I'm kind of new to the big db league, but I have a good knowledge of installing amps/subs/speakers of a reasonable standard.
I'm currently installing a pair of JL Audio W7 13.5" subs, a pair of JL Audio Slash V2/1000 mono amps (1 for each sub), 2 pairs of Morel Elate splits and an Alpine PDX-F6 all into a mates VX Berlina.
The boxes are built to JL Audio specification and are slot ported, and built of 21mm (I think) MDF.
I have set the LPF and settings as per JL instructions (recommended settings for this amp/sub combo) and wired each voice coil to each output of each amp. IE: each amp has 2 outputs, one for each voice coil.
I set the gains by having them all the way down, setting the HU volume to 30 (out of 35) and started turning the gain up until I could hear some audible clipping, and then backing the gain off.
I did happen to notice that when it did clip, the "Low Ohm" light flickered on top of the amp, not sure if that's normal :S
After getting one sub set, I proceeded to the next sub and amp.
My questions are:
A) Have I done everything correct?
B) Have I missed something?
C) Should I be concerned of the "Low Ohm" light?
The reason I ask is because I believe these subs should be able to push more air before clipping than what they are. Currently the gain is only set at about the 9-10 o'clock position, with 12 o'clock being half way.
Any help would be much appreciated.
Cheers,
Spudley.
Edited by Spudley, 22 January 2012 - 01:45 PM.
