Audison amplifiers , tell me
11 replies to this topic
#1 cm_ls1
  • 224 posts
Posted 08 June 2010 - 01:27 PM
How good are they?
Also apparently threre where different series ( blue vs black ) , differences from one to the other?
Thinking of getting rid of my old alpine v12s , an improvement?
Ta.
Edited by cm_ls1, 08 June 2010 - 01:30 PM.
HU: Wolfson WM8975 DAC - Bk Tube Driver - Front Stage - QSD 216 (MRVT420)- Sub - 13W6v2 (MRD1001)
#2 shiny_car
    Posts too much
  • Admin
  • 40,180 posts
Posted 08 June 2010 - 01:52 PM
Audison remain amongst my favourites. But then again, I haven't used a heap of top-spec amps.
You are specifically referring to the LRx series. The superceded blue models are still really nice. Great sound quality and nicely built, and look good. There have been some issues with blown power supplies/internals; but these seem to be very unusual, and if it hasn't already happened (to a secondhand amp), I doubt it should ever happen. It's often blamed on poor power delivery to the amp: battery, wiring, alternator issues; low voltage is presumably bad. But I would still buy them if I wanted an amp in that price bracket and quality.
The current black models are meant to offer even better SQ, and took designs and features from the superceded VRx models.
I don't think there's much between them, but I have not done directly comparisons. My experience is mostly with VRx models.
Typical of all Audison amps, they are relatively complex to set/tune, compared with most others. This refers to setting input modes, output modes, xovers, phase, boost, subsonic, etc, etc. Most models have a lot of featuers, and are very configurable; moreso than most other amps, hence the complexity. So it pays to read the manuals very carefully, and ensure you understand exactly what you are doing.
The sonic signature of Audison is often described as: fantastic clarity and dynamics, open soundstage, a little reserved in the top-end (high frequency treble), but very warm vocals; arguably this is due to some form of distortion, but it's not a negative feature IMO. In comparison, my Alpine F1 Status MRV-F900 is extremely clean, so what you get is what you feed into it; I honestly don't like this quite as much. Speakers will play a more important role, and make more difference than the amp though.
Some people will have had experiences with various combinations of speaker and amp. So perhaps explain what speakers, sub, HU you will be using: MBQ and JL?
Compared with Alpine V12, I would say there is a difference worth having.
#3 ~Spyne~
    SQN00B
  • 9,663 posts
i'm really not sure that there's any difference between the two amps you have shown.
Both are LRx series. Any small changes that may have been made between the two would almost certainly not be audible.
However, i have the LRx5.1k 5-channel amp and it's fantastic. Some odd quirks to do with having to use the sub xover filter in order to get (much) better output and quality, but all in all a VERY nice amp
what amps in particular are you looking at getting, what are your requirements and budget?
MEASQ National Manager
#4 cm_ls1
  • 224 posts
Posted 08 June 2010 - 02:36 PM
I'm running oz audio splits at the front and thinking about running the front bridged , or the back to the jl sub , I want to get the lrx 6.9 so down the track when I go 3way active , I can use this one amp for the splits and get a mono for the sub, good idea?
#5 shiny_car
    Posts too much
  • Admin
  • 40,180 posts
Posted 08 June 2010 - 03:30 PM
Could be a good way to go. Just ensure the amp offers as much power as you need: it's good, but not huge power. Some midwoofers may warrant more power, in which case a 4-channel + 2-channel can be better (ie: a powerful 2-channel just for the midbass woofers). The LRx6.9 has a good xover setup; only that channels C (5 and 6) have a LP filter, and no HP filter (ie: not bandpass). So the HU or processor would need to provide the HP for the midwoofers (eg: 80Hz HP), whilst the amp can provide the LP (eg: 500Hz LP).
#6 cm_ls1
  • 224 posts
Posted 08 June 2010 - 04:36 PM
Sounds like it's got the goods and channel c can handle 2ohm or even 1ohm load :@
Six Channel, bridgeable into either 5, 4 or 3 channels to run a complete in-car system
RMS Power @13.8V @4 ohm 4 x 70 watts + 2 x 75 watts/ 2 x 240 watts + 1 x 180 watts
RMS Power @13.8V @4/2 ohm 4 x 70 watts + 2 x 140 watts/ 2 x 240 watts + 1 x 470 watts
RMS Power @13.8V @2/1 ohm 4 x 120 watts + 2 x 230 watts
RMS Power @13.8V @2 ohm 4 x 120 watts + 2 x 140 watts/ 4 x 120 watts + 1 x 470 watts
Crossover Bypass A-B-C
Crossover Hi-Pass A-50-5kHz @12dB
Crossover Hi-Pass B-50-1kHz @12dB
Crossover Lo-Pass C- 50-1kHz @12/24dB(mono)
Crossover Band-Pass B-50-5kHz @12dB
THD @ 1kHz 0.04%
S/N Ratio (a weighted @1V) 100dB
Damping Factor 1khz,4ohm 120
Size: 198mm x 488mmx 56mm
#7 shiny_car
    Posts too much
  • Admin
  • 40,180 posts
Posted 08 June 2010 - 09:03 PM
I've seen the specs. For 3-way active, if each driver is 4ohm, you are talking about 4x70 + 2x75WRMS. 1ohm stability and power specs are irrelevant. And many drivers are higher than 4ohm (ie: 6ohm or 8ohm), so the power is even less.
#8 cm_ls1
  • 224 posts
Posted 08 June 2010 - 10:14 PM
Yeah I know, I'm sure it will push 3ways to loud enough ( for my tastes (sq)) levels ,
#9 golf_bht
  • 544 posts
Posted 09 June 2010 - 02:35 AM
If budget allow, I would recommend going up to VRX range. it is so much better
2003
4th [CAASQ] VIC AutoExpo Melbourne October 2003
2004
2nd place + Judges choice[CAASQ] Melbourne
Autosalon - April 2004
2nd place [CAASQ] Sydney Autosalon - May 2004
2nd place [CAASQ] Melbourne - Central Car Radio - May 30 2004
2nd place [CAASQ] Sydney - Doran Pro Audio- June 13 2004
3rd place [CAASQ] Autosalon Semi Final-
Melbourne September 2004
3rd place [CAASQ] 2004 Season Final
2005
IASCA Bangkok 2nd. place Street Smart 601+
IASCA SIC (Sepang Malaysia)
First place Street Smart 601+
Best SQ award & BEST Installation award
IASCA THAILAND (NAKNOSAWAN) 1St. Streetsmart 601+
2006
1St. Am1000+ IASCA Bangkok, 1St. Am1000+ IASCA Nakornsawan, 1St. Amature 1000+ IASCA Final and 1St. ISQC( SQ Open for anyone in the industry)IASCA Thailand International Final2006
2007 THE WINNER OF EMMA PURE PASSIVE THAILAND FINAL
#10 shiny_car
    Posts too much
  • Admin
  • 40,180 posts
Posted 09 June 2010 - 09:08 AM
But VRx are discontinued, so 'secondhand' is the only likely option (you'd be lucky to find 'brand new', though they probably exist). This leaves the Thesis series, which are no doubt superb, but so is the price. If you can afford them, awesome, but you'd also want to justify the expense by having equally good speakers, HU, sub, and top notch installation and tuning. I say it'd be worth it for sure, but not everyone would consider it good value.
#11 RMA
  • 1,051 posts
Posted 18 June 2010 - 05:00 PM
There is no difference between the Blue and Black in specification.
Audison simply moved to a new color scheme, all Audison amps are now black.
Hope that answers your question.
Not all things in the car audio industry are created equal...
Especially equipment and installers.
A bad installer won't blame his tools or his skill, he'll blame the equipment!
#12 shiny_car
    Posts too much
  • Admin
  • 40,180 posts
Posted 18 June 2010 - 09:02 PM
Oh, I totally missed that these are the same updated LRx models! I thought the 'blue' version posted by the OP was referring to the older series LRx, like this:
My mistake. :silly:
