getting power at 8 ohm....
#16
Posted 05 November 2009 - 05:32 PM
interesting... i think ill go the clarion anyway, i like the look, and four wont be too hard to hide, they are small....
Clarion HXD2
Crescendo Opus 8.6
Fi Audio Q 12"
JL Audio 300/4
JL Audio 500/1
#17
Posted 05 November 2009 - 05:39 PM
There are some decent midbass drivers that are 94-5 db efficient, which would give you more output.
#18
Posted 05 November 2009 - 05:42 PM
Ant
Previously:
SStealth
Antony
#19
Posted 05 November 2009 - 05:57 PM
the exclusives are the same, i traded off eficiency for super low distortion and and responce...
bit late now, i probably should have looked in the pro audio stuff, but i dont regret my decision... ill just power em up...
Clarion HXD2
Crescendo Opus 8.6
Fi Audio Q 12"
JL Audio 300/4
JL Audio 500/1
#20
Posted 05 November 2009 - 06:07 PM
Ant
Previously:
SStealth
Antony
#21
Posted 05 November 2009 - 06:14 PM
#22
Posted 05 November 2009 - 07:29 PM
Gonadman2, on Nov 5 2009, 06:14 PM, said:
No, the correct definition for a regulated power is the same output power across a large voltage range, and they should double power for every halving in load impedence, so 200w @ 4 ohm from 10.5v to 14.4v for example and 400w @ 2 ohm from 10.5v to 14.4v. The example you have given is something similar to the RIPS system JL uses which just manipulates rail voltage to control output power.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
#23
Posted 05 November 2009 - 09:14 PM
Would maximum rail voltage occur at 4 ohms, and therefore maximum power into 8 ohms would be exactly half?
#24
Posted 05 November 2009 - 09:22 PM
otherwise the HD 600/4 is 2x300RMS at 8 ohm - could be an option there maybe, or a couple of 450/4 - one for left @ 150x1 + 300x1 per amp @ 8 ohms...
and the 300/2 is 300x1 bridged at 8 ohms.
http://www.aes.org
TEAM Floor-Pods
#25
Posted 06 November 2009 - 10:39 AM
Bridge a 2x150 to each 8inch woofer giving 340wrms to each 8inch.
Bridged the 4x100 to each midrange to give 260wrms to each 4inch.
Run a single 2x150 for the tweeters giving 150wrms to each tweeter.
That power is spot on. The tweeters are more sensitive so you dont need as much power.
#26
Posted 06 November 2009 - 11:39 AM
