I'm currently thinking about building a centre channel using a Hybrid Audio L4 in the dash pointing directly up to the windscreen , with a tweeter at the base of the windscreen firing directly forward between the passanger and drivers' seats.
the mercedes dash has a spot for a factory 4x6 I think, although I havent yet pulled it apart to investigate. However, apparently you can fit 2 4" speakers in there with a bit of work.
Dash looks like:
Tweeter will be in similar pods as the ones on the L+R:
raised pod.jpg 22.51K
5 downloadsQuestions I have:
1. Given the centre driver will be 90degrees off axis to the listener, should I think about some sort of waveguide to help the 3.5kHz - 5kHz hole that is likely when the speaker beams? (assuming the L4 beams at about 3.5kHz...)
2. Should I put 2 l4's in there if possible? How will that affect off axis response if they are side by side?
3. What are the likely acoustical issues if the driver is mounted slightly below the dash, firing directly up into the windscreen? Does the refection become the point source for the listener?
4. Should I vent the rear of the enclosure into the dash, or should I consider some sort of aperiodic mat to reduce rattles inside the dash?
5. What are the other issues you can think of, and where would I start reading about them?
6. Has anyone developed any sort of acoustic lens technology for a 4.65" midrange? That would be awesome....
thanks gang!!
