is it easy to install an immobiliser?
30 replies to this topic
#1 hsvmonarogen3
    i own marc (x2)
  • 1,754 posts
Posted 20 January 2011 - 07:38 PM
well the first thing i need to do is say that i am buying a new/old car. (gq patrol) and becasue the previous owner hasnt had an immobiliser fitted and now the lows in WA have changed, i have to get one installed. shouldnt be a prolbem. well it is. the local mechanics have pretty much fked the barinas engine so they arent touching the trol. 2nd there is no auto sparky for 300k.
so...
1. i need a immobiliser/alarm with central locking outputs.... so throw up some suggestions
2. i need to be able to install it myself.
3. no idea what else i need to know about alarms.....
1st Bathurst Livewire Spl Comp '05
3rd Melbourne Autosalon Db Drag'05
2nd Melbourne Autosalon Db Drag'06
1st Autobarn Hoppers Crossing Db Drag '06
1st A&P Electronics Trarlgon Db Drag '06
1st Autobarn Epping Db Drag '06
2nd Stothers Music and HI-FI Db Drag '06
2nd Aust Finals '06
1st Melbourne Autosalon Db Drag '06
1st Phatt Audio Concepts Db Drag '07
1st Melbourne Autosalon Db Drag '07
2nd Melbourne Autosalon Db Drag '07
PB 149.1db on TL
#2 Big_Valven
    MEASQ [SA] Coordinator
  • 6,887 posts
Posted 21 January 2011 - 09:27 AM
Alarms and immobilisers are a pain in the ass. I avoid them completely.
They are hard to install, and even harder to install properly. A poorly installed immobiliser isn't worth installing in the first place.
#3 Gobbledok
    Denny Crane
  • 1,343 posts
Posted 21 January 2011 - 01:33 PM
Unfortunately this alone qualifies you for the 'take it to an installer' category. Don't take it the wrong way, but vehicle security can get quite difficult and if you've never installed before it can way too overwhelming and introduce possibilities of damage to the car's electrical system. Feel free to pm me if you're still keen to go ahead and ill help as much as i can...
2008 Corolla - IDA-X100 - 2x Cadence DCA2500 - 4x Cadence DCW15 - 3 Optima D34M - PB-149.1 - DECEASED
2006 Vito "The Don" - IVA-W205 - 3x Cadence ZRS-9 - 6 Cadence DCW15 - 5 Fullriver SPV70 - PB-148.3 @ 25Hz - DECEASED
1999 Merc C180 - CDA-9887 - AudioSystem F6-380 - Alpine Type X Pro Tweets - Infinity Kappa Perfect 6" Mids - Alpine MRD-M605 - Alpine SBR-S123V - Fullriver SPV70 - FOR SALE w/o stereo.
Spoiler
#4 rawan05
  • 47 posts
Posted 23 March 2011 - 06:09 AM
come on guys, we live in a new era of technology. you can pretty much learn everything you need of google for nearly anything. there is plenty of resources just need to find the right ones.
people always say that you should take things to someone qualified, where truth of matter is most of them do poor jobs not because they cant do good ones, but because they want to cut time and minimize effort to save money thus profit(purpose of business). this happens from "reputably installers" twisting and taping, to mechanics with bad workmanship. My last alarm install was done poorly by the shop i took it to
thus to know what you want done inside out before taking it to someone will let you know if you have a good job after since you can check. but to do it yourself will probably be best. for a good install most places wont even take the time, because they would charge too much
anyways here is some links to alarm installs that you can learn of. suggest to you to READ READ READ LEARN LEARN LEARN UNDERSTAND UNDERSTAND UNDERSTAND then re repeat till its second nature
http://www.elantracl...showtopic=25660
http://www.honda-tec...d.php?t=2108744
http://www.honda-tec...d.php?t=2368830
http://causeforalarm...ion7/index.html
read thousand times and soon will be an expert. i based my current alarm install on those threads and i believe have a good outcome
1. suggest aussie alarms dynamco and mongoose. remember wires have to be black so dont buy ebay color wired spec immob. you can pick a good one starting at 100 thats pretty basic and most of them have central locking output
hope that helps
#5 Gobbledok
    Denny Crane
  • 1,343 posts
Posted 23 March 2011 - 07:59 AM
what happens when the windscreen leaks and water gets into the car?
fail #1.... just sayin.
you can not suggest someone just learn learn learn off google. if everybody did that, NOBODY would go to work because they could just do it themselves.
if you have the capacity to learn something, then by all means, go ahead. but most people dont have an idea about electronics, or only have one car so dont want to just keep practising until they get it right. what if they do some serious damage by making a mistake. costs involved could be enough to turn anybody off doing it again. then where's your trusty installer? he's gonna tell you where to stick it because you turned down his quote in the first place.
Spoiler
#6 rawan05
  • 47 posts
Posted 23 March 2011 - 10:43 PM
when the windscreen leaks and water gets into the car, the other electrical components are going to get damaged as well as the immob, if you install it under seat or under dash or under steering column. we had a huge storm in perth last year, and heaps of cars got water damaged from hale smashing windscreens. some cars were ok after windscreen change, but a year onwards are showing the damage the water has caused to the electric system.
there is also alot of cars with fuse boxs/ecu/electrics near the ground of the floor of the car, but this is not common that much anymore.
also that is just an example of an install, others choose to put it in different positions.
i agree with you to some degree. not everybody should attempt a immob/alarm install. but you can suggest for people to learn of google.
this is not for everybody, but lots of people(specially into cars/car audio) have the ability and want to learn about this aspect.
now i dont know hsvmonarogen3 but he is willing to learn. the least it could do is teach him about it.
all i am trying to do is give people some resources to be able to learn about alarms/immob. this could be helpful to people that try to attempt an install
#7 Banned.ScrewYouTeam.inc
    1500 - 3000w RMS
  • Banned Users
  • 2,047 posts
Posted 23 March 2011 - 10:45 PM
I've installed 2 alarms, there really isn't much to it.
one has remote engine start as well.
but.
if you're having to ask on here how to do it, then you shouldn't be doing it.
I build the Loudest Inaudible Cars In Australia!!!!!
#8 Langas
  • 715 posts
Posted 23 March 2011 - 11:19 PM
Immobiliser installations.....
Get it right, the car won't start
Get it wrong, the car probably won't start either!
Doomed? Maybe :)
Edited by Langas, 23 March 2011 - 11:19 PM.
#9 Banned.ScrewYouTeam.inc
    1500 - 3000w RMS
  • Banned Users
  • 2,047 posts
Posted 24 March 2011 - 09:19 AM
how is that doomed? thats exactly what you want :P lol
#10 Big_Valven
  • 6,887 posts
Posted 25 March 2011 - 09:23 AM
Gobbledok.inc, on 23 March 2011 - 07:59 AM, said:
Did anyone else notice that this isn't Australian Standards compliant because it doesn't have an all-black loom?
If you didn't, don't install alarms.
#11 Banned.ScrewYouTeam.inc
    1500 - 3000w RMS
  • Banned Users
  • 2,047 posts
Posted 25 March 2011 - 10:32 AM
black wiring is only an issue if you want a reduction in your insurance which if you're installing it yourself probably won't happen anyway.
#12 sidewalk
    0 - 25w RMS
  • 16 posts
  • Interests:Listening to music the way it was meant to be played by the artists!!!
Posted 26 March 2011 - 05:36 AM
I wired up my own alarm once, luckily, it was in a crappy old 93 sunchicken (pontiac sunbird). I had it all working at the start, I soldered my connections, etc. However right before I sold the car things were getting wonky. As far as the wire harnesses went.... chop suey... I wish it had been a mostly factory plugin system.
All that said, that was when I was 18, I'm 30 now, and would probably do it again myself, however, I'll be stripping the whole damn car for dynamat, and doing all the wiring with all factory paneling removed. I wouldn't recommend it for a first time. I learned a lot of "bad ideas" from my install. I sure hope the next owner of that car didn't ever look under the dash public/style_emoticons/default/unsure.gif
#13 beepbeep
  • 35 posts
Posted 22 April 2011 - 10:13 PM
im more inclined to suggest if you are not confident than maybe take your partner ( if applies ) out for a nice couple day holiday 300k away.
i now it sounds like a pain :) but srs it is a easy job to screw up and if you need to drive 300k to get it done well may as well book a B&B and make a holiday out if it
facepalm at idea of using google to learn from, some of my worst mistakes have come from following directions i found on google
Edited by beepbeep, 22 April 2011 - 10:14 PM.
#14 ubernoob
  • 971 posts
Posted 22 April 2011 - 10:38 PM
I am a very lazy idividual, I'd just get an immobilser relay, you get a remote and 1(or more) relays that you throw in place of a standard relay, you can put it on your fuel pump or whatever, pretty sure you can get them with a perimeter sensing system so you don't even have to push a button.
Relay
Volvo 2001 S60T5
HU- Blaupunkt Bremen
Front Midbass- CDT ES06
Front Mid- CDT HD2
Front Tweeter- CDT ES010
Nothing good ends in phile.
#15 beepbeep
  • 35 posts
Posted 22 April 2011 - 10:50 PM
those relays sure do look interesting
