Ok well Its the summer break and its time to get serious! I will begin my design folio these few days...
So in Summary, I have concluded that I will mount the Jaycar modules (around 3 or 4 of them) in a plexiglass box which will sit inside an MDF box along with a computer CD drive which the CD tray will be custom attached to the underside of the box. This removes the hassle of huge expenditure for linear actuators or wasting time in designing and testing a slide and rack system which will be making the project unnecessarily difficult. The CD tray will move out a total of approximately 5.5", this is sufficient length for the module box to be fully exposed to viewers. A hollow rectangular hole will be cut on one side of the box, thus allowing the module box to move in and out. A small hole will be drilled for the button on the CD drive.
I would like to fibreglass a box for the modules which contours the dash top, but Im not sure how to go about the proper procedure to create the mould. I can fibreglass, but have minimal experience in creating moulds except speaker pod moulds lol. However fibreglassing a box then finishing it in a nice leather trim would yield many bonus marks for my assessment compared to a plain MDF box!
IMG_0799INT2.JPG 642.44K
3 downloads
001.jpg 488.69K
2 downloads
Heres something that I made previously, its a home audio system using car audio equipment running off a power converter from 12v to 240v. Pretty much a box just like the headunit box in this pic. An empty hole, the CD tray on the base and the module box moving in and out. Thinking to mount the box onto the dash of the car or somewhere under the dash. or even next to the centre console.
41064_1484517886535_1641531072_1183202_6527014_n.jpg 97.54K
3 downloads
Now I am not an expert in computer equipment so I would like to receive some help to wire the drive into the car. Do I Just run the 12v connection to the accessory in the car? Or should I run it constant 12v? Even if I ran it constant, it shouldnt drain the battery right? Its not using any power if I dont open or close it?
Theres two ground terminals? Do I bridge them and ground it to the chassis of the car? Do it leave the 5v alone?
IMG_2876.JPG 1.86MB
1 downloads
I will not need any of the CD laser readers, or any of that extra stuff in the CD drive. Is it possible to remove these components without preventing the CD tray motor from working? the circuit board on the left of the pic are where the cd tray motors are and the circuit board at the back are for all the lasers readers, etc. Both boards are connected via an electrical strap thing. Wouldnt I be able to get rid of all the laser readers etc aswell as their circuit boards then run power straight to the motor?
IMG_2877.JPG 1.95MB
1 downloads
I will have to modify the CD tray or produce a completely new tray to bolt onto my module box, but you can see it uses a rack and pinion system.
IMG_2878.JPG 1.78MB
0 downloads
IMG_2879.JPG 1.84MB
0 downloads
Its a bit of a long reply but I just need some guidance for this, dont want to end up blowing anything up lol. I dont have much role models who can help me with this project, so any help will be greatly appreciated!
Edited by Tommei, 22 December 2011 - 04:11 PM.
