n9600gt
Posted 07 September 2011 - 02:48 PM
BMW 3231 E36 - alpine cda 9887, Orion Millenium 6.5 w/ a/d/s 346is tweeters and xover, Rockford Fosgate Punch 150 25 to life, Orion h2 15.2, Orion XTR2250
Trusted Sellers - Gozza, DrBoom
Posted 07 September 2011 - 06:50 PM
or put it in your rig and power it up, see if the fan comes on
www.fuddbutter.com
Posted 07 September 2011 - 08:52 PM
Edited by perrin_07, 07 September 2011 - 08:52 PM.
Posted 10 September 2011 - 07:05 PM
Setup:
Clarion Digital Mechless HU
PPI 4ch 110wrms x 4
JBL GTO 608C 6.5" Splits
Bonecrusher 2 4000w rms @ 1 ohm 12v
4 150ah Exide Sealed Batteries
6 Elevation Audio SQx 12"
Shok Industries 0gauge
Stinger RCA's
Posted 10 September 2011 - 07:38 PM
Back in the day when the tiny fans would seize up or fail to cool the card, you could grab an old AMD CPU heatsink and put it on the graphics card. All you needed was a little thermal paste, and to drill a hole in the CPU heatsink to line up with the card's mounting holes.
New ones are harder to do, you might have to remove the stock one, and either cable tie or bolt it on.
Posted 11 September 2011 - 07:45 AM
If this dont work, do most computer stores sell replacement fans or would it be more involved?
#7
Posted 11 September 2011 - 06:36 PM
Some are just a standard size and you can swap the original out for a different, better brand.
More likely, it's some sort of fancy moulded heatsink and you'll struggle to find one that will fit.
Most of the time, though, an aftermarket one will fit with a bit of persuasion.
Question, though.... is it just seized?
Does it spin freely when you flick the blades with your finger?
#8
Posted 12 September 2011 - 07:57 AM
#9
Posted 12 September 2011 - 09:19 PM
Usually the fan will have a sticker on the back of it.
Peel that off, carefully so you can put it back, and spray a little bit of lubricant on the axle.
Spin it around a couple of dozen times with your finger, and it should loosen up a bit.
Try it with power again.
#10
Posted 15 September 2011 - 10:44 AM
Edited by ~Sparkles~, 15 September 2011 - 10:53 AM.
'01 GU II TD42T
#11
Posted 15 September 2011 - 09:40 PM
#12
Posted 18 September 2011 - 04:52 PM
Setup:
PPI 4ch 110wrms x 4
Stinger RCA's
