. I believe it does have 3x preouts however so you should take advantage of this and run 2 seperate amplifiers. Having 2 seperate amps has a multitute of advantages, and infact there isnt many reasons (apart from budget or space confines) not to.
A Monoblock amplifier (such as that Eclipse XA1200) is specifically designed to drive subwoofers. A 2ch or 4ch would be better utilised drivers your Morel front stage. 4ch amps that would match that Eclipse aesthetically would be the XA4200 or EA4200.
Those amplifiers are ok, but for the money you could probably do better. Perhaps look at the JL Audio slash series, Audio System (my personal recomendation) or Digital Designs. These brand will be able to offer you a 4ch/2ch and matching monoblock for about the same price (except for JL Audio, they will set you back a few more bucks, but are great amps and get a great wrap on here)
Another option if your short on cash but are looking to do something right away, is to purchase a single 4ch amp. Use the front 2 channels to drive your front speakers, and bridge the rear for your subs. Then, further down the track, you can purchase a monoblock for your sub/s and either bridge the 4ch amp into 2 for your front stage, or run some rear fill. Going down this route gives you more options for the future.
Im not very familiar with the Morel range of speakers, but those you have described sound like the Tempo 6.5" 2-ways. Im also unfamiliar with the vehicle so I cant comment on installation sorry...
Due to the nature of your query(and your inexperience) you may be better off posting something in the Beginners Section. The SQ section typically addresses advanced aspects of Sound Quality and requires some experience and technical understanding.
Hope this helps
H/U - Alpine 9861e
Processor - Alpine H701
Front Stage - Dynaudio System 362
Amp - Tru Tech S44
Amp - Eclipse PA5422
Subwoofer - Eclipse 15" Aluminium
Amp - Eclipse DA7122
#6 037981
  • 71 posts
Posted 07 September 2009 - 05:44 PM
eclipse_DYN u totally got me wrong
This is what I have
MOREL Elate 6.5 Limited Edition 2ways not Tempo 6.5" 2-ways
Eclipse CD5030
jl Subwoofers 13TW5-3 shallow mount
What I have to get
Monoblock Amplifier for the jl Subwoofers
2-Channel Amplifier something like this Rockford Fosgate Power T600-2
* Power Series Compact 2-Channel Amplifier
* RMS Power Output:
o 4 ohms: 200 watts x 2 channels
o 2 ohms: 300 watts x 2 channels
o Bridged, 4 ohms: 600 watts x 1 channels
* CEA-2006 compliant
* Dynamic Thermal Management cooling system
* Differential Input circuitry eliminates hum
* Variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
* Variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
* Optional remote bass/treble boost
* Class AB amplifier design
* MOSFET power and output stages
* Preamp inputs and outputs
* 4-gauge power and ground leads and a 150-amp fuse recommended — wiring and hardware not included with amplifier
* No on-board fuses — when installing multiple amps in a system, an additional 150-amp in-line fuse between the distribution block and the amplifier is recommended
* Frequency Response: 20 Hz - 20 kHz
* Dimensions: 9-5/8"L x 13-11/16"W x 2-3/16"H
* 1-year SonicElectronix.com warranty
#7 eclipse_DYN
  • 278 posts
Posted 07 September 2009 - 07:28 PM
oooooooo ok then nice speakers. In that case you'll want to consider a high end amp to get the most out of them. Whats your budget??
H/U - Alpine 9861e
Amp - Tru Tech S44
#8 037981
  • 71 posts
Posted 07 September 2009 - 07:44 PM
100 dollar lol
Edited by 37981, 07 September 2009 - 07:50 PM.
#9 037981
  • 71 posts
Posted 07 September 2009 - 07:48 PM
1500
2-Channel Amplifier and 1 channels
#10 037981
  • 71 posts
Posted 08 September 2009 - 05:44 PM
What about this
US Amps AX TU4360C
http://usamps.com/ax_amps.html
#11 037981
  • 71 posts
Posted 08 September 2009 - 08:08 PM
How much is too much can they take 300 PER CHANNEL form a TUBE AMPLIFIER :shok:
Us amps AX-TU 1000
Edited by 37981, 08 September 2009 - 08:23 PM.
#12 037981
  • 71 posts
Posted 08 September 2009 - 08:26 PM
Us amps AX-TU 1000
Edited by 37981, 08 September 2009 - 08:43 PM.
#13 037981
  • 71 posts
Posted 26 September 2009 - 08:03 PM
i was just thinking about this set up ok
i have my MOREL Elate 6 Limited Edition and I was living about adding 2 3 inch full range drivers and 2 4" sub
these 3 inch supposed to be one of the best 3 inch full range drivers
check it out
http://www.parts-express.com/pe/pshowdetl....amp;ctab=1#Tabs
I reckon it should sound good
Tell me what you think
thank you
#14 037981
  • 71 posts
Posted 27 September 2009 - 10:48 AM
#15 br85
  • 1,323 posts
Posted 27 September 2009 - 10:56 AM
If this thread is moved to the beginner's section, you'll probably get more replies.
We don't actually know what your goals are. "Sound good" is not a goal we can work with.
Do you want:
*Loud with good sound?
*Very loud with reasonable good sound?
*Good sound at lower volumes but not much capability for loudness?
*A stock appearance?
*To spend a little/moderate amount/lot to get to your goal?
We can't help you with what you've provided.
