Going Active.. HELP
Posted 29 March 2011 - 01:22 PM
Just need a bit of help. I'm looking at going active in the Falcon but I just need some clarification.
Speakers are Focal 165KR2 splits, Amp is a Tru S44. The Power RMS of the speakers is 80w, 160w Peak (Not sure on what the tweeters are rated at). The Amp specs are 4x65w at 4ohm, 2 x 100w @ 2ohm or 2 x 200w @ 4ohm.
I also have a JL 300/4 which I could use soley to run the tweeters.
My question is will 4 x 65w be enough power to get the Focals sounding nice if I run the woofers and tweets off the one amp? or should I run just the woofers off one amp and tweets off the JL?
It's all so confusing to me.
If any more info is required let me know.
Thanks in Advance =]
Sam,
Headunit: Clarion HX-D2
Front Speakers: Focal 165KR2 + Focal KRX3 Midrange
Front Speaker Amp: Tru Tech S44 & PDX 4.150
Subwoofer: Infinity Perfect 10VQ
Subwoofer Amp: JL 500/1
MEA SQ 2010 STATE CHAMPION - INTERMEDIATE CLASS
MEA SQ 2011 RUNNER-UP STATE CHAMPION - ADVANCED CLASS
SHOW CLASS JUDGE
Posted 29 March 2011 - 01:48 PM
Posted 29 March 2011 - 02:25 PM
Actively, the TNK tweeter is 8omhs while the 6KR2 midwoofer is about 3ohms (someone able to confirm?, my google-fu is lacking)
So with the Tru amp, the tweeter will only be seeing ~30wrms (potential RMS), while the midbass will see up to ~ 110wrms (potential RMS).
Posted 29 March 2011 - 05:05 PM
So I should be able stay with just the Tru amp and leave it at that?
SHOW CLASS JUDGE
Posted 29 March 2011 - 05:07 PM
Anyone know?
Front Midbasses : Focal 165 KRX2 6.5 x2
Front Tweeters : Morel MT-37 semi horn loaded x2
Subs : Mach5 IXL 18" subs x2
Deck : Alpine W502e double din touch screen
Amp : Soundstream REF 4.920 4ch
S Amp : Soundstream DTR 1.2200 Mono
Processor : Alpine H701 8 channel processor running active
Proofing : Dynamat Xtreme bulk packs
Wiring : 0Ga power x2, dist block, 4Ga to amps
Power : Optima yellow top D34
More to be added. .
Highest DB score: 142.0 @ 42 HZ
Quote:
The smoke is like the soul of your gear, if it rises to heaven you know you gear is dead. Shane
team rocket is burping off agaaaaaaiiiiiinnnnnn!!!
Posted 29 March 2011 - 05:27 PM
Looking at the specs for the S44 shows that it makes 100WRMS into 2ohms, this will be plenty to drive your midbasses.
What are you using to perform the active processing?
#7
Posted 29 March 2011 - 05:38 PM
SHOW CLASS JUDGE
#8
Posted 29 March 2011 - 05:43 PM
#9
Posted 29 March 2011 - 05:49 PM
I've still got the JL it's at my brother's plave. i'm gonna try and repair it and keep it in case of emergency. One of the grub screws is also stripped so I have to figure out what i'm going to do to fix that
SHOW CLASS JUDGE
#10
Posted 29 March 2011 - 05:53 PM
MR SPL, on 29 March 2011 - 05:07 PM, said:
Anyone know?
TNK Tweeter = 8ohms
6 KR2 Woofer = 2ohms
#11
Posted 30 March 2011 - 07:04 PM
One thing I would be careful about is that the Focal tweeters don't handle low frequencies well at all...be very careful not to cross them too low if you're going active (or to shallow a slope) or you might end up with fried tweeters.
I think the factory XO is upwards of 3khz and somewhere around 12dB or 18dB per octave.
Source: Clarion HX-D2
Subwoofer Amp: Celestra VA210
1998 Ford EL Fairmont
Source: Eclipse CD8455
Amp: Helix HXA-500
#12
Posted 30 March 2011 - 11:21 PM
More to be added. .
#13
Posted 31 March 2011 - 12:04 AM
Max - 2009 MY10 Mitsubishi Lancer RX
Chasing 110 points in Advanced SQ.
HU: Eclipse CD7200 mkII & iPC-106
Processor: Audison BitOne
Front stage: Precision Power 356cs 6.5" splits - Active
Amp: Polk PA1100.5 - 4x 80W rms @4ohm to front stage, 1x 600W rms @1ohm
Sub stage: Polk MM1040DVC x2 wired to 1ohm
Credts:
Initial Instal: Elite Car Sound ACT
2011 Update: BitOne Install & Tune by FHRX
Worthy mentions (advice/assistance): 2LOUD2OLD, IncredibleHulk, Syd Monster and others
2012 Update: Switch to 100% Active front stage by yours truly - retune in progress
Results/Awards:
2011 Intermediate: 1 Runner Up, 1 Win, 1 Judges choice, Points Champion (tie)
2012 Advanced: 1 Runner Up, 1 Judges Choice
#14
Posted 31 March 2011 - 06:22 PM
MR SPL, on 30 March 2011 - 11:21 PM, said:
Not a bad idea, because the Focal K series mids are actually really nice. The only real thing holding back the K series Focal's is the high crossover - neccessary to protect the tweeters, but makes it tough to get good upper midrange when off axis in a car door.
They would sound bloody brilliant matched to some Peerless HDS, Scanspeak Illuminator or SB Acoustic SB29 tweeters...all of which work nicely crossed at 2khz. Neither of these will matchthe Focal crossover though...you'd need to go active pretty much.
Amp: Helix HXA-500
#15
Posted 31 March 2011 - 08:19 PM
Sorry to highjack thread!
More to be added. .
