grounding chassis of amp to chassis of car - noise?
amplifier chassis ground
15 replies to this topic
#1 broadz
  • 2,400 posts
Posted 14 December 2011 - 09:49 AM
Hi guys, i'm building an amp rack to hold my 3x old school Alpine V12s behind the back seat of my dual cab navara.
Space is extremely tight and as such I am forced to use a 3mm flatbar (20mm wide) bent and welded with amp mounting holes drilled and tapped to sit inbetween the ribs as you can see below.
I do not have enough clearance to mount an MDF mounting plate to the amp rack to isolate the amps from the (conductive) steel the amp rack is constructed from.
My intentions are as follows:
Is it truth or is it more of a myth that mounting the amps to directly to the body of the car will introduce noise into the system, enough to worry about?
#2 Arctic Alto
  • 98 posts
Posted 14 December 2011 - 03:04 PM
i would just use some rubber washers/grommets or a strip of rubber for the part the screws in..
then there's no metal to metal. :)
#3 fnlow
    SA Great!
  • 782 posts
Posted 14 December 2011 - 04:26 PM
What does the Alpine manual say? The DLS ultimate amp manual recommends isolating the amplifier chassis from ground. I have read on MEA of people fixing noise issues by isolating the amp, whether there will be an issue in your install is another matter though. Broadz is there absolutely zero thickness to be had between the rack + amp + back of seat ? 3mm sheet of toughned glass or similar?
And Arctic I'm not sure if I understand your example but it seems as though the fasteners would still have metal to metal contact.
Wanted to buy: Rockford Fosgate 12"- RFP 3412 - Please PM
Trust Your Ears
Trusted Seller(s): Ritonja, berger, Damon, vs380kw, Fhrx, Roo, k_p, advance, aragorn2, Ruffels
Trusted Buyer(s): bojo
#4 Sorin-Andrei
    139's is what i'm about
  • 3,032 posts
  • Interests:South Australia's awesome car audio scene
Posted 14 December 2011 - 04:44 PM
I would have thought some 3mm acrylic would also be a viable option..
Wanky uninstalled gear that I need to install in my 200sx this year:
Source: Alpine 9887
Front: 2 x SB Acoustics SB17 per door
Front Amplifier: Digital Designs S4a
Subs: 2 x Hybrid Digital Designs/PSi 99F series
Sub Amp: Digital Designs M2a
#5 Arctic Alto
  • 98 posts
Posted 15 December 2011 - 12:23 PM
True, you could use some plastic/rubber washers too
#6 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 15 December 2011 - 08:52 PM
Just use a rubber grommet that has a decent lip covering the metal bar and use small bolts thus not metal being touched.
Setup:
Clarion Digital Mechless HU
PPI 4ch 110wrms x 4
JBL GTO 608C 6.5" Splits
Bonecrusher 2 4000w rms @ 1 ohm 12v
4 150ah Exide Sealed Batteries
6 Elevation Audio SQx 12"
Shok Industries 0gauge
Stinger RCA's
#7 Arctic Alto
  • 98 posts
Posted 16 December 2011 - 11:39 AM
just a thought, maybe dont screw it at all,
you could use some decent velcro for the whole back of it.
#8 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 16 December 2011 - 12:02 PM
I used velcro on my metal amp rack, this stuff was that nuts strong it took me a bit to seperate them lol.
Setup:
PPI 4ch 110wrms x 4
Stinger RCA's
#9 Finezy.inc
  • 101 posts
Posted 16 December 2011 - 02:30 PM
i believe you can by nuts and bolts of various sizes that are made of nylon and non-conductive, might
be worth looking into that with some nice fat rubber washers or something. :)
Boom Boom Barina
PB: 150.4 @ 44hz - Autobarn Test 'n' Tune Traralgon
#10 Frankston Car Audio
    1500 - 3000w RMS
  • 2,131 posts
Posted 16 December 2011 - 04:21 PM
Dan, you could use something like these if you can find an extra few mm to space the rack out.
The link is to the US, but I know these are available locally.
Mark
2010 Victorian State Runner-Up - MEASQ Expert Class
2011 Victorian State Champion - MEASQ Expert Class
#11 Lunchbox.inc
  • 4,620 posts
Posted 16 December 2011 - 05:00 PM
Mark
those things are definitely cool!! where would one find them...? bunnings etc? or somewhere more specialised...?
#12 Frankston Car Audio
    1500 - 3000w RMS
  • 2,131 posts
Posted 16 December 2011 - 05:23 PM
They're actually isolators for noise and vibration, Lunchy..
Not sure if Bunnings would carry them, but a commercial nut and bolt retailer might.
I have seen them somewhere.. I just can't remember where! :fool:
Mark
#13 Lunchbox.inc
  • 4,620 posts
Posted 16 December 2011 - 05:32 PM
Mark
that old age getting to you again i see!! hahaha
might go check out that nuts and bolts place on hartnett drive, they have pretty much anything you could ever want! haha
#14 sean
    MetalManiac
  • 2,510 posts
  • Interests:Electronics, Audio, Metalwork
Posted 16 December 2011 - 05:39 PM
Some common places you should find used ones are in old washing machines and driers (if you can't find any new locally)
Black Alfa Romeo 164 Q: Denon DCT-Z1, Zapco 1000.1,
Sinfoni 90.2 (2x), Sinfoni 45.2x, Scanspeak AirCirc tweeters,
Focal Be 3W2 Midrange, Focal Be 6W2 Midbass,(2x) PHD AF10W subwoofers
______________________________________Trusted members:_________________________________
___muzzy66, zion187reigneth, Darkness_GR, TRD1JeeZy, 1point21gigawatts, DrBoom, NowHearThis,___
___Chemhaz, Charger, broadz, ~thematt~, keepitreal07, philz, Pulse-R, blanketman, TEGBOY, Damo95,___
_____Pacman, FaBzZz72, devolutionary , The Toad, shaky, MattVIP, Blackfox, Brycestro, KARAFLA_____
__268669, GTi-FTW, fury, Stone, stupidfingers, Tiger, brown202, burgsy, brady123, Morpho, Mr. Drifter____
#15 aj2thec
  • 539 posts
  • Interests:Turbos, girls, snowboarding
  • State:ACT
Posted 16 December 2011 - 11:24 PM
This is what I would do:
Mount amps without insulators.
1. If no noise - crack a beer and admire work.
2. If noise: get 2/3/4mm clear tubing from Bunnings and make collar / washer for screws. Cost: 50c - $2. Crack a beer and admire work.
Car: 04' Lancer Headunit: Alpine 9887 Highs and Mids: Digital Designs DDA + S4 Sub: Digital Designs 3512 + M3
Lancer build Civic build Bitchn Magna build FD RX7
