BA Falcon - ICC Speaker Output
5 replies to this topic
#1 ch0c0
  • 124 posts
  • Interests:FORD, Car Audio, IT
Posted 20 December 2011 - 10:59 AM
Hi all.
Ive got a bit of an ongoing drama with noise in my BA. The noise thread can be found here:
http://www.mobileelectronics.com.au/forums/index.php/topic/564364-ba-falcon-noise/
So ive finally found some time, and pulled out the ICC. However, it looks like the line level outputs are in the top plug, which is fixed into the dash.
Whats the best way to tap into the outputs ?
Thanks,
Dan.
#2 ch0c0
  • 124 posts
Posted 20 December 2011 - 10:47 PM
Im about |---| this close to ripping it all out, cutting my losses, and dealing with the stock stereo!
#3 bob
    3kW Power House
  • 3,883 posts
Posted 21 December 2011 - 07:52 PM
Hey mate, what are you trying to achieve?
Line level outputs from the ICC? If that is the case, you need to solder to the ICC amplifier board before the signal gets amplified.
BA XR6 - HERE
Want to fit a deck to your BA? Click Here
#4 ch0c0
  • 124 posts
Posted 21 December 2011 - 08:59 PM
No.
I just need to get access to the speaker outputs as close as i can to the ICC, because thats its definitely getting noise induced from the harness.
At the moment my LOC connects behind the kick panel, as thats the easiest place to get the signal from.
#5 bob
    3kW Power House
  • 3,883 posts
Posted 22 December 2011 - 05:50 AM
OK, then you are right, you need to get at them from the large plug in the dash.
Have a good look into modifying the ICC to get line level outputs though. Then you can bypass the LOC.
http://www.asllogist...utput-p-28.html
These guys do it for $220, but I remember seeing a post somewhere where someone did the conversion themselves. I have an ICC here that I can pull apart to check it out to try.
Is there any reason you don't want to add an aftermarket deck to the tissue box area? I had the exact same problems as you, and all my problems went away when I put in a new HU. I will never look back either!
If you want to go down the route of an aftermarket headunit, I have a spare fascia here you can have cheap
BA XR6 - HERE
#6 ch0c0
  • 124 posts
Posted 22 December 2011 - 09:01 AM
Unfortunately im using the tissue box holder for something else (UHF CB). It fits in there perfectly and there isnt really anywhere else to put it. Adding low level outputs may be a good option though. Ill look into it.
