Protect mode on right turns
13 replies to this topic
#1 hixx
    0 - 25w RMS
  • 7 posts
Posted 20 January 2010 - 12:48 AM
Hi guys have looked around quite a bit and cant seem to find a solution to my problem, i would be very greatful for some tips or info on how to fix my sound system, i have 6 speakers, 1 amp and 1 sub set up connected to a kenwood stereo and it works great going forward or straight but whenever i take a right turn in my car be it sharp or not my speakers crackle and sometimes the head unit goes into protect mode.
I have tried taking the head unit out and making sure all the wires are connected properly with no actual wire showing/touching, i checked under dash/steering column for loose wires and checked sub and amp connections to no avail, im all out of options to try, so i thought i would ask some people with more experience with sound systems.
Thanks for reading! and i hope i posted this in the right place.
#2 ddaudiodirect
  • 158 posts
Posted 20 January 2010 - 07:11 AM
It sounds very much like a short in one of the speaker wires, it sounds like when you are turning right either the speaker terminals are touching on the car body or a wire is pinched somewhere and turning right makes it short.
What kind of car is it? and does it have aftermarket speakers in it?
#3 bigwillystyle
  • 864 posts
Posted 20 January 2010 - 07:33 AM
Speakers in the rear shelf... One of the terminal blocks will be broken off and when you go around corners the tinsel leads either touch the body, basket of the speaker or each other...
Toyota camry?? Or ford falcon??
Bring It On...
Big_Valven, on 15 December 2010 - 10:04 AM, said:
The amplifier has a small packet of 'warning smoke.' When you do silly things to it, it lets out the warning smoke to make you think something is damaged when it isn't.
Of course something is damaged! There was smoke!
Quote
Steve Lunchbox-Inc Laughton "front stage is technically known as "the less important than awesome mind asploding subdoofers" part of the sound.... this rare creature can often be found in more expensive, upper class cars, but never in commodores, the commodore is the natural enemy of the "front stage""
#4 myxsptlk
    0 - 25w RMS
  • 13 posts
  • State:Other
Posted 20 January 2010 - 07:37 AM
Do you have your h/u power connected directly to the battery? Check that the connection there is okay and even if it's not connected to the battery check that the battery is tightly secured and the positive terminal isn't touching anything metal. Same thing happened to me, first I noticed whenever I did right turns my stereo would reset. I tried a hard swere and the whole car stalled, thank god there wasn't any oncoming traffic. Turned out the battery was loose and the positive terminal was touching the battery clamp
#5 hixx
    0 - 25w RMS
  • 7 posts
Posted 20 January 2010 - 11:02 AM
i drive a done up 1991 honda prelude, all the speakers are aftermarket, but installed by previous owner, i installed the kenwood head unit as the old one was crappy looking and didnt support ipod connectivy or aux. Will have a look at your idea this morning myxsptlk.
#6 hixx
    0 - 25w RMS
  • 7 posts
Posted 20 January 2010 - 08:27 PM
battery is secure fine and all cords leading to it are also.. can not find anything that would cause it :(
#7 pyr0maniac
  • 248 posts
Posted 20 January 2010 - 08:29 PM
Does anything else go out? Temporarily loss of ignition? Gauges go dead?
#8 hixx
    0 - 25w RMS
  • 7 posts
Posted 20 January 2010 - 09:09 PM
Nope noticed this morning though, before it goes into protect mode its only the speakers that stop/pause/crackle and the sub keeps going strong until it goes into protect all 6 of the speakers go out/crackle. (2 small tweeters on dash and the other 4 in normal spots)
Edited by hixx, 20 January 2010 - 09:10 PM.
#9 hixx
    0 - 25w RMS
  • 7 posts
Posted 20 January 2010 - 09:29 PM
Okay just a sidenote i went down and played music very loud and pulled and moved around every cord i could find coming out of it and off my battery and off the amp and worked fine, also i only just noticed when i have volume really high on very heavy bass songs (pendulum - the other side) that as the sub goes the screen lighting on my kenwood stereo dims slightly and goes back to normal repeatedly
sucks driving without music!! cant find a thing wrong with it.. considering looking for a place in perth that does stereo repairs now
#10 Cyberpunky
    3kW Power House
  • 3,321 posts
Posted 20 January 2010 - 09:32 PM
check the tinsel leads on drivers side(it may be left but odds are with right) door speaker. I am guessing they are touching the door metal when you turn. Just cover the metal with some duct tape if its the problem
Edited by Cyberpunky, 20 January 2010 - 09:33 PM.
MEASQ co-founder
#11 hixx
    0 - 25w RMS
  • 7 posts
Posted 20 January 2010 - 10:18 PM
checked it and its fine no exposed metal and the connectors wouldnt be touching door as theres a good 4cm gap, going to wait till tomorrow to check the left side as i snapped one of the brittle bottom door clips taking door trim off to check speaker, lets hope thats it but very doubtful as right side looked very neat and organised
#12 Big_Valven
    MEASQ [SA] Coordinator
  • 6,887 posts
Posted 21 January 2010 - 11:40 AM
really, you have to check every single speaker and wiring connection in the system.
#13 hixx
    0 - 25w RMS
  • 7 posts
Posted 21 January 2010 - 02:45 PM
Upon looking at rear speakers i found a 2 small metal clips magnetised onto the back left speaker and i took them off, and then took for a test drive and no more problem :| could just be cooncidental and its just stopped momentarily but hopefully its fixxed for good!!! Thanks for your help guys
#14 Chaos
    rockin' in the free world
  • 714 posts
  • Interests:Guitars, British rock and roll, cars, computers and university (not an interest!)
  • State:ACT
Posted 21 January 2010 - 06:07 PM
dukt tape = +500 dee beez??
:P
"So, my big brother was playing guitar and I figured I'd try it too." - Stevie Ray Vaughan
"Permission to say cock!"
Trusted Sellers: bagtho, Gozza, Chemhaz, KGB, meaty_taco, Ren (xMplar)
QUOTE (Big_Valven @ Jan 31 2010, 12:13 AM) <{POST_SNAPBACK}>
Far out Chaos, you're all over it like a bad smell tonight! keep up the good work :)
