Tutorial: Cheap,easy tweeter pods
12 replies to this topic
#1 Matt VIP
    Got loud yet?.....nope...
  • 4,090 posts
  • State:ACT
Posted 13 December 2009 - 09:49 PM
Ok boys and girls, today we’re going to learn how to make the tweeter pod as described in Patrick Bateman’s thread “Improve your soundstage for $2”.
Please take the time to read the first page at the very least, as it describes the whole theory behind the build. Patrick describes the diffraction issue and its effect on soundstage realism far far better than I ever could.
http://www.diymobileaudio.com/forum/diy-mo...dstage-2-a.html
The Build:
As you’ll see, it will cost a little more than $2. Surprise surprise. However the results will be, as they say in the ad, priceless.
First of all, you’ll need every installer’s key tool: a decent beer. Today we’re drinking Hoegaarden, which is a very nice quality Belgian wheat beer. If you keep your costs down on the build, you too will be able to afford a better quality beer. Thanks to Crosspug for the beer. :drinks:
Attached File  IMG_1713.JPG   1.29MB   42 downloads
Equipment List
To buy:
• Packet of 10 polystyrene balls. http://shop.ebay.com.au/?_from=R40&_tr...-All-Categories
Cost $5.50 inc postage.
• Exterior PVA. I used Selleys Aquadhere, available from Bunnings. It's important to use the exterior stuff, as the normal stuff might just melt into a gluey puddle on your dash in the middle of summer. Boooo!
Attached File  IMG_1714__Large_.JPG   93.46K   22 downloads
o Cost $10
• 5 minute epoxy resin. Something like Araldite works well, I used the Bostick stuff cause it was cheaper. 2 packets will be plenty!
o Cost $7 per packet
• Flocking powder. I purchased mine from Carrols woodcraft supplies.
o Cost $18 delivered.
Total cost: About $40.
From home:
• Automotive body filler
• Sandpaper
• Drill and holesaw attachment
• Sieve
• Paintbrush
• Bamboo skewers
• Latex gloves
Determining the size of the polystyrene ball:
The equation used to work out how large the radius of the sphere needs to be is this:
Quote
required sphere radius in cm = 34029 / lowest frequency / 2 / pi
This equation uses 340.29 metres per second as the speed of sound. If you have another equation, feel free to use it, although it may not be as correct as the one above.
For my sphere, I chose 5kHz as my frequency, so:
Quote
34029 / 5000 / 2 / 3.14 = 1.08cms.
For 2khz (most people’s lowest cutoff frequency)
Quote
34029 / 2000 / 2 / 3.14 = 2.7cms.
Remember, this is for the radius, so the diameter will be……BING! Twice this, or in other words 54mm for 2kHz. In other words, your main issue will be finding a suitable sized polystyrene ball to suit your tweeter rather than worrying about the lowest diffracted frequency.
I chose a 65mm diameter ball for my Hybrid Audio L1v2’s. This was a perfect fit.
Fabrication.
Step 1: Covering the balls with epoxy.
• Mix up a decent amount of epoxy. Make sure it’s well mixed.
• Stick 3 skewers into the ball, fairly close together. This will act as your handle so you can get crap everywhere without getting it on your fingers.
• Using a spatula or a piece of cut up plastic (I cut up the thin flexible plastic from the epoxy packaging into rectangles), cover the ball in a thin layer of resin. Make sure there are no runs. Wear latex gloves for this bit.
• Put the skewers with the ball on top into an egg carton, and leave to dry for 12-24h.
Attached File  skewers.jpg   172.57K   20 downloads
• Sand off any runs and recoat.
• Now the ball should be fairly hard. If there are any runs, you will need to sand them down until it is nice and flat.
Step 2: Cutting the mounting hole
• Now you need to work out approximately where to cut the ball, depending on the size and shape of your tweeter. A few mm past the centre line is what I aimed for.
Attached File  IMG_1726__Large_.JPG   107.39K   20 downloads
• Now you need to cut the inner hole for the tweeter to sit in. I used a hole saw attachment just a bit bigger than the tweeter cut out.
Attached File  IMG_1727__Large_.JPG   168.16K   12 downloads
• Drill down enough for the tweeter to sit in, then scoop out the polystyrene with a blade or knife.
• Clean up the inside with a dremel sanding attachment or just don’t worry too much about it.
Attached File  IMG_1728__Large_.JPG   108.24K   9 downloads
• All you’re looking for at this stage is a clean fit with not too much movement.
• Once this is done, you can sand the face with a sanding block to get a perfectly flat surface.
Attached File  IMG_1729__Large_.JPG   87.4K   15 downloads
• Tape around the outside, and epoxy the face and inside.
• Once dry, use bog to get a nice flat face. The reason why we use epoxy first is that the bog won't stick to the polystyrene.
• Now you need to make sure that everything is sanded pretty nicely, and the whole thing looks ready to trim.
Mounting
Once ready to trim, you need to work out how the tweeter will attach to either the dash or the a-pillar. Crosspug uses a ball swivel mount on his pods, which give a completely adjustable and very sturdy mount. Props to Sydmonster for the build.
I got a bit fresh with mine 8), and made up some adjustable mounts which go over the wooden cowl on my dash. I used a t-nut on the inside of the pod which bites into the polystyrene, and a very short bolt. I drilled a second hole for the wires. See below for pics.
Another way is to use the method described here:
http://www.diymobileaudio.com/forum/diyma-...eeter-pods.html
which uses hollow threaded rod. This is great ‘cause you can run the tweeter wire up the inside of the rod. Nice.
Trimming
Trimming can be done in any number of ways. I suck the big one at trimming, so I went with the easiest option I could find – flocking. As always, the exterior of the pod must be as perfect as possible before trimming.
• Skewer the pod again very carefully to make a handle, as it’s easy to put the skewer through the back. You could also use a Stanley knife, but make sure it’s secure.
• Mix up PVA with about 2-4 teaspoons of black laser printer toner in a plastic cup. This should turn the PVA a very dark grey. You can pinch this out of the photocopier at work by taking the toner cartridge out when no one's looking, undoing the end and emptying some into a glass jar. Be careful cause it will go everywhere. This is good stuff because it is inert and mixes into the PVA very well.
• Paint the pva onto the pod until you have a light coat. If it’s too thick, it will run and you’ll be stuffed. Make sure the PVA totally covers the pod and the face. Take your time here.
• Put the flocking powder into the sieve and, over a box lined with clean newspaper, shake the flocking powder over the pod. Make sure you use plenty of flocking and cover every surface– it can always be collected after the pod is dry and reused.
• Leave to dry for AT LEAST 24 HOURS.
• Shake off the excess flocking, collect it and put it back in the bag.
• Profit!
Attached File  IMG_1623__Large_.JPG   85.94K   15 downloads
and just cause its a cool car...
Attached File  IMG_1637__Large_.JPG   115.29K   13 downloads
:D
Tips for the n00bs:
1. Don't use polyester resin to cover the polystyrene ball. It makes napalm. Waaay to 70's for what we want.
2. Don't use spraypaint on polystyrene.
Attached File  IMG_1730.JPG   147.23K   13 downloads
3. Don't use bog straight onto polystyrene. It sort of rips it up and makes it very hard to get a nice sphere. Plus it doesn't stick very well.
Attached File  IMG_1731.JPG   188.7K   4 downloads
4. Don't try and use modelling clay to make a teardrop shape. Usually it ends in fail.
Attached File  dome.jpg   155.37K   7 downloads
Attached File  IMG_1734.JPG   156.87K   10 downloads
5. Don't try and vinyl a sphere. Get a pro/shop to do it or just paint or flock it.
Attached File  IMG_1732.JPG   177.58K   12 downloads
6. Careful when using Araldite, as it sticks stuff together. Like your stanley knife.
BUT HOW DO THEY SOUND?!!
They sound fantastic. In my original pods, the sound was very raw and "in your face", or "hot", with a large amount of sibilance and harshness at around 5-10kHz (hard to tell without measurements). A combination of the pods themselves as well as tuning (phase, rather than EQ) and the ability to change their aiming has resulted in a much more relaxed, listenable sound. For the first time ever, I actually drove for 5 hours (on the way home from nationals) without dicking about with crossover slopes, phase, eq, time alignment, levels etc etc etc etc. For those of you with a high level processor like the hxd2 or similar, this is no mean feat.
I just simply listened to the music.
Anyway, these were my results. Feel free to post up anything of relevance, including a discussion about diffraction and any improvements that can be made. My next step will be to fill in the gap between the tweeter and the pod, and paint them. When I can be bothered.
:good:
Matt VIP
* I'd like to thank Patrick Bateman for posting this stuff up. Whilst he is not necessarily the final word on acoustics and physics of sound, he is someone who thinks about stuff, theorises, goes out and tests his hypotheses, and posts up his results. I am merely riding on coat tails here, or, as Newton said, standing on the shoulders of giants.
Edited by Matt VIP, 14 December 2009 - 10:08 AM.
Quote
The only excuse for passive crossovers is their low cost. Their behavior changes with the signal level dependent dynamics of the drivers. They block the power amplifier from taking maximum control over the voice coil motion. They are a waste of time, if accuracy of reproduction is the goal.
my vibe tastes like hedgehog slice
#2 wazzab4
    FORD FUN
  • 1,722 posts
  • State:ACT
Posted 13 December 2009 - 10:04 PM
Nice thread matty.
#3 ~Samuel~
    Team XS Audio
  • 5,312 posts
  • Interests:Music
Posted 14 December 2009 - 04:19 PM
wazzab4, on Dec 13 2009, 10:34 PM, said:
Nice thread matty.
Understatement :P
You have done an awesome job on those pods and a great job on putting this thread together, big props to you Matt
Sam
#4 claor
  • 1,475 posts
Posted 14 December 2009 - 05:45 PM
ooo kool :) nice job
#5 zion187reigneth
    General monkey
  • 3,096 posts
  • Interests:DIrt bikes,Drag racing,General monkey business
  • State:Other
Posted 16 December 2009 - 04:27 PM
Quote
any wine and cheese on the trip home :P
Edited by zion187reigneth, 16 December 2009 - 04:28 PM.
My history
no car sound at all.
#6 benny77
    0 - 25w RMS
  • 2 posts
  • State:Other
Posted 19 December 2009 - 12:39 PM
Hey man, your pods look great! Benny from DIYMA here, looking to finish my polystyrene ball tweeter pods. Stoopid question, what's "bog"?
thanks!
#7 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 19 December 2009 - 01:01 PM
bog is Australian colloquial dialect for "automotive body filler".
You mob call it bondo I think. :P
Quote
#8 TEGBOY
    TEGBOY
  • 6,458 posts
Posted 20 December 2009 - 03:35 PM
They do sound and look great Matty. I honestly didn't think you would have gotten such great results with using a foam ball, but how wrong was I?
Well done again bro!!
#9 TERRA Operative
  • 560 posts
Posted 20 December 2009 - 09:02 PM
Wooo, +1 for innovation. Simple and effective, I like it. :)
Apex'i, Bomex, Carbing, Clarion, Cusco, Defi, Dynaudio, HKS, Just Alloy Radiators, Royal Purple, Sard, Shift-I, Team Orange, Tom's, TRD, Tru Tech, Wilwood, Works Bell
Because the stickers aren't going on my car....
Tereno Empireo Rapidmova Reakcii Armeno
#10 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 21 December 2009 - 01:49 PM
:wub: thanks guys.
Anyone got any constructive criticism? Any ideas on how to improve on the design?
Quote
#11 Weekend Warrior
  • 33 posts
Posted 08 January 2010 - 05:56 PM
This is awesome!!! only problem being i can't find where to get Polystyrene balls from!! There is none listed on Ebay.
#12 zion187reigneth
    General monkey
  • 3,096 posts
  • State:Other
Posted 08 January 2010 - 07:54 PM
Matt VIP, on Dec 21 2009, 02:49 PM, said:
:wub: thanks guys.
I was looking at the pics matt and i have a pondering.
The design/shape of the ball and the subsequent effects thereof would change due to the surrounding window and window frame?.
If it is indeed fee sable that the ball shape can change the effects of the tweeter ,then it is highly possible that a newer modified design of the tweeter housing taking into account the surroundings could infact produce even greater benefits.
Just pondering
My history
#13 br85
  • 1,323 posts
Posted 11 January 2010 - 06:12 AM
Just pondering
Yup, and that is where waveguides come into their own. Like the opposite of a sphere, you end up with a concave instead of convex baffle, one which can be (not so easily, but achievable) moulded to your dash/windscreen/pillars without discontinuity.
