Pioneer P9 optical cable
10 replies to this topic
#1 fenis
  • 63 posts
Posted 09 March 2010 - 06:34 PM
Hey guys I just recently bought a P9 combo 2nd hand off another MEA member and I'm having trouble with no sound at all! If I use the RCA preouts direct from the headunit I do get sound but when using the DEQ processor (with the digital optical cable) I don't have any sound..
All the menus and processing etc work fine with the DEQ and I've double checked all the connections so it's either a problem with the optical cable or the DEQ's RCA preouts (the previous owner ensures it was working perfectly before) - so I suspect the optical cable may have been damaged at some stage.
Does anyone have a P9 optical cable lying around that I could quickly use to test? If not in perth I would pay for postage and pay a small fee as well :)
Cheers guys
Edited by fenis, 09 March 2010 - 06:40 PM.
#2 Pulse-R
    Digital is only on or off
  • 10,953 posts
Posted 09 March 2010 - 07:09 PM
If there's no optical, the DEQ should defult to the analog input from the IPBus.
maybe you haven't got the optical turned on? did you try from radio?
http://www.aes.org
TEAM Floor-Pods
#3 fenis
  • 63 posts
Posted 09 March 2010 - 07:43 PM
Can the IP bus cable carry analog? I didn't know the optical could be turned on or off! How do you do that? There's also no sound from the radio either.
Edited by fenis, 09 March 2010 - 07:43 PM.
#4 Pulse-R
  • 10,953 posts
Posted 09 March 2010 - 08:13 PM
yes, the IPBus carries analog. It's actually quite similar to Alpine's AiNet.
looking at the manual here --> http://docs.pioneer....CRB1643_manual/
on page 85
you need to connect the optical (black) connector to the DEQ, and the IPBus (black) connector to the DEQ.
otherwise it won't work.
also, the first time you power it up, you should do a reset to make sure all the IPBus devices are initialised and picked up by the DEX
http://www.aes.org
TEAM Floor-Pods
#5 fenis
  • 63 posts
Posted 09 March 2010 - 10:56 PM
You asked if I turned on the optical - maybe you meant to say have you plugged it in? And yep I resetted both the DEX and the DEQ..
#6 fenis
  • 63 posts
Posted 11 March 2010 - 12:43 PM
I'm a little confused here. So if the optical cable isn't plugged in the DEQ automatically reverts to using the analog signal from the IPBus cable?
I thought that the DEQ can only function digitally from the optical cable otherwise it won't work at all.
Edited by fenis, 11 March 2010 - 12:56 PM.
#7 Pulse-R
  • 10,953 posts
Posted 13 March 2010 - 11:07 AM
maybe it's faulty then.
http://www.aes.org
TEAM Floor-Pods
#8 ~thematt~
  • 3,300 posts
Posted 13 March 2010 - 01:26 PM
From memory, whilst the IPBus carries an analog signal, it doesnt carry it from the CD. Only the radio. The CD is only transmitted over the optical line.
#9 fenis
  • 63 posts
Posted 23 March 2010 - 11:06 PM
UPDATE: It wasn't the optical cable! It was a faulty IP-bus cable! The previous owner had 2 IP-bus cables (one for the DEQ and one for a CD stacker) so I thought what the hell I'll try swapping the IP-bus cable and low and behold it worked!!
This is such a sweet sounding unit - I can hear so much more detail and my system has come alive! Thanks for everyone's help! :db:
#10 Stone
    3kW Power House
  • 7,005 posts
Posted 24 March 2010 - 06:08 AM
It's probably not faulty, there's 2 types of IP-BUS cables. One will work with it, the other won't.
#11 gmcclelland
  • 60 posts
  • Interests:Computers and audio.
  • State:TAS
Posted 24 March 2010 - 08:29 AM
your username sounds like penis.
that is all
Car: '95 VW Golf GL
Headunit: Pioneer DEH-2950MP
Speakers: Alpine Type S in the rear. Stock front and rear door speakers and stock tweeters.
