wiring problem need help please
Posted 15 January 2012 - 03:48 PM
to eliminate some possibilities i have borrowed the same head unit off a mate connected it up and the problem still happened.
i then temporarily re wired the constant power but its still doing it.
so i have taken it to the local auto electrician and he cant work out what it is, and recommended i take it somewhere else haha
im unsure what to do next, please help
thanks
Jarrad
Posted 16 January 2012 - 12:54 AM
Posted 16 January 2012 - 08:51 AM
What car?
Which model Alpine?
Does the Alpine use a "hide-away" control box?
Are you using a "plug & play" adapter harness?
Did you solder the connections, if not using an adapter?
Where/what have you connected the ground to?
Answer theses and give us any other info you may think relevant, and we will be able to help further
Mark
2010 Victorian State Runner-Up - MEASQ Expert Class
2011 Victorian State Champion - MEASQ Expert Class
Posted 16 January 2012 - 03:43 PM
Posted 16 January 2012 - 07:20 PM
head unit is alpine IVA-D106E
all connections are soldered and heat shrunk
the ground is connected to the roll bar looking thing inside the dash
this system i have had in for about 3 years with no problems at all until now
i have run a new wire staight from the battery with an inline fuse, but still no good
this weekend i think i will pull all the trims out of the poor old thing and go over all the wiring, is it possible some of the wiring to the amps have given up maybe worn through and is shorting it out and the head unit is going into some sort or protection mode?? not sure just putting it out there
thanks
Edited by GOT22Z, 16 January 2012 - 07:21 PM.
Posted 16 January 2012 - 07:28 PM
#7
Posted 20 January 2012 - 08:01 PM
#8
Posted 20 January 2012 - 08:08 PM
that should fix the issue.. :/
#9
Posted 20 January 2012 - 08:18 PM
#10
Posted 20 January 2012 - 08:48 PM
Sinfoni 90.2 (2x), Sinfoni 45.2x, Scanspeak AirCirc tweeters,
Focal Be 3W2 Midrange, Focal Be 6W2 Midbass,(2x) PHD AF10W subwoofers
______________________________________Trusted members:_________________________________
___muzzy66, zion187reigneth, Darkness_GR, TRD1JeeZy, 1point21gigawatts, DrBoom, NowHearThis,___
___Chemhaz, Charger, broadz, ~thematt~, keepitreal07, philz, Pulse-R, blanketman, TEGBOY, Damo95,___
_____Pacman, FaBzZz72, devolutionary , The Toad, shaky, MattVIP, Blackfox, Brycestro, KARAFLA_____
__268669, GTi-FTW, fury, Stone, stupidfingers, Tiger, brown202, burgsy, brady123, Morpho, Mr. Drifter____
#11
Posted 20 January 2012 - 08:58 PM
Did he get his ticket out of a weet bix box?
Front Stage- Crescendo opus 9.6 Active
Helix xxl - Power Station
Speaker Amp-DLS RA40 reference series
Sub-Morel Ultimo 12
Sub Amp-DLS RA10
RCA`S Harmonic Harmony
2010 Victorian State Champion-Intermediate Class 2010 Victorian State Champion-Show Class
2010 National Runner up-Intermediate Class 2010 National Runner Up-Show Class
2011 Victorian State Runner Up-Advanced Class 2011 Victorian Runner up-Show Class
#12
Posted 21 January 2012 - 04:51 PM
yeah dodgy auto electrician probably did wont mention names because hes probably a member here
amps are pdx 1.1000 and 4.100
#13
Posted 21 January 2012 - 06:16 PM
#14
Posted 26 January 2012 - 09:15 AM
