Bi-amp Dynaudio passive crossovers?
Posted 22 April 2010 - 02:37 PM
Does anyone know how to do this?
Posted 22 April 2010 - 03:54 PM
Shouldn't be too hard.
Posted 22 April 2010 - 05:15 PM
Power by: Phoenix Gold
Posted 22 April 2010 - 06:15 PM
It looks quite do-able. (I realise that's the X362 xover, but X360 is presumably very similar.)
For example, the 'air coil' probably just has a single end soldered to the POS track. Unsoldering this, and hardwiring it to new speakerwire, will isolate the LP filter for the woofer, for bi-amping purposes. Take it a step further and tri-amping shouldn't be too hard.
Posted 22 April 2010 - 06:31 PM
the second option saves from destroying the crossover.
the woofer and midrange are 6dB crossovers:
1 coil for the midbass, plus a cap and resistor for impedance correction (left hand side of pic)
1 coil, 1 cap and some resistors for the midrange (right of pic.).
1 coil, 1 cap, some resistors and a Thermistor for the tweeter (centre of pic.).
very simple, very easy.
Edited by Pulse-R, 22 April 2010 - 06:33 PM.
http://www.aes.org
TEAM Floor-Pods
Posted 24 April 2010 - 09:03 AM
#7
Posted 24 April 2010 - 09:23 AM
http://www.aes.org
TEAM Floor-Pods
#8
Posted 24 April 2010 - 09:30 AM
#9
Posted 24 April 2010 - 12:32 PM
either need to completely disassemble the crossovers, and re-build them as separates,
or
make new ones with the same component values.
http://www.aes.org
TEAM Floor-Pods
#10
Posted 24 April 2010 - 02:13 PM
#11
Posted 24 April 2010 - 03:07 PM
Damo95, on 24 April 2010 - 02:13 PM, said:
I was thinking the same thing!
You still have your H701, Clint?
If you are able to bi-amp, then you already have enough amp channels.. so why use the passives?
I was going to do the same with my Morel LE Elates, originally.. then I thought to myself, WHY?
You can use the same x-over points and slopes if you are active, with the added advantage of changing these if necessary for your setup..
Just my $0.02
Mark
2010 Victorian State Runner-Up - MEASQ Expert Class
2011 Victorian State Champion - MEASQ Expert Class
#12
Posted 24 April 2010 - 03:11 PM
The mid and tweeter, was the one I was warned to run passive.... is that not really the case?
#13
Posted 24 April 2010 - 03:23 PM
I seem to recall him saying he uses the same x-over points as the passives but actively..
The passive containing protection for the tweeter and zobel may be what was behind the warning you had?
I don't think you would be silly enough to damage them if you opted for active..
I just see more advantage with tunability using full active over active/passive.
I want to see you get the Foz right this time.. !
Mark
#14
Posted 24 April 2010 - 03:55 PM
Clint.. sure.. most will say the dyn tweeters sound "warmer" when run off the passive..
but if you have the channels for active, then give it a shot using same crossover points/slopes..
#15
Posted 24 April 2010 - 05:53 PM
Processor - Alpine H701
Front Stage - Dynaudio System 362
Amp - Tru Tech S44
Amp - Eclipse PA5422
Subwoofer - Eclipse 15" Aluminium
Amp - Eclipse DA7122
