highest db measured on lowest rms
94 replies to this topic
#1 jas13
  • 41 posts
Posted 31 October 2011 - 12:58 PM
hi as per title just wondering what everyone has recorded on spl or music with low rms? im working on a new goal to achieve a 140 on music and 145 burp.i have recorded a 138 music and 141 burp on 2 x 12"s and 350 wrms to each sub from the amp at 2 ohms.your input would be greatly appreciated.do you guys think its possible?thanks jas.
#2 Big_Valven
    MEASQ [SA] Coordinator
  • 6,887 posts
Posted 31 October 2011 - 01:04 PM
Depends on everything. Car, box, port area, woofers, tune, positioning, loading, frequency, car peak.
700 watts rated isn't an overly low amount of power.
#3 dbdrgaoz
  • 65 posts
  • State:Other
Posted 31 October 2011 - 01:39 PM
I have just put a system together in a Toyota station wagon, 1600wrms and 1 x FCW-15 Does 146.7
#4 Big_Valven
  • 6,887 posts
Posted 31 October 2011 - 02:05 PM
1600 watts is heaps. Even I've done 146s from 1.6KW...
#5 ryzaa
    Transcending Superfluous
  • 461 posts
Posted 31 October 2011 - 02:21 PM
Bobo has done 148ish from 1500w
Doug and I burped a 150 at 36hz off a clamped 1700w and one dead woofer.
As Big V said, 1500w is not really low power...
*Awaits old school guys who had AudioControl meter and Cheater amps*
EDIT: disclaimer: scores set at a certain Easternats event dont actually count :P
Edited by ryzaa, 31 October 2011 - 02:23 PM.
#6 barcode
    1500 - 3000w RMS
  • 1,696 posts
Posted 31 October 2011 - 02:23 PM
120 something off 800rms.
lower tuning than you though lol
DISCLAIMER: If you find a post or a message from me offensive, inappropriate, or disruptive, please ignore it.
If you don't know how to ignore a post, complain to me and I will be only too happy to demonstrate.
RANDOM INTERNET GUY said:
Modifying a car on centrelink is like attempting to stop masturbating over bukakke videos, it just wont happen...
#7 Lunchbox.inc
  • 4,620 posts
Mad Ras(spelling?) on here, was doing 141's off 2x clarion 15"s and a jaycar 4x 100rms 4ch in his yellow pulsar, running 2ohm off a pair of the channels, which i believe is around 150rms per woofer...
as far as i'm concerned thats an AWESOME score off <300rms...
700rms really is plenty of power, and 1500rms+ is a tonne...
#8 268669♫
    expert in my own lunchbox
  • 2,640 posts
Posted 31 October 2011 - 02:28 PM
If you want big numbers off low power you need a high sensitivity subwoofer and a tapped horn.
Ant
Previously:
SStealth
Antony
#9 SSSpoosah
  • 230 posts
Posted 31 October 2011 - 02:29 PM
I'd be thinking probably 300wrms-500wrms
Basic entry level mono amp or multi-channel
#10 Big_Valven
  • 6,887 posts
Posted 31 October 2011 - 02:49 PM
I reckon it has to be <500w RMS rated to be considered "low power."
#11 lunchietey
  • 30 posts
  • Interests:Car audio derr! PA equipment, Home theatre, My dune Buggy and Women!
Posted 31 October 2011 - 03:11 PM
138.3 from 300 rms and 2 jl 15w0-8 sealed with music
#12 SSSpoosah
  • 230 posts
Posted 31 October 2011 - 03:40 PM
I find both of these very impressive :yahoo:
#13 Fury♫
  • 4,422 posts
Posted 31 October 2011 - 03:41 PM
138.3db on a termlab with 1 x 12" in 1cu.ft sealed box off 400wrms... in an excel :P
#14 Spink!
  • 869 posts
  • State:ACT
Posted 31 October 2011 - 03:50 PM
On a first run in an N15 pulsar hatch me and my friend did a 140.6db from memory, 2 old unknown kenwood 12's, 600wrms at 2ohm, 47ish hz 90mm single flared port, loading off the tailgate. With some tinkering should get it a little higher.
My VY Berlina
http://www.mobileele...rlina-sq-build/
H/U - Alpine 9855r
Speaker Amp - Alpine MRV-F545
Sub Amp - RF T1001bd Power Seires
Front Stage - SB Acoustics SB17 Midwoofer
/SB29 Neo Tweeter
Subwoofers - 2 x Polk MM 10"
Optima D34 YellowTop, Stinger & Aerpro Wiring
#15 Lunchbox.inc
  • 4,620 posts
Posted 31 October 2011 - 03:58 PM
about the best part was the overal simplicity of madd_rass's install... it was very much what i would consider an "amature" install, not in a bad way, but you can tell when someone knows what they're doing, and when someone has just had a red hot go at it! and this was very much the latter, port was almost non existand, maybe 20mm wide, and i'm not even sure how long it was, i seem to think it was just the thickness of the mdf baffle....
(thats the port between the subs there)
i'm hoping Jason doesn't take this the wrong way, simply put i was VERY impressed with it, there was no real logical reason why it would work, but it did, and it got loud, and low too...doing the 141 at around 40hz...
Edited by I♥Miley.inc, 31 October 2011 - 03:59 PM.
