X-Over Points for setup
Posted 19 January 2010 - 06:59 PM
I have the following setup.
15" JBL Gti in the boot of my car, in IB, 6.5" Oz Audio Matrix Elites in kickpanels up front, in around 12L enclosures, and some USD waveguides under the dash.
My biggest problem with systems is tuning them, and just need a little guidance.
The USD waveguides can be crossed as low as 700hz (I am running them passive atm, just to get a feel for them, and this is the x-over pint I am unsing). I can increase this by running them active though.
My queston is what are some guidelines for the x-over points? Having never run horns, I am batteling a bit with getting them right.
Currently I have the USD's at 700hz (straight through on my deck), the 6.5" Oz@63Hz-1000Hz, and the 15"@63Hz. They are on a 12db slope.
Any suggestions wold be welcome, I still have some tweaks to do on the guides, but am just looking for some experienced advice.
Thanks in advance.
HU : Clarion DXZ776USB
Amp Front : Phoenix Gold X200.4
Midbass : Dynaudio MW180
Highs : USD Waveguides
Amp Sub : Eclipse DA7122
Sub : JBL GTi MKII 15"
Cables and Acc. : Stinger Helix, Audison Connection, PG
Car : 1972 Holden HQ Premier
Posted 20 January 2010 - 07:34 AM
just because the waveguides can play down to 700hz, doesnt mean necessarily that you should be doing that....my tweeters can play down to 1.5khz, but i have them crossed at 3.2khz because that's what sounds right to me
it's really a case of trial and error...if you cant tell the difference immediately, leave them on one setting for a couple of days, then change the crossover and listen for another couple of days...
Posted 20 January 2010 - 07:45 AM
In my situation I have gear that can play the following:
Sub: 20-200Hz
Mids: 40-500Hz
Midrange: 140-10Khz
Tweeter: 1.8KHz - 20KHz
So where the heck do I set my xovers???
It's just something u have to play around with...and there is no easy answer on this one...Lots of trial and error...
11.97 @ 123mph
12.64 @ 118mph
Posted 20 January 2010 - 12:12 PM
Tweeter: 1.6khz @ 24dB
Midbass: 80hz @ 24dB, 1.6khz @ 24dB
Subwoofer: 80hz @ 24dB
Give that try and see how it goes. If the tweeters seem a little harsh, you may have to lift the tweeter-mid crossover to 2khz.
The mids will do 80hz - 1.6khz no problems off axis ... probably even 2.5khz on axis. It really all depends on the subs ability to play clean to 80hz. A lot of them don't like to.
Source: Clarion HX-D2
Tweeter: Scan-Speak D3004/6020-00 (passive)
Midrange: Fountek FR88-EX (passive)
Midbass: Scan-Speak 18W/8535-00 (active)
Speaker Amp: Tru Technology Billet B-475
Subwoofer: Peerless 830877 XLS 12"
Subwoofer Amp: Celestra VA210
Posted 20 January 2010 - 12:17 PM
Power by: Phoenix Gold
Thanks to : Phatt Audio Concepts : Sew Fine Interiors : Frankson Car Audio
Posted 20 January 2010 - 02:25 PM
I'd cross the Horns over at about 1.2kHz, the mids down to say 40Hz (Oz Audio are an awesome midbass.. they'll handle get low enough) and let the sub handle the rest
My 2 cents
#7
Posted 20 January 2010 - 03:05 PM
i.e. Sub from 20-80Hz, then midbass from 40-280Hz, midrange from 200-3.2Khz, tweeter from 2.5KHz-20KHz...and use a 24db slope...
I've been using 24db slopes and not overlapping the xover points.
Any thoughts/ideas on this? Benefits/disadvantages? One that I can think of would be in the vocal range...having 2 different speakers playing vocals might sound strange... Or I could be totally wrong!
shizzle - Sorry if I've hijacked the thread, but hoping the answer might also be useful for u.
11.97 @ 123mph
12.64 @ 118mph
#8
Posted 20 January 2010 - 03:17 PM
That's my opinion though
#9
Posted 20 January 2010 - 03:19 PM
What does a crossover do?
What information do we need to determine a cross over (ignoring our ears)?
How does a crossover effect/relate to this information?
#10
Posted 20 January 2010 - 03:25 PM
My brain hurts.....
Well...a crossover splits the signal into separate frequencies so they are directed to the appropriate speaker...
Knowing the frequency response would be good....
That's where the xover points should be....
Or something like that....
But...what about when there is a midrange that will play from 140Hz to 10KHZ...and a tweeter that plays from 1.8KHz to 20KHZ...? For example
11.97 @ 123mph
12.64 @ 118mph
#11
Posted 20 January 2010 - 03:28 PM
Ant
SStealth
Antony
#12
Posted 20 January 2010 - 03:41 PM
NiDeKCuS, on Jan 20 2010, 04:25 PM, said:
This would be INCREDIBLY useful.
How do you hope to choose xover points when you don't know the frequency response of the drivers?
And considering the OP is using horns, which very few people here would have experience with, i'd suggest grabbing some measuring tools, and measure the response.
#13
Posted 20 January 2010 - 05:30 PM
seems to work
#14
Posted 20 January 2010 - 05:36 PM
Same deal with the mids - the OZ Audio do tend to play pretty low, but my modelling suggests that in 12L sealed, at 40hz, they will be at -4.5dB even after cabin gain. For best results / integration you want to keep the gap within about 1.5dB - this suggests an optimal crossover point at 90hz-100hz. You can probably get away with 80hz (-2dB) but only if the sub can play that high...if the sub is 2dB down at 80hz as well, then your going to have integration difficulties...in which case i'd suggest a different midbass or different sub.
Not only will crossing at 40hz likely give significant gap in response, it'll also likely increase distortion dramatically throughout the midrange - especially at high volumes. Keeping it at 80hz should reduce non-linear distortion dramtically, leaving you with a nice clean midrange.
I'd really suggest going with 1.2khz on the tweeters and 80hz on the mids based on the limited information available. I think one of the guys provided a response chart on the 15" JBL before, and from memory it just might handle the 80hz crossover.
#15
Posted 20 January 2010 - 06:03 PM
Secondly, I'd follow Fuzz's advice and do incar measurements of the Horns. This will tell you whether you have effectively coupled the horn to the dash (and can therefore run a 600-700Hz crossover before unloading). If its not coupled, your horn will unload much high (around 1.6kHz) and any information below that will tear apart your compression driver.
Because crossing the horns is so critical on the waveguide, you'll actually find that the Compression Driver wont work 'any harder' at 800Hz (with good coupling) then it does at 1.6kHz (without coupling). You'll want the Horn crossover as low as possible, without causing increased distortion levels (which happens when the horn isnt coupled)
