car pc for sound quality system
11 replies to this topic
#1 hugsdrugs
  • 126 posts
Posted 15 December 2009 - 01:02 AM
i'm working on a car pc. I've owned a lot of head units. including many alpines. was planning to get a pionner p99rs which runs about 115dB SNR with .0008 THD the price was about 2g's but would still be weak compared to a pc.
pc's are update able, and have more processing power then a head unit could. Also can watch cinema movies
i'm thinking of running a
*mini itx mother board these a small and if put into a case can be a small 7X7inch square
*mi-atx power supply can run from 6-24 volts and senses battery discharge will shut down if power hits 11volts.
* and any random double din touch screen
things i'm working on are...
* A possible power pack which stores power like a laptops ability to be portable, if i can't i'll scrap the thought in the mean time.
* a switch for a turn on lead.
i'll be taking a 12v power supply from the mini pc, and maybe putting on a resistor to lower the current to a cd player level. The pc will turn on first then i use the switch to turn on the amps
And lastly a important thing is crossovers. i'm not sure how i'm gonna these yet. i'll be using a 7.1 asus sound car so 6 channels for front stage and plus sub
the sound card will have rca outputs left and right like a normal head unit. i just hope to get everything ready and research prepared so i don't damage or overload the amps with the signal coming from the sound card.
for crossovers. i could maybe find a program knowing tweeters i need to be abit careful with programs. or i could build some kind of crossover/filter to connect to the rca before it reaches the amp. other options are a electronic crossover which might give the option of volume controll
#2 Pulse-R
    Digital is only on or off
  • 11,176 posts
Posted 15 December 2009 - 06:31 PM
If you can get an external processor (like H701 or BitOne) that works well as a crossover/eq/etc., and the controller for it does the volume.
as for processing, the CarPC options are many, but the performance is not SQ-oriented, nor very user-friendly.
as a transport, the PC is a good idea, and Carnetix make good power supplies.
http://www.aes.org
TEAM Floor-Pods
#3 hugsdrugs
  • 126 posts
Posted 15 December 2009 - 08:51 PM
how would this sound card do for a start?
http://www.asus.com....sEKBPr6ko9pFF2D
8 RCA outputs
low distortion
low noise
decent preout power
#4 Pulse-R
  • 11,176 posts
Posted 15 December 2009 - 09:28 PM
looks ok, then you need drivers to enable teh 3-way front+sub... that's the tricky bit.
if you can set the amplifier crossover for 1kHz HP, that will go a long way to protecting your tweeters, and not have too much interference of the actual crossover frequency (4kHz or so).
http://www.aes.org
TEAM Floor-Pods
#5 Pulse-R
  • 11,176 posts
Posted 15 December 2009 - 09:35 PM
Burr-Brown PCM1796 *4 - nice, same as HXD2
ASIO 2.0 Driver Support - need this for crossover filters such as VST, etc.
audio specs look good too.
only problem will be with the volume control, as it's done inside the PC, you lose SQ as the volume is decreased due to the digital information being lost... may not be too noticable, or it may be terrible depending on the rest of your system.
http://www.aes.org
TEAM Floor-Pods
#6 mr_jay_318i
    hmmmmmm....
  • 677 posts
Posted 15 December 2009 - 11:03 PM
it would be much better as trasport. decent board will have optical out for an outboard processor too.
but then i spose you still have to get a $1000+ processor. still realtime on somethin like a bitone would be awesome control.
Edited by mr_jay_318i, 15 December 2009 - 11:04 PM.
1990 BMW E30 318i
Pioneer DEX-P99RS, XDV-P650, CD-BTB200, CD-IB100II
Tweeters: Dynaudio Esotar2 110's
Mids: Dynaudio Esotar2 430's
Midbass: Dynaudio Esotec MW182's
2 X Arc Audio 4200SE
1 X Arc Audio 2300SE
2 X Arc Audio Black Series 12's
Stinger Connections, Custom RCA - RJ-45 Balanced Inputs, Optima D34, Python 990
Custom Car PC
TEAM PHATT
#7 Carnut
    0 - 25w RMS
  • 6 posts
  • State:Other
Posted 28 December 2009 - 07:04 AM
#8 Z2TT
  • 53 posts
Posted 30 December 2009 - 06:32 AM
Hi All.
I'm considering going the Car PC Route, since I have a double din. I mean since most Double din H/U's cost $2000+, why not get a car PC?
So I too am building a SQ Orientated System. I was wondering whether any Car PC's have decent inbuilt sound cards with good DAC's. Anybody aware of any?
Also i was wondering if there is a Car PC I can buy that has a PCI slot so i can just put a Xonar card in.
Third option like mentioned here to use an Outboard processor, Other than Alpine, what other processors is there that I can use that will be decent for an SQ System?
Interested in this Car PC Concept.
#9 eron
    0 - 25w RMS
  • 18 posts
Posted 03 January 2010 - 10:02 PM
I've no experience in car PC and little in car audio. However, I do know that there are portable DACs that give good SQ.
For example: http://www.head-fi.org/forums/f61/headamp-...o-price-413230/
This one connects via usb, but you lose the PC volume control.
There are others like the cheaper Govibe DAC that still allows volume control.
#10 mr_jay_318i
    hmmmmmm....
  • 677 posts
Posted 04 January 2010 - 02:19 AM
audison bitone. Optical in and more than enough control for any sq purpose. Awesome processor.
1990 BMW E30 318i
Custom Car PC
TEAM PHATT
#11 smithjaguar
    0 - 25w RMS
  • 5 posts
Posted 17 February 2011 - 05:04 PM
I looked at the Alpine PXA-H701 with a sound card that allows a digital output. Other is Mini-ITX SPII12000 and it has Sound Blaster Audigy PCMCIA with optical out, 512MB memory, 8" Xenarc VGA Touch screen and 200 GB Seagate Baracuda drive.
#12 hellypetro
    0 - 25w RMS
  • 5 posts
Posted 13 April 2011 - 02:46 PM
The sound card has RCA left and right like a normal head unit. I just hope that everything is ready and prepared for research, so that will not damage or overload the signal amplifier with the sound card. For the crosses. I maybe could find a program knowing that tweeters should be a little careful with the programs. or it could build a kind of cross / filter connect to the RCA before reaching the amplifier. Other options include an electronic filter that can give you the option to adjust the volume.
