New Box
Posted 07 February 2010 - 09:42 PM
In changing the box around i have lost a fair bit of output (loading off boot??) and i would like to try a ported box. What is a good size box for the IDQ woofers and what is the best way of running them. I mostly like listening to rock but i listen to most types of music depending on mood and the traffic. I also want to have a go at some sound offs but really dont want to comprimise much on sound quality.
I have tried designing boxes with basebox pro but there is too much going on there for me. cant work out much at all. All i really need is a optimum volume, port size and length and any tips on how and where to face woofers/ports.
Michael
Front Stage: Focal Tweeters TA243, Dynaudio Mids MD140, Jaycar 10"s
Crossover: Behringer DCX
Front Stage Amps: 4 x Audio System F2-500
Subs: 2 x IXL 18"
Sub Amps: 1 x US Audio Bonecrusher2
Batteries: Optima YT D34s
Charging System: 3 x 110Amp Alternators
Sound Deadening: Dynamat Extreme, Sika Boom, Flashtac
Posted 16 February 2010 - 06:25 AM
TriggerHappy, on Feb 7 2010, 09:42 PM, said:
In changing the box around i have lost a fair bit of output (loading off boot??) and i would like to try a ported box. What is a good size box for the IDQ woofers and what is the best way of running them. I mostly like listening to rock but i listen to most types of music depending on mood and the traffic. I also want to have a go at some sound offs but really don't want to compromise much on sound quality.
Michael
Have i put this in the wrong spot ???
No replys ? i would like to start working on a new install asap.
Michael
Subs: 2 x IXL 18"
Posted 16 February 2010 - 07:04 AM
See how you go with that
Posted 16 February 2010 - 09:44 AM
I'd be trying that before I built another box!
X3 3.0d
Head Unit - Alpine CDA-117E
Amplification - RE Audio XT-1600.4
Front Stage - Hertz Energy
Subwoofer - Rainbow Hammer 10
Cabling by Stinger & Aerpro
Team Furry Seal Killa
Posted 16 February 2010 - 07:39 PM
Thanks deafwish and Tiger for the replys
The box i currently have was built with a flat face and sits at an angle to the back seats, if i built the said ported box at 1.9 cubic feet (per driver ?) would i see any gains from sealing the box to the parcel shelf, floor and strut towers in behind the seats ?
Would something like 12mm MDF do for the trim panel behind the seats or should i use 18mm mdf like the box ?
Where would be the best place to aim the ports into the cab alongside the drivers or into the sealed off section of the boot. Would 4" down water pipe do for the port or is there a better material i should use ?? and would flaring make much of a difference.
How thick can i buy perspex, would it be possible to put a perspex window in the back of the box so you can see the rear of the drivers and with such a large box what sort of bracing would be required.
Thanks Heaps
Michael.
Subs: 2 x IXL 18"
