Macbook - Power? Optical > RCA?
Posted 18 September 2009 - 01:47 AM
Just scored a macbook (core2 duo 2ghz) with no screen, CD drive, battery etc (stripped). Chucking in the power cable, it still works fine. Plan is to make it into a teency box and have a neat little carPC.
The basic idea is to use the macbook, its integrated video and optical audio, Lilliput EBY701 (use one of the two USB ports for the touchscreen), add a USB GPS dongle in the second USB port. The macbook MIGHT still have its integrated bluetooth functioning, also.
The macbooks' normal charger claims 16.5V @ 4.6A (max) - How am I best set to achieve this? I'd love to run an M2-ATX, as it has the startup/shutdown timers that I desire. Is there a way to bridge rails to get close to my 16.5V, or will it only result in the smell of burning silicone?
Secondly, the macbook only has one 3.5mm stereo headphone jack, which obviously won't cut the mustard for running a 4.1 setup. Interestingly though, the 3.5mm jack also includes an optical connection.. Does anybody know of a simple, cheap optical > 5.1ch RCA converter? I see optical > 2ch RCA converters going cheap, but thats' pretty pointless!
I would rather NOT use a USB sound card, as I only have 2 USB ports, and would prefer to keep my installation size to a minimum. I will be running windows however, so if no optical decoders are available, I can run any old USB device as a last resort - however I would also then need to add in a USB hub :\
I appreciate any feedback you can muster up!
Cheers,
-Luke
Posted 18 September 2009 - 01:54 AM
Started pulling apart remaining bits on the motherboard - Found the bluetooth unit+antenna.
Posted 18 September 2009 - 09:05 AM
2008 Corolla - IDA-X100 - 2x Cadence DCA2500 - 4x Cadence DCW15 - 3 Optima D34M - PB-149.1 - DECEASED
1999 Merc C180 - CDA-9887 - AudioSystem F6-380 - Alpine Type X Pro Tweets - Infinity Kappa Perfect 6" Mids - Alpine MRD-M605 - Alpine SBR-S123V - Fullriver SPV70 - FOR SALE w/o stereo.
Posted 18 September 2009 - 11:59 AM
http://www.griffinte...oducts/firewave
Discontinued now, but could be the thing. Apple's Audio/Midi utility is a good one to get familiar with in times like this for channel setup.
Also worth looking into different media apps, a couple to look at are Boxee, Plex, XBMC, or just use the built-in front row.
The magsafe connector might make life difficult. Perhaps look into adapting the empower airline connector, as it's designed for about 15v on planes. It doesn't charge the battery, but that's not an issue here.
Edited by speaksgeek, 18 September 2009 - 08:33 PM.
Alpine 9887 + Peugeot steering wheel controls
Focal K2P front splits
PPI Art series 2x 75W Front amp
RF 10" Sub
Soundstream 400x1 @ 2ohm Sub amp
Posted 18 September 2009 - 12:05 PM
Posted 18 September 2009 - 03:06 PM
as for the USB, why not get a USB2 powered hub (powered from a ciggy lighter adapter) to run lots of devices.
http://www.aes.org
TEAM Floor-Pods
#7
Posted 18 September 2009 - 04:21 PM
Just found the 802.11n wireless card for the macbook, complete with the factory antenna that goes around the screen
#9
Posted 18 September 2009 - 08:43 PM
Although if you google enough, I'm sure it's out there.
RF 10" Sub
#10
Posted 18 September 2009 - 09:22 PM
#11
Posted 19 September 2009 - 04:08 PM
I mean for the macbook.
RF 10" Sub
#12
Posted 19 September 2009 - 04:47 PM
#13 Guest_Liquidity_*
Posted 21 September 2009 - 02:29 PM
#14
Posted 21 September 2009 - 02:38 PM
#15
Posted 21 September 2009 - 06:12 PM
Get a USB hub and an external soundcard that is Mac Compatible, or run it on windows and use what you like... you're wasting your time using the MacBooks onboard audio if you want SQ
Edited by 0restes, 21 September 2009 - 09:00 PM.
