Headunit dims with accessories yet wiring is fine
5 replies to this topic
#1 VippiN
  • 169 posts
Posted 28 December 2011 - 04:05 PM
Edit - Thanks for the help
Edited by VippiN, 28 December 2011 - 08:22 PM.
#2 peaandham
    I'm John Wayne Pilgrims.
  • 4,086 posts
Posted 28 December 2011 - 05:06 PM
What car is it in bud?
Perhaps its a factory fault with the car, maybe a google search with some keywords including "dimming" or "illumination" and the model/make of the car?
Edited by peaandham, 28 December 2011 - 05:07 PM.
1st Place in SA's first SQ Comp, Intermediate Class.
1st Place in SA's First 2011 Comp, Intermediate Class
Sales Assistant for Solver/Wattyl Paints and Granosite Texture Coatings.
Inquires Welcome.
#3 VippiN
  • 169 posts
Posted 28 December 2011 - 06:00 PM
Hi mate, Googled for hours no dice, friends with same car all works fine. Car is a 2002 Impreza.
Just randomly tried hooking it up to the interior clock's illum wire, same drama.
#4 Frankston Car Audio
    1500 - 3000w RMS
  • 2,131 posts
Posted 28 December 2011 - 07:46 PM
Subaru's have two illumination wires.
IIRC the wire you need is a light green/yellow?.. it is normally located in the factory headunit connector, in the row below the wire you have connected to.
Don't rely 100% on my wire colour above, as I am doing this from memory!
... and please don't use a test light in this vehicle (unless it is a computer safe type.) to find the second illumination wire.. Only a multimeter should be used in most modern vehicles. as the current supply from the ECU that controls most functions, can be damaged by the excessive current draw from a light type tester.
HTH :)
Mark
2010 Victorian State Runner-Up - MEASQ Expert Class
2011 Victorian State Champion - MEASQ Expert Class
#5 VippiN
  • 169 posts
Posted 28 December 2011 - 08:20 PM
Yellow/green is 12 volt acc.
Problem found and fixed.. For some reason my +illum was giving off 4 volts on acc.. So wired straight from headlight stalk = working.
Thanks for the help either way :good:
Edited by VippiN, 28 December 2011 - 08:30 PM.
#6 ubernoob
  • 971 posts
Posted 28 December 2011 - 08:45 PM
Did you originally use the wire that is after the dash lights dimmer?
Volvo 2001 S60T5
HU- Blaupunkt Bremen
Front Midbass- CDT ES06
Front Mid- CDT HD2
Front Tweeter- CDT ES010
Nothing good ends in phile.
