Clipped signal from Pioneer AVH-P7850DVD
13 replies to this topic
#1 sliksilvia
  • 525 posts
Posted 23 February 2010 - 07:28 PM
Hi Guys,
When I have my head unit at around 17 mark out of 40 being max my tweeters distort on high freq on two songs that i can tell.. Songs such as Celine Dion and Diving Faces (trance)...
Im not sure if this is due to the head unit pre-outs clipping (Pioneer AVH-P7850DVD) or the amp
(Zapco Ref 350.2) powering components (RE Audio XXX 6.5). I will try to find this out on the weekend when I set re-set the gain's however I have noticed with this particular headunit I cannot adjust the filter or cut of freq for how high the tweeters play...
If anyone with an Pioneer AVH-P7850DVD can maybe let me know how high they can turn the headunit up before getting a clipped signal let me know.. I usually set the headunit at 3/4 of its max volume (MAX = 40) and then set the amp gains from that point..
Cheers,
MB
Edited by sliksilvia, 24 February 2010 - 10:43 AM.
~ Pioneer ~ Zapco ~ Image Dynamics ~ RE Audio ~ Stinger ~ Dynamat ~
#2 Stone
    3kW Power House
  • 7,005 posts
Posted 23 February 2010 - 08:24 PM
Do you know anyone with a CRO? That'd be the most accurate way to tell...
#3 ReMiX
    Inhuman
  • 1,885 posts
Posted 23 February 2010 - 08:54 PM
My max volume was 25 with my AVH-P7850 with no distortion.
As above, Get your hands on a oscilloscope to check the signal.
Edited by ReMiX, 23 February 2010 - 08:57 PM.
IPB Image
#4 Jnr
    I Love Marg
  • 1,570 posts
Posted 24 February 2010 - 01:15 AM
Alberts cannington has a CRO
Jnr
Team Piglet
"PERFECTING BACKYARD ENGINEERING"
#5 Luke352
    1500 - 3000w RMS
  • 2,776 posts
Posted 24 February 2010 - 09:58 AM
MB
Are you running Passive? If so why would you need a filter for your tweeters?
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
#6 sliksilvia
  • 525 posts
Posted 24 February 2010 - 10:46 AM
I've noticed I only get tweeter distortion with the Auto EQ feature on. Im running passive but thought a x-over filter will still be got to cut off how high the tweeters play?
Without the Auto EQ the system can play at 25+ without distortion however the SQ in terms of stage height and clarity isnt as good, hence why I have the Auto EQ set to ON..
I might take the car the Alberts to be RTA'd see if they can get it sounding any better..
#7 Luke352
    1500 - 3000w RMS
  • 2,776 posts
Posted 24 February 2010 - 10:54 AM
No all you need is a High Pass to prevent your Mids from playing too low and over exeritn them, you don't have to worry about the tweeter that will be looked after by the passive.
I suspect your problem is the Auto EQ, I suspect it is adding a lot of boost around certain freq's causing the output from the HU or possibly the amp to clip in that freq's range since it is considerably higher then everwhere else.
There is no reason why you can't acheive the same results or better tunign the system manually as what the Auto EQ tune does.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
Subbass JBL W15Gti
#8 sliksilvia
  • 525 posts
Posted 24 February 2010 - 11:11 AM
Yeah i've been told to scrap the Auto EQ and have it tuned propely with RTA and a good set of ears.. I think i gotta get it booked into Alberts or West Side Cannington...
I've played around with it myself but still cant get it sounding as good as using the Auto EQ feature..
#9 mr_jay_318i
    hmmmmmm....
  • 670 posts
Posted 24 February 2010 - 09:38 PM
i have no stress with mine. i run at about vol 18 for testing 25 for normal and can push up to about 31 or 32 if i reaally wanna deafen myself and is still sounding fine and detailed. mind you there is 600rms+ for the fronts.
i would say run the fronts active. the deck is fairly capable, just takes a while to get used to the tuning side.
1990 BMW E30 318i
Pioneer DEX-P99RS, XDV-P650, CD-BTB200, CD-IB100II
Tweeters: Dynaudio Esotar2 110's
Mids: Dynaudio Esotar2 430's
Midbass: Dynaudio Esotec MW182's
2 X Arc Audio 4200SE
1 X Arc Audio 2300SE
2 X Arc Audio Black Series 12's
Stinger Connections, Big_val RCA's, Optima D34, Python 990
Custom Car PC
TEAM PHATT
#10 sliksilvia
  • 525 posts
Posted 25 February 2010 - 11:14 AM
Are you using the Auto EQ on your 7850?
Running active is no longer an option, I did this in my previous car but have sold the Zapco 4 Channel and i'm only using a 2 Channel and Mono block with the factory rears off the deck with my current setup...
Edited by sliksilvia, 25 February 2010 - 11:15 AM.
#11 mr_jay_318i
    hmmmmmm....
  • 670 posts
Posted 25 February 2010 - 09:55 PM
na.
when you run it active you cant use auto eq or ta. all manual.
dont forget the deck does have a tweeter output (its only 22rms from memory) but still i ran my tweeters off that for a while and it was ok. just a prick to wire because it comes from the external box. otherwise i would say even get a little 2 channel just for the tweeters.
1990 BMW E30 318i
Custom Car PC
TEAM PHATT
#12 sliksilvia
  • 525 posts
Posted 26 February 2010 - 11:27 AM
mr_jay_318i, on Feb 25 2010, 07:55 PM, said:
na.
22rms prob not enough power to run the RE Audio tweeters which are in the kick panels and I believe they are 3 ohm.. Def dont want to spend money on a another amp
mr_jay_318i is your normal lisiting volume 18 or 25 on your deck? Just curious as mines around 14-15 which is reasonable loud
#13 mr_jay_318i
    hmmmmmm....
  • 670 posts
Posted 28 February 2010 - 08:26 PM
yeah just depends. for testing about 12. normal listening 18-26 and can push up to about 31 for real loud. i do have my gains down and am about to turn em down a bit more to get rid of a tiny hiss i get on a 0 bit track. they are 5v pre outs, try turnin the gain right down.
1990 BMW E30 318i
Custom Car PC
TEAM PHATT
#14 sliksilvia
  • 525 posts
Posted 08 March 2010 - 04:37 PM
yeah i think its time i checked my gains or got it RTA'd im running Symbilink rather then RCA's which have a preout booster so its converts it to 12 Volt preouts so i should prob drop the gains on the amps..
At 13 is my normal listening volume which is quite loud.
