The other day i fitted a response 4 chan amp into my BA ute using an REQ5 loc. Everything went fairly smoothly except for the dreaded whine coming through the speakers. Now i did miles of research as my grounds are solid, the req is grounded at the same place as the amp (according to the req5 manual this creates a ground loop isolator). RCA's are only 500mil long and no where near power so theres no chance of interference through them.
Now i read some people had success with the jaycar noise filters, and at 15 bucks i thought i'd have a crack.
So heres my first question: Using the stock ICC unit, how do i install one of these? There are three wires, ones for the 12v constant, ones for ground and the other is for the 12v constant from the head unit (i've added a pic to make more sense), if im to use this noise filter where can i get this wire from?
Now whilst i was looking around behind the ICC for the 12v constant, i remembered reading about unplugging rcas/speaker wires at the amp to see if the noise stops, so i unplugged rcas and the noise stops. OK, plug them back in and unplug the speaker wires, noise stops! Does this mean im getting interference from the speaker wires? I've run the power from the bat through the center and speakers down the drivers side so thats not a prob. I did notice that there are wires running down the drivers side for the drivers seat adjustment as well as the antenna cable, could these cause interference in any way?
One other possibly stupid question, is there any difference between the red power cable and brown ground cable you buy? Reason im asking is i've used a short length of red power cable for my ground to my amp as i didnt have any brown ground cable.
I know people on here have had some drama with the ICC's in the falcons and have opted for an aftermarket head unit, but there doesnt seem to be many solutions other than this.
Alpine 9835
PS2
Clarion TVX-6651
Boston Z6
Phoenix Gold X200.4
Focal Plain Chant
Dynamat
