Headlight turno off delay (Follow me home lights)
Posted 01 August 2011 - 11:41 PM
IE turn the car off with the headlights left on and it leaves them on for say 30 seconds then turns them off?
Pretty sure jaycar used to do such a kit but I cant find it. I really miss the follow me home lights from the MG and every time I drive mum and dads cars I remember how good it was.
Would really help a lot as I have wired my headlights to be ignition on lights on.
Also does any one know of a delay timer so I could turn my ignition on but then have a (bypassable) 15 or so second delay till the headlights come on. cant be good for the lights to be turned on during preheat and cranking on an old diesel... I believe there is such a module for motor bikes fitted with HIDs to prevent them doing ballasts during crank
'01 GU II TD42T
Posted 02 August 2011 - 09:31 AM
VICTORIAN MEMBERS CLICK HERE
Mine is quite small
Posted 02 August 2011 - 10:18 AM
What about the turn on delay?
'01 GU II TD42T
Posted 02 August 2011 - 05:20 PM
Posted 02 August 2011 - 07:29 PM
'01 GU II TD42T
Posted 02 August 2011 - 09:08 PM
just a thought.
3rd Melbourne Autosalon Db Drag'05
2nd Melbourne Autosalon Db Drag'06
1st Autobarn Hoppers Crossing Db Drag '06
1st A&P Electronics Trarlgon Db Drag '06
1st Autobarn Epping Db Drag '06
2nd Stothers Music and HI-FI Db Drag '06
2nd Aust Finals '06
1st Melbourne Autosalon Db Drag '06
1st Phatt Audio Concepts Db Drag '07
1st Melbourne Autosalon Db Drag '07
2nd Melbourne Autosalon Db Drag '07
PB 149.1db on TL
#7
#8
Posted 03 August 2011 - 10:02 AM
I'm about to rip the unit out and see if I can put a better antenna on the RX unit and see if I can replace the TX unit with something better than the standard nissan unit if upgrading the antenna on the RX unit doesnt solve my issue. Not really interested in changing to an after market alarm - I have insurance and the OEM unit is fine as they cant do much unless they bypass NATS and if they bypass NATS then they know what they are doing and no 3rd party alarm is going to stop them.
In other news guy in fleebay can cut me new keys and program the NATS chip for under $70 - thats nearly $50 cheaper than any other quotes I've had and over $100 cheaper than going to my local nissan dealer!
I've got a 315mhz remote coming from hong kong which im going to set up for switching my compressor on and off and my rear light on and off and there are two spare channels still so maybe worst case scenario I use one of those.
Gunna give the cap idea a go first.
'01 GU II TD42T
#9
Posted 03 August 2011 - 10:08 AM
i put a 50buck special central locking kit in and works from about 30m away.
2nd Aust Finals '06
PB 149.1db on TL
#10
Posted 03 August 2011 - 10:50 AM
http://www.jaycar.co...ht&form=KEYWORD
Sometimes its the simple things...
http://www.ebay.com....=item1e65a78795
'01 GU II TD42T
#11
Posted 03 August 2011 - 11:06 AM
2nd Aust Finals '06
PB 149.1db on TL
#12
Posted 03 August 2011 - 11:37 AM
Might be time to rip the dash out...
I need / want both
I want a delay from turning the ignition on till the headlights come on - so they dont come on during cranking. Then I want them to stay on for 30 seconds after I turn the ignition off (or open the drivers door - undecided at this stage)
'01 GU II TD42T
#13
Posted 03 August 2011 - 11:54 AM
http://www.the12volt...s/page5.asp#lsp
2nd Aust Finals '06
PB 149.1db on TL
#14
Posted 03 August 2011 - 01:52 PM
'01 GU II TD42T
#15
Posted 03 August 2011 - 02:23 PM
Edited by AJ (LOUDA1), 03 August 2011 - 02:30 PM.
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
