Matt VIP, on 21 March 2011 - 08:16 AM, said:
what EQ do you have on your amps? you may be able to use a single band to cover the frequencies you want to adjust. Otherwise, cross your sub lower with a steeper slope.
Actually I just thought of this I can use the bass boost on my arc 2300SE (can adjust both frequency and level) to boost only the midbass channels.
Winno, on 21 March 2011 - 08:37 AM, said:
If your Seas midbasses have a decent xmax, run them full range all the way down to natural roll off down near 40Hz or whatever.
i.e. don't run them on any high pass filter/xover at all.
This will pull your bass forward and also give you a more impact and 'slam'.
You might also want to play with the phase and gain of your drivers too when tuning things up.
You don't say whether you're going to run a passive system or an active system although I suspect active is what you'll be going for.
It also should go without saying that you're putting your mids onto a solid mount into treated doors.
Yep I'll be running full active and will definitely focus on making my doors as solid as possible (eg using aluminium tubing to stiffen up mounting area, modelling clay etc).
As for the xmax of the seas w18nx it's listed as 22mm. Not sure if want to let them run full range as it might muddy up the midrange and also they will be installed IB in the doors so won't have as much suspension control. Here are the specs:
On the freq response chart the thin line is the IB response - I thought in IB you lose heaps of midbass output below 100hz or am I wrong? And does cabin gain usually boost midbass as well?
Edited by fenis, 22 March 2011 - 10:20 AM.
