Does your dsp chip effect sound quality
Posted 16 May 2010 - 10:06 AM
Posted 16 May 2010 - 10:41 AM
HU : Clarion DXZ776USB
Amp Front : Phoenix Gold X200.4
Midbass : Dynaudio MW180
Highs : USD Waveguides
Amp Sub : Eclipse DA7122
Sub : JBL GTi MKII 15"
Cables and Acc. : Stinger Helix, Audison Connection, PG
Car : 1972 Holden HQ Premier
Posted 16 May 2010 - 11:25 AM
Posted 16 May 2010 - 11:29 AM
Posted 16 May 2010 - 11:31 AM
Posted 16 May 2010 - 11:53 AM
#7
Posted 16 May 2010 - 02:15 PM
I do not agree that it is the DSP chip causing the 'problem', but rather the budget code used to effect the 'adjustments', and the budget design implemented.
Every DSP chip is pretty similar internally, it has inputs and outputs, and firmware inside to make it do what it's told.
The problem arises when a programmer has to cram in more features. This requires more code and more processing speed.
Head unts and processors used to have a dedicated DSP chip for processing, but now they have the DSP doing EQ+TA+XO and then throw in a few codecs as well, and bluetooth, and iPod control.. all of a sudden, the ancillary functions need so much space there's very little left for any audio adjustments. A good example of how it used to be done is the Alpine PXA-H701. It has 2 DSP chips for time alignment and equalisation. A seprate DSP/CODEC chip is used for Digital audio decoding and crossovers.
Given that a processor only has so much program memory, it's not hard to see that with all the extra 'features' in modern head units, there has to be a trade-off. This tradeoff is in the precision of the complex calcuations used to perform EQ and crossover functions. To do it right requires 10x more processing than the approximations used in many budget implementations.
The truth is, cheap sells and most people can't hear the difference anyway - or don't care.
- my 2c.
http://www.aes.org
TEAM Floor-Pods
#8
Posted 16 May 2010 - 09:13 PM
I think the stickiest point here is that it's hard to actually pinpoint the DSP chip as being at fault. Thing is, there is any number of points in a headunit where manufacturers can cost-cut, and more often than not a DSP can degrade sound quality without actually setting TA and EQ.
A unit could have one of the most cutting-edge DSPs available, and still be let down by rubbish conversion or line drivers, for example.
To directly answer your question though; my DSP doesn't affect sound quality one bit... but that's cos I don't have one... yet
Edited by Big_Valven, 16 May 2010 - 09:14 PM.
#9
Posted 20 May 2010 - 01:51 AM
Big_Valven, on 16 May 2010 - 09:13 PM, said:
#10
Posted 20 May 2010 - 12:22 PM
#11
Posted 20 May 2010 - 04:08 PM
Some digital processors may affect sound quality but passive networks affect it MUCH more, even if in different ways.
#12
Posted 21 May 2010 - 08:24 AM
#13
Posted 21 May 2010 - 08:59 AM
Active processing for similar $$$ is much more flexible, and doesn't suck up power or create phase anomalies to the same extent that passives do.
And what do you mean there's no fluctuation? There's HEAPS of fluctuation in passive components over time, when the weather changes, etc. DSP units have no such problem.
#14
Posted 21 May 2010 - 09:05 AM
Edited by mrock, 21 May 2010 - 09:06 AM.
#15
Posted 21 May 2010 - 09:52 AM
MOTHER OF GOD I WANT ONE, actually make that I WANT ONE HUNDRED:
DEQX active crossover and everything under the goddam sun you could ever ask from dsp
Ok, I get that it's super expensive, but there are people who've spent WAY more than 10k on a system before, it's not that far out of reach.
Edited by br85, 21 May 2010 - 09:55 AM.
