SONATA 4 SPECIFICATION:
1. Amplifier output is:
4 x 100 Watt RMS @ stereo 4 ohm
4 x 100 Watt RMS @ stereo 2 ohm
2 x 300 Watt RMS @ bridged 4 ohm
2 x 300 Watt RMS @ bridged 2 ohm
2. Efficiency is 73%.
3. Size is 272 mm (length) x 147 mm (width) x 49 mm (height).
4. Weight is 2.5 kilograms.
5. National Semiconductor LM4562 audio op-amp at pre-amplifier stage. Its specification is higher than Burr Brown OPA 2134 (50 Mhz bandwidth for LM4562 versus 8 Mhz bandwidth for OPA 2134).
6. Shielded coil at output stage for more focus magnetic flux and less eddy-current.
7. Complete protection against wrong battery connection, DC offset output, speaker cable short circuit, and over-heat.
SONATA 4 FEATURE:
1. Green class D technology with very high efficiency. Its maximum current draw is only 40 Amperes and in most cases user won't need to change battery or alternator. The power cable size needed is 8 AWG.
2. Class D full range amplifier design that is not an expansion from limited bandwidth class D design. The result is natural sound
3. As typical all class D amplifier, Sonata 4 has the ability to drive speaker with fluctuating impedance.
4. Compact size for easy installation and placement
5. Weight is 2.5kgs.
6. Casing is made from aluminium extrude for sturdy construction, less distortion, and maximum heat dissipation. Finishing is bronze color anodized.
7. All terminals are on the same side for easier and tidier wiring. Amplifier gains are on the other side to make it is easier to reach for quick adjustment.
8. Speaker and power terminals are "screw in" type for maximum contact and hassle-free connection.
9. RCA terminals are "chassis" type for sturdy connection and furthermore to avoid RCA body touching amplifier body.
10. Logo can be rotated every 90 degree for maximum flexibility. In this way, Sonata 4 can be installed upside down and all we need is to rotate the logo.
