Dynamco 6XR V4 Immoboliser - Toyota Corolla Seca
1 reply to this topic
#1 Wocky63
    0 - 25w RMS
  • 1 posts
Posted 03 March 2011 - 06:28 PM
Hi, I thought my Dynamco 6XR V4 Immoboliser was playing up and decided to bypass it by cutting the wires out and rejoining the original wires. Yes you guess it, it wasn't the immobilser it was the car battery being flat. Now I'm in a mess because all the wires that come out of the Dynamco are all black and i need to reconnect it. I know that some were 2 x 3 wires join together and the others were 3 x 2 wires together all black and cut into my wiring coloured from the ignition switch wiring. I hope someone can help me
#2 immobiliserdoctor
    0 - 25w RMS
  • 20 posts
Posted 17 March 2011 - 11:59 PM
The power wire is the fused one, open the module and find the two pins in the 7(?) pin connector that are joined, they are ground. Thin red and black will be LED all left are lock unlock and ignition, won't hurt anything to touchtest. strip ignition wire and turn on, strip remaining three wires. One by one, apply the stripped wires to the ignition wire, the one that makes the LED go on solid (stops flashing), is the ignition wire. I'm pretty sure you'll get the immob wires once you're inside the module, just untape everything, trace back and go again. good luck
