So I need to document this otherwise it will never eventuate and I need people to chastise me for being lazy when progress slows.
Here is the plan, a 50/50 water meth mix sprayed in pre turbo by a ~300-350CC standard type petrol injector. For the people thinking the injector will sieze running water you can "supposedly" run about 2% machinists oil which will mix with both the water and the methanol and keep Mr injector doin his thing.
What I need-
Water pump- Flojet pump rated at 95Psi with overpressure cutout, the ability to run dry and handle solvents.
Regulator- Adjustable regulator which returns to the tank.
Injector- Don't have one yet but need an injector that is similar to a standard flow rate for my engine, I think it's 350cc/Min
Injector Driver- Jaycar injector driver, I was originally going to use a MAP sensor but that would have needed a fre to freq convertor to give me an input driver for the injector driver and that is too much work.
Boost Switch- This will probably be a 5Psi switch which will trigger the power supply relay for the pump and injector driver.
I am just going to set it up like a piggyback(?) setup, I am just stealing a signal from one injector and using that as the input for the injector driver. Because I will be running 50/50 water meth the injector will not flow as much as an injector flowing petrol, this suits me well as I want to run about 15% water meth mix to petrol ratio. I may have to run a slightly larger injector but I can adjust injection pressure up to 95Psi and because it is on the low pressure side of the turbo I don't need to worry about a rising rate regulator.
So all in all it seems like it will be fairly easy to do and will be more accurate than at least 50% of the kits avaliable on the market.
If you have any questions or I forgot something, let me know.
Pics of the beginnings in the next week or so.
