Ribbon tweeters for car
Posted 15 January 2010 - 04:56 PM
I'm thinking of using RAAL 20-70 tweeters. For home audio these are the best I've used.
They don't sound like tweeters, all other tweeters are annoying to the ear.
I've used most scanspeak, dynaudio, focal, seas and most other brands and they all have severe limitations.
Any suggestions?
MAYA Acoustics, TAG the audio group, Weiss Engineering
Holden Caprice 2007
Head Unit: Clarion HXD2
Amplifiers: Soundstream 2 X HRU4, 1 X Soundstream HRU2
Front Speakers: Focal K3P 3 way 6 1/2" & KBF 6 1/2" Bass extension kit
Rear Speakers: Boston Pro 60se (for ambience)
Masking Tweeter: Scan-Speak Illuminator R2004/6020 & Mundorf Silver/Gold/Oil Caps
Subs: 2 X SEAS L26ROY
Processor: Rockford Fostgate 3sixty.2
Capacitor: Tsunami HCAP-40
Speaker Cables: Siltech Classic Anniversary 770L Silver/Gold
RCA: Crystal Micro
Near Future: TAG (Weiss/Maya) AD, Convolutor, Up Sampler, Room Correction, 32 bit DA (true 32 bit) to replace Rockford Fostgate 3sixty.2
RAAL 70-20XR Tweeter to replace Focal Tweeter
Home Reference
Front End: Weiss Medea DAC, Weiss Jason Transport, TAG/MAYA/Weiss Convolutor (proprietry technology)
Pre Amps: TAG signature (custom 300B input tubes, 16 chokes, six chassis, first of its kind) & Aronov
Amps: 4 X Mark Levinson 333, Aronov mono blocks,
Speakers: TAG reference, FAL, Infinity RS 4.5, Infinity RS 2.5
Cables: Acrolink (top of the range)
Turntable: Aura, Tri Planar Arm, Koetsu Rosewood Signature & Air Tight cartidges
Posted 15 January 2010 - 05:09 PM
Ant
SStealth
Antony
Posted 15 January 2010 - 05:43 PM
268669, on Jan 15 2010, 06:09 PM, said:
Ant
These aren't the small RAALs, they are only available to OEM companies and require approval from RAAL to use. They are superior to the RAAL tweeters you buy from Madisound or other such retailers.
I'm also going to use a second tweeter (scanspeak 3/4" illuminator) for a masking effect.
Edited by Aris, 15 January 2010 - 05:47 PM.
Holden Caprice 2007
RCA: Crystal Micro
Home Reference
Posted 15 January 2010 - 05:52 PM
Mind you i would not be doing door trims, thought about kicks?
Posted 15 January 2010 - 05:57 PM
I personally haven't used them, however, I've heard they give horns a run for their money with regards to the higher frequencies.
I'm a novice when it comes to car audio and positioning of drivers in a car any recommendations are welcomed. If you think the kicks are a better position for the tweeters maybe I should consider it,
Holden Caprice 2007
RCA: Crystal Micro
Home Reference
#7
Posted 15 January 2010 - 06:22 PM
Also "thematt" on this forum uses ribbons either LCY's or AC's I can't remember which, hopefully he'll chime in and give you his opinion, as he is probably the only person on the forum to have alot of experience using ribbons in car.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
#8
Posted 15 January 2010 - 06:53 PM
I like them, but bigger than your ribbons.
like any speaker, as far from you as possible works best.
http://www.aes.org
TEAM Floor-Pods
#9
Posted 15 January 2010 - 07:04 PM
Incredible sound for the price. I wouldnt put RAALs in there though. Too expensive. Not worth it. My LCY's were $100 a pop delivered (express post from the US), and work well, but only play 6.5k up. Gives it air and space, but nothing special to the overall sound. Its the mids that are critical, but hey, your money.
Also, using a 2nd tweeter is flawed and wont work. Adding more diffuse sound wont cure the diffuse sound you already have.
Plus, we've said this on here before. Polar response (beaming) is primarily due to the dimension of the diaphragm, not the type of driver. Only waveguides can increase it. The Focal TLR only gets a good offaxis response, like the Dyn 330D, by using a good waveguide. There is no amount of Engineering or Design that is capable of overcoming physics.
You cant argue with Physics. Well, you can, but you'd be wrong.
#10
Posted 15 January 2010 - 07:14 PM
pcon_4.jpg 103.53K
11 downloads
pcon_5.jpg 120.74K
8 downloads
pcon_6.jpg 125.89K
6 downloadsLooks like someone disagree's with you
Headunit - Sony DSX-S300BTX
Front Speakers - Pioneer TS-A1702C
Rear Speakers - Pioneer TS-A6964
Speaker Amp - Fusion CA-DA41400 (4x150)
Rear Amp - 2 x Fusion CA-DA12250 (1x1150)
Subwoofer - Digital Designs 3515 Dual 1.5 with CF Dustcap
Power - 0ga/4ga Power & Ground, Stinger Distro
RCA - Monster Cable XL
Sound Deadening - Dynamat Xtreme
#11
Posted 15 January 2010 - 07:18 PM
#12
Edit: Damn you Spyne i was too slow
Edited by SPL Samuel, 15 January 2010 - 07:19 PM.
#13
Posted 15 January 2010 - 07:22 PM
No they don't actually since those are actually Midrange ribbons, also not sure if they are actually a ribbon, probably closer to a planar in design. If you go to the bottom of this page http://www.hertzaudi.../default_en.htm and look at the specs for the MLCX3 which is the supplied passive you'll see they cross the ribbon over at 900hz on the low end and 4.55khz on the top end. Also the response of those drops off like a cliff past 10khz.
Edited by Luke352, 15 January 2010 - 07:35 PM.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
Subbass JBL W15Gti
#14
Posted 15 January 2010 - 07:26 PM
#15
Posted 15 January 2010 - 07:40 PM
FreQuence, on Jan 15 2010, 07:26 PM, said:
See here to read about the differences http://en.wikipedia.org/wiki/Tweeter from the looks of it the Hertz ribbon is a true ribbon. Also looking at the photos and position of those tweeters and typical ribbon response and also according to Hertz documentation they really didn't put those ribbons in a very ideal position.
Edited by Luke352, 15 January 2010 - 07:58 PM.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
Subbass JBL W15Gti
