Tweeter Challenge
Posted 07 July 2010 - 02:38 PM
I know the ideal answer is a good ribbon, but falling short of that, does anyone know of any dome (or Ring Radiator) tweeters that can do (say) 2.5khz - 20khz without sh!tting themselves and sounding like garbage above 100db? Don't mention compression drivers, they just can't do 20k.
Posted 07 July 2010 - 02:48 PM
You're 80yo self will thank you for listening to high freqs at 100dB+
If a ribbon is the ideal answer, what's stopping you? Why compromise?
Edited by mrock, 07 July 2010 - 02:50 PM.
Posted 07 July 2010 - 02:51 PM
I quite like the ScanSpeak Ring Rad's I've used in the passed... Not cheap, but damn nice. Had good top end detail, and stay composed at volume.
Granted I crossed them over at about 4k in a 3-way config.
Posted 07 July 2010 - 03:03 PM
It's not for daily use in a car anyway. I'm looking for something that will work in some studio monitors I'm looking at building. Granted, they won't need to go that loud very often, but when you're mixing things like drums pre-compression, there's some MASSIVE crests in there that might jump more than 30db above average signal level, and I want them to hold up to the abuse (in the sound quality AND mechanical/thermal limitation aspects).
4khz might be decent enough once the right waveguide is used. If I can get about an extra 12db of sensitivity gain between 1k - 5khz, that brings the theoretical acoustic equivalent xo point down to about 1khz or so. Might need a very complex filter at that stage though, but I'm looking at a $2500 - $3000 budget for drivers and box/waveguide materials (and I don't need xo components, the end user will be buying a high-end DEQX).
Edited by br85, 07 July 2010 - 03:06 PM.
Posted 07 July 2010 - 04:17 PM
I'd be looking at a small compression driver with a phase plug, to give you response out past 20k.
There's a small BMS unit that i'd look at, or a small Celestion unit that QSC use in some of their speakers.
#7
Posted 07 July 2010 - 04:41 PM
they maintaim composure up to 1kW peaks (on paper, at least)
besides, why do you need to hear up to 20kHz so loud? I'd think 18 is plenty.
http://www.aes.org
TEAM Floor-Pods
#8
Posted 08 July 2010 - 12:27 PM
#9
Posted 08 July 2010 - 01:35 PM
Unfortunately though I think the biggest challenge (or more likely prohibitive factor) will be that anything that can reach those levels will sound like poo at normal listening levels, defeating the purpose of a studio monitor.
#10
Posted 08 July 2010 - 01:53 PM
#11
Posted 09 July 2010 - 12:04 PM
mrock, on 08 July 2010 - 12:27 PM, said:
mrock, on 08 July 2010 - 01:53 PM, said:
The guy I'm building these for is no rookie to mixing (he's probably done about a quarter of the productions you hear on triple J during primetime), I'll leave that part of it up to him. He likes the sound of the dynaudios, he just wants something with a few more guts (the smaller dyn monitors aren't that great below 400hz) and a less "clinical" but more "detailed" high end. Sounds like an oxymoron, I know, but I think I know what he's getting at.
I WOULD just point him in the direction of the Linkwitz Orion, but the studio he's about to move into doesn't allow him to put them far enough out from the walls, so we're doing box speakers, and that's that.
#12
Posted 09 July 2010 - 09:36 PM
93dB sensitivity at 2.83v (5.6om re) should translate to about 91.5dB @ 1w/1m.
In theory:
1w = 91.5dB
2w = 94.5dB
4w = 97.5dB
8w = 100.5dB
In theory you should be able to hit 100db of as little as 10w input power.
The HDS extends right out to 20khz on axis (thought not quite flat). It's got exceptional distortion right down below 1.5khz, so 2.5kz should be no problem in that regard. Also plays down to about 2.5k response-wise, however it starts dropping below this.
Might be worth a look in.
Source: Clarion HX-D2
Subwoofer Amp: Celestra VA210
1998 Ford EL Fairmont
Source: Eclipse CD8455
Amp: Helix HXA-500
#13
Posted 09 July 2010 - 09:40 PM
The R2904 Ring Radiator is NOT a good performer below 3khz in it's natural form. The D3004/6600 or D2904/7100 would be better options at those frequencies. Both extend out to 20khz no problems at all, but the 6600 plays down beyond 2khz while the 7100 starts to drop off at 3k.
The 7100 does have significantly higher sensitivity though - it's up about 3dB on the 6600.
Still, I'd probably say the HDS is the best fit overall.
Edited by muzzy66, 09 July 2010 - 09:46 PM.
Amp: Helix HXA-500
#14
Posted 09 July 2010 - 10:08 PM
If the R2904's only work well down to 3k or so, I'd be hard pressed getting them down to 1.6k without a slight compression chamber in the waveguide, though I have heard of people successfully crossing the XT-25 at around 900hz (acoustic, not electronic) when the loading is good, I just don't know whether these sorts of speakers can go much above 95db without crapping themselves. The reason I like the idea of a ring instead of a dome is that the Frequency and Polar Response in a waveguide looks a little better. I wonder if the R3004 could be a contender. I'm just a bit iffy on the lower sensitivity.
Edited by br85, 09 July 2010 - 10:09 PM.
#15
Posted 12 July 2010 - 10:10 AM
Edited by mrock, 12 July 2010 - 10:12 AM.
