H701 tuning tips
11 replies to this topic
#1 eclipse_DYN
  • 278 posts
Posted 19 February 2010 - 01:35 AM
Last night I installed my new head unit, a DVA-9861e, and wired up my new processor, H701. Straight out of the box (so to speak) the SQ is excellent. Very clean and powerful sound. Im not sure why, but I seem to have much more volume now..... Something to do with optical output maybe?
Today I concentrated on setting gains, and time alignment. I am pretty happy with what I have achieved, but I'm unsure on some of the other features the 701 has.
Im after a bit of advice from someone who has used a 701 and knows the ins and outs of the different settings features. I have tried enabling and disabling different things in different combinations, but I'm having trouble finding a winning combination that makes the most of what I have.
I know that every setup is different and will require different setups, but I'm just after a starting point. Features I'm unsure of are:
MX - On or Off. If on level 1,2 or 3?
Bi-Phantom - On or Off?
Multi Channel - Movie, Music, Rear mix or off?
PCM - 2ch or 3ch
Listening Mode - Standard or Maximum
Any advice is, as always, very much appreciated.
H/U - Alpine 9861e
Processor - Alpine H701
Front Stage - Dynaudio System 362
Amp - Tru Tech S44
Amp - Eclipse PA5422
Subwoofer - Eclipse 15" Aluminium
Amp - Eclipse DA7122
#2 Mr_Bob
    3kW Power House
  • 8,744 posts
Posted 19 February 2010 - 09:29 AM
Definately tune with MX off, (it' sorta like a "loud" feture, but more advanced)
If your base tune is for SQ, you can use it to give you a fatter sound for everyday cruising.
found it was ok when i was listening to Rap or DnB
multichannel is about surround settings, i had it off, but if you're playing movies, you may want it on.
Bi-Phantom is designed to replicate a centre channel even if you don't have one.
I tried it and noticed an imaging change, but i didn't think it was better.
I haven't tried the other settings,
PCM is usually the sample rate, so i'm not sure why it relates to channels
Unless it's a form of calculation to generate a centre channel signal even if the source doesn't have one recorded?
<p style="text-align: center"><strong><span style="font-family: Tahoma"><span style='font-size: 10px;'><span style="color: red">RE XXX Splits - AXTU600C<br />12&quot; RE XXX - USAmps AX2000</span></span></span></strong></p><br />  <p style="text-align: center"><em><strong><span style="font-family: Tahoma"><span style='font-size: 10px;'>2004 CAASQ National Champion (Amateur Street class)</span></span></strong></em></p><br /><p style="text-align: center"><em><strong><span style="font-family: Tahoma"><span style='font-size: 10px;'>2005 CAASQ National Runner up (Pro Street class)</span></span></strong></em></p>
#3 Pulse-R
    Digital is only on or off
  • 10,953 posts
Posted 19 February 2010 - 08:21 PM
In short:
MX off (has to be set for all sources, except AM has no MX.
Are you using surround, or only 3-way front+sub?
Bi-Phantom is to do with centre channel/surround info.
PCM 3-ch is only if you g=have a centre speaker.
Standard.
If you hook up a screen, there's a few other options also, to do with DVD sound. - 2-ch mixdown, or surround... etc.
http://www.aes.org
TEAM Floor-Pods
#4 eclipse_DYN
  • 278 posts
Posted 20 February 2010 - 06:06 PM
Pulse-R, on Feb 19 2010, 08:21 PM, said:
In short:
Standard.
Im not using surround, only 3way front + sub. I am still running semi active front stage, have the midrange and tweet running off the passive crossover still. I have Front 1 going to the amp driving midrange and tweet, Front 2 going to midbass amp, and Sub to Sub. Im thinking maybe I should have run the midbass amp off Rear, that way I have more EQ channels available, and can tune bands that are really close together
So without the centre speaker I should have Bi-Phantom off, PCM set to 2ch, and listening level to Standard. Easy
I have noticed an immediate increase in stage height and depth, as well as a much more focused centre image. And for some reason more volume??
Great setup the 9861 + 701, heaps of tuning options, will take me ages to get it right. Hopefully it should be sounding pretty good by the next comp (March 6)
Edited by eclipse_DYN, 20 February 2010 - 06:08 PM.
H/U - Alpine 9861e
Amp - Tru Tech S44
#5 Mr_Bob
    3kW Power House
  • 8,744 posts
Posted 20 February 2010 - 09:35 PM
more volume is likely to be due to the higher voltage pre-outs.
may also be perceived volume if your dynamics have improved.
I ran my setup very simliar to yours, semi active 3 way, midbass off rears, mid and tweet off front 2.
I used Front 1 for ambient tweeters.
#6 vsber
  • 64 posts
Posted 21 February 2010 - 09:33 AM
Glad to hear you have it up and running .
Source/processor: Clarion HX-D2,
Amplification: Tru Tech Billet 4100s stage 4 , Phoenix Gold 475 Titanium , Alpine Mrdm-1005
Drivers:Morel Elate 9 ,CDM-88 ,Morel Picollo ,Morel Ultimo 12
Cables:Monster Cable 400 series 404.402.sub
#7 HISPL
    I know a bit about a few things ;)
  • 5,050 posts
  • Interests:Car Audio (Obviously), Golf and Travel
Posted 21 February 2010 - 01:00 PM
Remember to always cut and never boost using an EQ ;)
#8 bsyde
  • 570 posts
  • Interests:Car Audio-MiniTruckin-Djing-PS3
Posted 21 February 2010 - 02:35 PM
That is not always the case. The idea is not to boost into clipping. So try and cut more than boost is a good idea but to never boost is not entirely correct
UNDER CONSTRUCTION
CLICK TO SEE CAR
CAR:
MY10 Mitsubishi Lancer VR-X
Source Unit: Pioneer P90 combo
Speakers: Crescendo 9.9v2 active 3way
Subwoofer:Crescendo Etude 5.12
Amps: Arc Audio
KS300.2
KS300.4
KS500.1x2
#9 s4turn
  • 347 posts
  • State:Other
Posted 22 February 2010 - 02:48 PM
this thread here may be of help
http://www.diymobileaudio.com/forum/diy-mo...rets-701-a.html
in the thread above, if you run tweeters on front 1. midbass off front 2, midrange of rear 1 then you will get a separate EQ for the Mids and tweeters, which I plan on doing :D
Edited by s4turn, 22 February 2010 - 02:51 PM.
Boston ---> Alpine ---> Scan-Speak
#10 Pulse-R
  • 10,953 posts
Posted 22 February 2010 - 04:52 PM
^^^ That's how I have mine.
make sure you set all the sources to 2-channel mix-down, or you have some funny effects with 5.1 cd's.
I had to connect up the screen to get some of the options, but then disconnected it again once the H/U setup was done.
http://www.aes.org
TEAM Floor-Pods
#11 HISPL
  • 5,050 posts
Posted 22 February 2010 - 09:36 PM
Not alwyas the case but good advice for someone who is a noob.
I don't think you should buy speakers or install a system where the FR is that bad that after cutting using your EQ you then need to boost to complete "fixing" the problem ;)
#12 Mr_Bob
    3kW Power House
  • 8,744 posts
Posted 22 February 2010 - 09:59 PM
personally i wouldn't boost unless it was a last resort.
I found a gap in my frequency response, and considered boosting those frequencies
i kept chasing the issue to find that my mids and midbasses preferred to be out of phase relative to each other.
possibly due to phase shift in the crossovers.
once the phase was swapped, the FR was much smoother.
also had another issue where i needed to run overlap in the electronic crossovers to get rid of a gap.
in both cases, boosting the frequencies would not have solved the issue
but would have increased the risk of damage to speakers,
inparticular in the first case, as the speakers were receiving full power, but were not audible in that range.
tuning your system to be +/-3db is not easy, and if you do this only via the EQ, you will strangle the dynamics.
The best way to tune is via installation.
this is about good system planning and then some trial and error :)
EQ should only be applied once this has been exhausted, and then sparingly.
I would much much much rather an ordinary frequency response and good dynamics,
than a perfect frequency response and ordinary dynamics
