Central Locking doesn't flash hazards
7 replies to this topic
#1 qwerty_man
  • 184 posts
  • State:NT
Posted 11 December 2011 - 01:24 AM
Hi guys
Hopefully this is a super quick question.
The car I just bought for my girlfriend came with remote central locking (which works perfectly) except when it locks/unlocks the doors the indicators don't flash. It's a simple small thing I know, but the misses is on my case because sometimes she doesn't know if it's engaged or not.
I'm told via a receipt which I don't have access to it's a "VISC400R Vision door lock system".
Is it a quick and easy task to add the indicator/hazard flash to the car? (It's a 1998 Lancer).
Thanks!
Edited by qwerty_man, 11 December 2011 - 01:26 AM.
#2 icacha
    Resident wanna be comedian AKA George
  • 5,362 posts
Posted 11 December 2011 - 12:16 PM
thats all it might be, remote keyless entry.
Q: How do you know if you're too drunk to drive? A: You swerve to miss a tree then realise it's the air freshener hanging from the rear view mirror.
Albert Einstein: (you think he was thinking about the I.C.E. industry when he said the following?)
-We can't solve problems by using the same kind of thinking we used when we created them.
-Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe.
-Insanity: doing the same thing over and over again and expecting different results.
#3 bobo333
    Mr Temporary Setup
  • 5,368 posts
  • Interests:loud noises
Posted 11 December 2011 - 01:03 PM
most remote central locking kits have a wire to hook up to the indicators which whoever installed it obviously didnt do, youll have to find the control module (usually would be under the steering column or in the drivers kick panel) and try to get a wiring diagram or figure out which wire it is to go to the indicators and hook it up, im not familiar with that particular system but the wire is often yellow if that helps...
you might have to put in a couple of diodes too if there is only 1 indicator wire coming out of the control module so that when you hook both indicators up to it they dont backfeed into each other when your trying to indicate
Posted ImagePosted ImagePosted Image
^^^ Click for build logs ^^^
#4 MOBASS
  • 84 posts
Posted 12 December 2011 - 08:40 AM
Some of the keyless entry kits do not have the hook up wires for the indicators, some do...
Best thing to do is ring the company on the receipt and as them if it is possible for them to connect up the indicators with that particular keyless system.
Simon
#5 Carbon Car Systems
  • 28 posts
Posted 27 February 2012 - 07:15 PM
Hi,
The Vision keyless entry system doesnt have indicator / flasher outputs for the blinkers. No good mate, it just locks / unlocks the doors listen for the noise. :(
Kind Regards,
Daniel Gardener
Carbon Car Systems
Daniel Gardener | Auto Electrical Surgeon
T: (02) 9831 3288 | M: 0411 101 737
E: daniel@carboncarsystems.com.au | W: www.carboncarsystems.com.au
Unit 21/47 Third Avenue, Blacktown NSW 2148
#6 artuc
  • 164 posts
Posted 28 February 2012 - 12:29 AM
It still may be possible in theory as the lock/unlock could be used to trigger a circuit that will then flash the indicators, would be a huge pain though and would just be easier to swap out the module for one that can.
2004 Ford Courier Spacecab TD
#7 SeptemberSquallIndustries
  • 47 posts
Posted 17 March 2012 - 09:02 PM
Just wire the unlock trigger via two relays in parallel to ground.
High side of relay one is the original lock/unlock circuit.
High side of relay two can be:
  • a circuit you design to flash the indicators;
  • OR easier, simply a circuit from +12V via a squalker to ground (think reverse sensor "beeper");
  • OR easier still, simply a circuit from +12V via one factory horn to ground (will chirp the vehicle horn).
  • OR more interesting, a circuit to fire streamers from the exhaust of the car or some other wife-obvious way to indicate the car is locked?
" I could clear this sky in ten . seconds . flat... "
#8 mdlr
  • 51 posts
Posted Today, 07:46 PM
Hi. All current vision remote locking controllers have 2 outputs for light flashing , the vae 316 490 has unfused green/blue wires and the vae 318 650 has fused green wires while the TP360r remote locking kit has a single wire to flash park lights, it also has anti hi-jack wiring. Cheers MD
HI
I'M MICHAEL
NA 2003 BA ACID RUSH FUTURA WAGON
auto on cruise control | lightup window switches | doubleclick window lift from remotes
